posi install
Old Jan 7, 2005 | 10:48 PM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
posi install
i have a GM factory posi carrier that i bought out of a wrecked car that i wanna install into my peg leg rear now. What is involved in doing this? ive never done it before and wanted to know if it was a job i could tackle myself, if not, any of you guys around Grand Rapids MI out there willing to help ?
Old Jan 7, 2005 | 11:15 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
If you have a decent amount of mechanical experience, then you could probably manage it yourself IF you don't have to reshim the pinion. If, however, you install the new posi, and your gear wear pattern sucks, then having someone with differential experience helping you will be necessary.
Either way, you will need an impact to unbolt the old ring gear (remember-left hand threads!), and torque wrench to reinstall it, and also for torquing down the main caps.
Having a drum rear will make pulling the axles easier. Also, be perpared to find that the differential cross shaft retaining bolt/pin is broken (if you like doing burnouts), in which case you will need a new one, along with the extraction tool kit (which is cheap).
Also, you will need new carrier shims because the old cast shims WILL break when you try to reinstall them. You can get a set of trick adjustable shims from ebay for like $20. I have purcheased two sets off ebay, so I know they are there. They are the best thing to happen to differentials since hypoid gears!
Old Jan 8, 2005 | 12:59 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
What extraction kit are you talking about? If there is one, I need it. Mines broke. Where Can I find one?? Here's what mine looked like when I attempted to take my one-wheel peel rear axle out. I gave up and threw it back together :
Sorry about this MonteMan357, My intent isn't to screw up your post, I plan to do exactly what you're doing and ran into the problem described above. I hope your install goes smoother than mine. Good luck with it!!
Old Jan 8, 2005 | 05:23 AM
ede's Avatar
ede
provided you got the correct series carrier all you need to do is swap the ring gear to the replacement carrier check contact pattern and back lash and you're all set. try searching i think someone else ask this same question before.
Old Jan 8, 2005 | 09:43 AM
meeklay812's Avatar
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
MonteMan357...... THAT YOU ZACK!!! HaHa if not I live in Grand Rapids and would be willing to come give ya an extra hand, but I have never done this either, just alot of reading. Good Luck!!
Old Jan 8, 2005 | 11:03 AM
Engine: 5.0 TPI
Yes, there is a removal kit. I got mine from snap-on, but it is made by somebody else, like Lisle or something. It comes in a long plastic tube about 20" long. There is a long semi-flexible drill bit, a threaded insert/guide for the drill bit, an easy out, and instructions. This kit works awsome, that pin will be out in no time.
You can try going to sears, I think the sell it in the tool section. Or you can try napa or autozone or something. Worse comse to worse, I will mail you mine so you can use it, then just mail it back to me when you are done. My email is fisherbody86@hotmail.com. Email me if you need my kit.
Old Jan 8, 2005 | 11:12 AM
Engine: 5.0 TPI
Here is the kit, and a link to read about it.
http://www.skywaytools.com/autopg2.html
Old Jan 8, 2005 | 12:13 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
yes matt its me....figured i might as well join this board since i surf it a lot and theres a lot of smart guys with good info here
Old Jan 8, 2005 | 03:06 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Stay away fom that meeklay812...he's trouble
Old Jan 8, 2005 | 03:29 PM
meeklay812's Avatar
Car: '89 RS
HaHa thanks James! Take a look at the time you made that post..... kinda wierd! BTW I just bought a new rear that I get to pick up next weekend from Chicago. I CANT WAIT! I'm still lookin for a set of rear LS1 brakes, keep your eyes peeled.
Old Jan 8, 2005 | 04:35 PM
Car: 1991 Z28
Engine: 357
Axle/Gears: 3.73:1
dont worry james i know to keep away from that little sticky fingered meeklay. Matt did you decide on a school yet? when you guys going to pick up that rear?
Old Jan 9, 2005 | 12:02 AM
Confuzed1's Avatar
Car: 83Z28 HO
Awesome!! Thanks alot for the link AND the offer! :yes:
Ordering a kit tomorrow if they'll take orders on Sunday!
Old Jan 9, 2005 | 12:15 AM
Confuzed1's Avatar
Car: 83Z28 HO
Ordered!
Old Jan 9, 2005 | 08:37 AM
406TPI's Avatar
Car: 1985 IROC-Z
Hey Matt, change your sig....it's .030 over not .30 over which would be impossible on an SBC. Probably just a type-o
Which rear did you end up buying?
Old Jan 9, 2005 | 11:30 AM
meeklay812's Avatar
Car: '89 RS
HHmmm, never even noticed the .30 over . I bought that rear out of an '85 IROC with an auburn posi and 3.73's. It seemed the general consensus was the 4.11's were way too low of a gear so I bought this one. Now I have to find a set of calipers if i dont get the LS1 brakes. Do you have your new rear and everything back together?
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
