Anyone have a manual on a SBC(Except 305s)? Come in...
Old Feb 15, 2005 | 02:08 PM
firefrombelow's Avatar
Can you explain your setup, and what modifications you had to do?
Old Feb 15, 2005 | 02:40 PM
ede's Avatar
ede
396 and m21 factory set up except blow bell and hurst shifter, but i'm guessing you mean in a 3rd gen f body, that i don't have
Old Feb 15, 2005 | 04:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have a T-56 with my 2-piece RMS 305; used to have a 400 with the T-5 that came in the car (83 model), and then later with a 91 T-5.
Like ede, I've had about a dozen cars over the years with manual transmissions; mostly 4-speeds, about half & half big blocks & small blocks, in the Chevrolets I've had. Even a few other brands besides GM.
What are you trying to find out?
Old Feb 15, 2005 | 05:32 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Chronology is like this:
1983 - 2002: L69 and T5
2002-2005: 350 and T5
2005 - ? : 350 and Super T10
No modifications needed for any of these, but I will be making a set of NASCAR-style shifter rods for the ST10. If you dont know them, heres a pic. They are solid rods, and have heim joints on either end to take all the slack out of the linkage. It will also be getting a Hurst shifter. I've been told that the one for a '63-67 Corvette is what I need?
Attached Thumbnails Anyone have a manual on a SBC(Except 305s)?  Come in...-t10rods4.jpg
Old Feb 16, 2005 | 09:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
350-saginaw 3 spd column shift in my 1980 truck
Old Feb 17, 2005 | 01:28 PM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
Original factory World Class T-5 in my 91 Formula with a damn chattering RAM Kevlar clutch on my 383 SuperRam.
Why are you asking?
Old Feb 17, 2005 | 10:30 PM
brutalform's Avatar
I had a Tremec TKO, Lakewood safety bellhousing, SPEC stage III clutch assembly,with a 10 lb aluminum flywheel. Modifications: the driveshaft has to be shortened, good time to upgrade the u- joints, and to increase the tube size to 3". The Tremec sits in the car differently than a T-5, or 700R4. You can use the spacer blocks that the Tremec dealers provide, or modify your crossmember, so you dont need the spacers. This is a must if you plan on using the Mufflex "Y" pipes as I had. The bellhousing was "dialed in" within the .005 allowable specs. for proper input shaft alignment. (mine was out big time). All this backed a 436 EFI SBC. Now the transmission of choice is a fresh 700R4.
Old Feb 17, 2005 | 11:33 PM
blue_tacos's Avatar
Car: 82 Berlinetta 87 Iroc
Engine: 327
in my 82 berli I have a 327 with the stock 4 sp ****ty saginaw. Only reason why it is probably not blown out is I can't drive my car much cuz i get to many tickets. 404 rwhp on a saginaw will ruin it real quick im sure if you drive it enough
Old Feb 18, 2005 | 08:11 AM
rsn932's Avatar
stock non-World Class T5 from an 87 on an 355 TPI, but I didn't drive it for more than a week before deciding to go HSR. I'm in the middle of installing that right now.
Old Feb 18, 2005 | 10:40 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Im running a manual and auto all in one. Best of both worlds. It down shifts from overdrive to a 1 to 1 ratio when you nail the thrittle to the floor. Feels just like an auto shifting into passing gear. Plus you manually down shift the super t10 for a second gear reduction and its all smiles from there . You dont want to know the amont of mods it took to install.
Old Feb 18, 2005 | 02:57 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
i have a tremec TKO II right now....using stock belhousing and adapter plate
my driveshaft didn't need to be shortened....until i got a moser 12 bolt
im switching up to the tremec 600 soon though
Old Feb 18, 2005 | 03:30 PM
brutalform's Avatar
THATS RIGHT....I goofed. I actually had mine shortened to accommodate the Currie 9in. Not the Tremec. Thanks for bringing that up....
jhawkeye
May 25, 2022 06:33 PM
Terrell351
Jun 13, 2021 01:13 PM
theurge
Aug 21, 2015 12:46 PM
kyleb24
Aug 15, 2015 08:24 AM
