E-brake might as well not be there on 89 PBR setup
Old Dec 9, 2003 | 02:05 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I think the title says it all. I can sit there and pull up on the handle with all my might, and the car will still roll on level ground D. My 86 was firmly planted with the ebrake engaged. Is there a way to remedy this? I was under the impression these utilize a "self-adjusting" cable tensioner? Can I at least get it to hold the car on a hill? Thanks fellas
Will
Old Dec 9, 2003 | 06:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like your calipers are frozen on their sliders.
Mine hold the car on a pretty steep rearwards incline with very little tension on the handle. Yours should do the same if they're working right.
Old Dec 9, 2003 | 04:21 PM
ebmiller88's Avatar
Have you tried getting in the tranny tunnel and adjusting the tensioner? It looks like this. My '89 PBRs hold mine just fine. You may indeed need to rebuild your calipers if this doesn't help. By the way, these brakes do NOT self adjust.
Ed
http://f1.pg.photos.yahoo.com/ph/tar...e+adjuster.jpg
Old Dec 20, 2003 | 09:30 PM
joshwilson3's Avatar
Old Dec 21, 2003 | 02:06 PM
norcalz28's Avatar
I distinctly remember reading somewhere that the tensior on the ebrakes IS self-adjusting. Can anyone shed some light on this??
Will
Old Dec 21, 2003 | 02:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looking at mine, they don't look self-adjusting to me. But I could be wrong.
Have you taken the calipers off and checked to make sure they slide freely on the slides yet?
Old Dec 21, 2003 | 05:19 PM
ebmiller88's Avatar
First off, the PBRs don't adjust themsleves. Second, I forgot a part of this. There's also an adjusting screw in the caliper itself that MAY need to be adjusted to get the piston to hit the pad squarely.
Here's the link to what has been posted by me already with pics too. Read it through and see if it helps any. It should. I searched for "e-brake" and user ebmiller88 in the Brake forum:
https://www.thirdgen.org/techbb2/sho...ghlight=ebrake
Ed
Old Dec 22, 2003 | 03:39 PM
Pat Hall's Avatar
Hello Ed. I'm glad I looked up your old post on how to remedy the ebrake problem with pbr's. I haven't tried adjusting the little allen screw yet. I read about how to adjust everything in my repair manual, but the lack of pictures and a detailed explanation make it hard to understand how everything actually works. I tried adjusting the two nuts on the piece in the tranny tunnel. In fact, I turned it way in. The pads hold nice and tight on the passenger side, but the driver's side can still turn when you put it in drive with the ebrake engaged. You can also see where the ebrake lever on the passenger side isn't extended very far, but it's way extended on the driver's side caliper. If the allen screw adjustment doesn't fix this, the only other thing I can figure is maybe the actuating collar on the driver side caliper is stuck or not working right for some reason. The allen screw thing seems to make sense though, because it looks like the ebrake pushrod is just pushing one side of the brake pad forward, and not doing it nice and parallel. Have to give that a try once some of the damn snow melts around here!
Old Dec 22, 2003 | 06:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The cars with the rear drum brakes are self adjusting, however the cars with the rear disc brakes are not. Norcalz28, if you need the information for adjusting your rear brakes, I have the GM (not haynes or chilton) service manual for the 1989 camaros and can e-mail you the info.
The Trickster!!!!!!!!!!!
Old Dec 22, 2003 | 06:27 PM
Pat Hall's Avatar
Hey Trickster, I would greatly appreciate it if you could shoot me an email with that info in it too while you're at it!
Old Dec 22, 2003 | 10:09 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Pat.
I tried to send it to you and I think I broke the poor e-postmans back. Got another e-mail account somewhere that is a little bigger or has a stronger e-postman?
Old Dec 23, 2003 | 01:54 AM
norcalz28's Avatar
You wouldn't want to part with that manual would ya?
I would be most interested
Will
Old Dec 23, 2003 | 08:44 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, but I will send you the information you need. I hope you have a e-mail account that can hold a large file. about 5 megs.
Well Will, I tried sending it however your mail box is too small. Do you have another e-mail account I could sent it too.
The Trickster!!!!!!!!!!!!!!!
Old Dec 23, 2003 | 08:07 PM
norcalz28's Avatar
Sadly, I don't, but thanks man
Will
Old Dec 23, 2003 | 09:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Don't give up Will, I'm not called "The Trickster" for just my good looks.
Old Dec 23, 2003 | 10:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Don't look now Will, but you have e-mail!!!!!!!!!!!!:lala: :hail: :lala:
Old Dec 23, 2003 | 11:24 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey Pat,
You've got mail!!!!!!!!!!!!!!!
The Trickster!!!!!!!!!!!!!!!!!!!
Old Dec 24, 2003 | 03:30 PM
Pat Hall's Avatar
Originally posted by Trickster
Hey Pat,
Thanks a bunch for sending the info dude! Greatly appreciated! Once I get done with all the fun and joy of the holiday, I'll have to sit down and check it all out.
Old Dec 26, 2003 | 01:06 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
Trickster,
Can you send me that info too! My ebrake doesn't work and I have tried everything mentioned, it's driving me crazy.
Old Dec 26, 2003 | 12:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello 89 Iroc Z,
Your mail man is knocking at the door.
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
