v6 tranny to a 305
Old May 30, 2001 | 08:45 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
v6 tranny to a 305
i'm doing the swap real soon and i need to know about the tranny
someone said i can definetly keep my 6 tranny as long as i get a v8 bellhousing and get a custom clutch made (kinda like half of a 6 clutch and half of an 8 clutch put together)
i dont care about the durability
i just need it as a cheap fix until i can upgrade to a T56 in a year or so
any opinions???
oh yeah, its a 5 speed
Old May 30, 2001 | 04:41 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
email jersrjr (jersrjr@msn.com) and ask him about this. He just did it with a 4 speed in his '82. I'm not sure what year you've got (whether it's a hydraulic or mechanical clutch) but you can make it work.
later
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old May 31, 2001 | 06:35 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
A v6 trans will not bolt up to a v8 and the bellhousing is integral with the case of the tranny.
Old May 31, 2001 | 06:36 AM
JoelOl75's Avatar
I better correct myself and say any 60 degree v6 (2.8L, 3.1L, 3.4L) transmission won't bolt up to a v8. A 4.3L v6 trans will but these trans are weaker internally.
Old May 31, 2001 | 07:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Joel, you do understand he's talking about a manual transmission, right?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 1, 2001 | 06:46 AM
JoelOl75's Avatar
Ohh... sorry.
Old Jun 1, 2001 | 07:46 AM
blak92!'s Avatar
The V6 T5 trans will bolt to the V8 bellhousing, but the input splines are less, you would need a different clutch.
Also, because of the numerically higher 3.95 first gear of the V6 T5, torque multiplication is much greater->significantly lowering the torque rating of the trans.
If you decide to install this trans, you will be pulling it out within a week because the internals would be mutilated.
DO NOT even consider using a V6 T5 trans.
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
Old Jun 16, 2001 | 05:44 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
I'm sorry, but I think it all depends on how you drive the vehicle. If you race, then he transmission will die quickly. But a good driver who is careful can make it live long enough to swap the t56 when money allows.
if and when i do a camaro (parents won't let me now) i'll probably do the v6-v8 swap, and run a t56 with 4.10 gears. But don't let the naysayers about the t-5 hold you back. it can be made to work, although you do have to run the stock v6 clutch as it has less splines on the input shaft compared to a v8 t-5. my neighbor is running a v6 t-5 in his 84 camaro and he is using the 9 5/8" clutch behind his 350. he said that it was the biggest he could run. I'm guessing this is because he still has to use a v6 clutch disc.
it's called learning. build something, blow it up, fix it, you learn. how do you learn if you don't do?
Gunsbee
Sep 7, 2015 07:10 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
