Power slott rotors?
Old May 28, 2002 | 04:31 PM
85zcamaro's Avatar
Power slott rotors?
Are they any good b/c they are only about 110$ ea. and they look pretty descent, i need ne rotors so would they be an improvement?>
Old May 28, 2002 | 06:58 PM
BretD 88GTA's Avatar
Car: Yes...
Transmission: See "Engine"...
They'll definitely look cooler, but that's about it. You won't see much of a performance gain. I'd also shop around some more. $110 each is a little pricey. I paid around $70 each for AutoSpecialty cross-drilled rotors from a local shop.
Old May 28, 2002 | 11:21 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Actually,I noticed an improvement in brake fade.The stock rotors would heat up quickly during hard braking and cause the brakes to be dramatically less effective.But with the new rotors,almost all the brake fade is gone.I would like to step up to some bigger rotors and calipers-the 17's make the rotors look even smaller.
Old May 29, 2002 | 09:56 PM
85zcamaro's Avatar
Hey rspeed
hey,, i love your rotors and wheels!!:hail: Where did you get them and how much did they rotors and wheels cost.. I need some stock replacement rotors and i want one just like the powerslotts, So any help is appreciated! Thanks
Old May 30, 2002 | 01:29 AM
RSpeed's Avatar
Thanks.The rotors came from JCWhitney.I can't remember exactly how much,but I wanna say around $70 ea. And the wheels are from groupawheels.com for $238 ea. for 17x9.
Old May 30, 2002 | 07:07 AM
84LT-4's Avatar
I have had the stainlesteel brakes slotted rotors on the car for about a year. it was the 1le brake upgrade kit came with the slotted rotors , they have a little less fade when you brake hard from higher speeds but in my opnion they are more for looks .
Old May 30, 2002 | 06:42 PM
Jack D's Avatar
I am getting the EBC Rotors and pads. Simlar to powerslots but have slots and dimples. Not drilled. Ill let you know how they work out.
Old Jun 2, 2002 | 12:26 AM
BAK12484's Avatar
Shouldn't you only get slotted rotors if you're racing your car?? I heard the slots are used not to dissipate heat, but to help clean the rotors and ensure a better "bite". So for a daily driver shouldn't you go with cross drilled, or a combo of slotted/drilled ???
Old Jun 2, 2002 | 07:13 PM
AFrikinGoodTime's Avatar
Drilled rotors are great for street cars. They reduce brake fade and allow for offgasing of the pads so they remain in contact with the rotor under higher temps giving the pedal a greater "sweet spot"-better feeling and control of the brake pedal. They do however need to be combined with usually a carbon matrix type pad (higher performance and more friction than a metallic pad). Just be carefull when the brake are cold, the car won't stop well until the pads are warmed up. This usually only takes a block or two. Stillen motorsports in Costa Mesa, Calif. offers mild to wild combo's to choose from. http://www.stillen.com/
Slotted rotors are found more on allout racecars. The drilled rotors can warp or even crack under allout hightemp/ highstress braking conditions on a race track corner after corner. Driving on the street can never in ones best attempt duplicate a track condition and speeds, and are just not necessary for the street.
Old Jun 3, 2002 | 04:50 PM
Kandied91z's Avatar
i have the gm versions on mine and love them, here is an old pick that i had laying around.
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
