ALDL Pinout?
Old May 20, 2002 | 04:40 PM
dyeager535's Avatar
Car: Which one?
Transmission: 465
ALDL Pinout?
Anyone have a link to an '88 VIN F ALDL pinout? (or can just post the pinout here?) I've got the electrical diagnosis manual, which works great up till now, but doesn't include the ALDL.
My plug was cut, so all I've got are 6 or 7 wires sticking out the back, and only 3 or 4 referenced from the ECM.
Thanks!
Dorian
Old May 21, 2002 | 12:58 PM
Jza's Avatar
Jza
Borrowed from one of Vader's many useful posts:
Old May 21, 2002 | 01:01 PM
86IROCZ's Avatar
Cool Diagram!! All the other one's I've seen only show A, B F and G.
Jza's Avatar
Jza
Oh, obviously on your car, you won't have the airbag, antilock brakes, or 8192 serial pins, so basically H through M won't connect to anything. M "might" be spliced to E, though. I know my 89 doesn't have 8192, but I have continuity from M to E for whatever reason.
Old May 21, 2002 | 01:41 PM
dyeager535's Avatar
Car: Which one?
Transmission: 465
I appreciate that muchly. Figured it would be in amongst the '85/86 wiring diagrams, but its not. Couldn't even find the pinout on the web. Odd, you'd think this would be one of the more common diagrams.
Thanks again,
Dorian
Old May 22, 2002 | 01:57 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
http://www.monte-list.nu/tech/tpi/tpi_wiring.txt
typed that up from my 86 Helms for Dorian today.
The 165 ECM *is* an 8192 ECM isn't it? How can yours just "not" be 8192? I have no 88 or 89 wiring diags, but have heard the M splice to E thing before so it has merit (yeah I know that's "bench racing" w/out the Helms, but so be it)
Hmmm.
Old May 22, 2002 | 10:31 AM
dyeager535's Avatar
Car: Which one?
Transmission: 465
Originally posted by jmd
[url]I have no 88 or 89 wiring diags, but have heard the M splice to E thing before so it has merit (yeah I know that's "bench racing" w/out the Helms, but so be it)
Hmmm.
For anyone following this and still interested, backtracking from the connector the ALDL M and E wires originate from, to ECM, then using the GM diagnostic manual, I was able to find that in '88, authoritatively, the M and E wires are spliced together.
Dorian
Old Aug 16, 2002 | 11:04 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
acroding to my Haynes firebird manuel M&E do connect then go to pin#A8 at the ECM.
a 90-92 car the M pin at the ALDL is the only wire going to the ECM(A8).
InfernalVortex
Apr 20, 2021 11:31 AM
xodus2002
Jul 17, 2020 09:08 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
greenyone
Sep 8, 2015 08:41 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
