spohn sub frames
Old Mar 28, 2003 | 10:19 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
spohn sub frames
i ordered the spohn sub frame connectors last night to put on my 92 bird. from what i hear they are the best out there right now. so my question to you is, did any of you run into any problems with installing them? how difficult is it to do the installation myself? could i do it myself or do i have to take the car to some shop? basicly im asking those of you that have them or know somebody that does, how did the spohn connectors work out?
p.s. im live in chicago, if i have to take the car somewhere, can any of you recommen a place to take them? and how much am i look at for installation?
Old Mar 28, 2003 | 11:19 AM
91Z28-350's Avatar
To the original question, I'd try and find someone who's actually done SFC installs before. Cheap is nice, but you don't want to pay someone to learn to do it...on your own car. On someone else's car, sure. It's not difficult, if they follow directions, but that's a big "if" when you aren't in the lift area working with them (insurance and liability for the shop). Sorry I can't help, I'm not in Chicago.
Old Mar 28, 2003 | 06:28 PM
SteveSpohn's Avatar
To your first question, because he hates everyone, and that's why he's banned from thirdgen.org, and now this new user name he has chosen has been banned.
In your area, I'd talk to John at HPA for the SFC installation.
www.hpaparts.com
Thanks,
Steve
Old Mar 29, 2003 | 08:57 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
this could be a super dumb question to some of you, but they come with installation instructions correct? my friend is a good welder, but neither one of us have ever done SFCs but i want us to do them on my car.
Old Mar 30, 2003 | 03:10 PM
KMAN's Avatar
yes, the spohn come with instructions
Old Mar 30, 2003 | 05:45 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
hey steve,
ive seen some install pictures of your SFC's, and while they look like a good quality piece there is ont thing that confuses me....where the welds attach along the length of the connector, is there tabs on the tubing there? cause that looks like an awful long way to stretch a bead.
i have the SSM's in my car right now, very good quality piece, but the main reason i have them is because im using the lift bars...on another car where weight is an issue i think id be more inclined to use your product.
Old Mar 31, 2003 | 02:38 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Yeah, spohn SFCs are awesome. The only problem I had with them was I couldn't get the brace going from the passenger side sfc to the transmission tunnel due to lack of clearance from the dual cats. It wasn't really a big deal. There definitely worth the money in my opinion. I had a welding shop install them it took them about 2 days and cost me 140-160 bucks... that's including putting the new spohn lcas, brackets, and sfcs all on.
Old May 22, 2003 | 07:14 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
I just installed my first SFC and it went off pretty much without a hitch. Pretty basic stuff. My troubles where from the LCA bolts rust welded in. Took a crowbar to the *****(don't ask). Other than that everything is pretty simple. Still struggling with the passenger side Y pipe(lazy).
Old May 22, 2003 | 11:11 PM
laiky's Avatar
I got the Spohn's, besides the great service, there pretty straitforward to install. There not that hard to install, i am a very rusty welder! The only problem i had was getting the flange where 3 sheets of metal cometogether (the rail along the side of the car) clean enough for a good bead. They conform nicely to the rocker. I have a single Cat. I removed the heat sheild fromthe floor and cut about 3/4 " from the center where the cross bar goes then reinstalled it. I also used some 1/2" angle iron to attach to the floorboards, because i couldn't fill the gap too well.
Steve, i'd like to know what size wire you use for this as well as the welds to the floorboards??
Old May 24, 2003 | 11:39 PM
Spdfrk1990's Avatar
sounds like you had the same problems as me westman lol. Im going to get my y pipe fixed this weekend tho. I had to get the air hammer out to get my driver side lca bolt out.
Old May 26, 2003 | 07:50 PM
ebmiller88's Avatar
I'm all set to weld mine in tomorrow. I have the weld areas all sanded and prepped for welding. Steve recommends stitch welding along the inside of the tubing along the floorboards, and as 383 mentioned, that's a really big gap to try to fill with just a welder. I cut some pieces of steel about 3/4" in depth and will weld them in instead of trying to fill weld the gap, similar to Laiky's idea with the angle iron.
Steve's SFCs fit really well, come with very good instructions, and his website has good pics to see how they should look once installed.
I'll have pics posted tomorrow.
Ed
Old May 28, 2003 | 08:18 PM
ebmiller88's Avatar
Thought you guys might like to see more pics than what Steve has on his site.
The install went pretty smooth. Be careful with the heat and don't blow a hole in your floorboard...it sucks. I think I fixed it tho.
Anyhoo, like 383 mentioned, I felt I needed to bridge the gap a bit between the floorpan and the SFC so here's a pic of some metal I cut and damn if it didn't fit just about right.
Old May 28, 2003 | 08:22 PM
ebmiller88's Avatar
Here's a shot of the driver's side and where I sanded and grinded the paint away to weld. These SFCs were coated with POR-15 and I will recoat the welded areas with it also. I just picked out areas where the lip was closer to the SFC and welded there.
Old May 28, 2003 | 08:24 PM
ebmiller88's Avatar
Here's the little guy that did all the work. These little 115V MIGs are the cat's ***! Nice little units for us DIYs, and run about $400.
Ed
Old May 28, 2003 | 10:14 PM
MdFormula350's Avatar
my grandfathers mig wouldnt weld worth a crap so we used his stick welder that did the trick.
Old May 28, 2003 | 10:18 PM
Old May 28, 2003 | 10:19 PM
Old May 28, 2003 | 10:20 PM
Old May 28, 2003 | 10:21 PM
Old May 28, 2003 | 10:27 PM
more pics sorry i couldnt help myself
Old May 28, 2003 | 10:29 PM
Old May 28, 2003 | 10:30 PM
Old May 29, 2003 | 06:03 AM
Spdfrk1990's Avatar
eb your installation looks like it will go really well.Did ur sfc's come uncoated and u not paint them mdformula.
Old May 29, 2003 | 09:26 AM
ebmiller88's Avatar
Thanks. My SFCs were uncoated and I painted them with POR-15 (www.por-15.com). I HIGHLY recommend using it on any part underneath the car, and I think MD ought to use it before those new SFCs rust away...
LOL...
I'll have more pics of the finished install this afternoon.
Ed
Old May 29, 2003 | 10:26 AM
Spdfrk1990's Avatar
I primed my bare metal spots after i was done then coated them with some rust prevention paint made by SEM.
Old May 29, 2003 | 12:04 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
MdFormula350: In the fourth picture that you posted... is that with or without ground effects installed? It *seems* to me like they're installed, but then again, I've never seen one of these cars without the effects installed.
I just ordered my Spohn SFCs on Monday, and I purposely ordered mine unfinished because I honestly didn't think that anybody would be able to see them without looking underneath the car. But if they're going to be *that* visible, then I might have to reconsider...
Old May 29, 2003 | 12:59 PM
my car is a formula, so no ground effects.
anyway it was at a angle from the floor, you cant really see them if i drive by and u were standing up..
SPOHN SUBFRAME CONNECTORS = :hail: :hail:
Old Jun 2, 2003 | 06:35 AM
ebmiller88's Avatar
Here's pics of my finished install, all painted with POR-15 and purdy.
Old Jun 2, 2003 | 06:36 AM
ebmiller88's Avatar
Area near the cat:
Old Jun 2, 2003 | 06:37 AM
ebmiller88's Avatar
Back by the LCAs:
Old Jun 2, 2003 | 10:09 AM
awesome! :hail: i am just going to spray paint mine
Old Jun 2, 2003 | 01:28 PM
Spdfrk1990's Avatar
awsome install very clean look how does the car feel now
Old Jun 2, 2003 | 03:22 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Hey Ebmiller is that the lincon wedler from like homedepot that sells for like 437.99 or something very close to that? becuz im lookin at the very same welder so i can do some stuff to my car but my big question is do you have to get a dedicated line to run just the welder or will like a regular plug out in the garage work? and is there much of a difference between 110v and 115v? my parents kinda dont want to have a big problem with me like tripping the braker everytime i go to weld so thats why im holding off on gettin it.
Old Jun 3, 2003 | 09:36 AM
ebmiller88's Avatar
Yep, that's the Lincoln Pro Mig 135 and it runs on regular 110-115V house current...you could run the thing in the kitchen if you like. No significant difference between 110 and 115V , just how companies choose to market their products. I only tripped the breaker once and it was because my air compressor, plugged into the same outlet, was running at the time and I fired up the welder. It was a 20A breaker, so no big deal. If you run it out of an outlet my itself I don't think you'll have any problems. These are nice little welders. Go for it!!
Spdfrk1990: I haven't taken the car out of the driveway yet.
Ed
Old Jun 3, 2003 | 09:44 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thanx Eb, i think ill be hittin up homedepot this week.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
darwinprice
17
Oct 11, 2015 11:51 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
