location of o2 sensor on 91 camaro 305
Old Dec 11, 2004 | 09:15 AM
cjcland's Avatar
i am getting an error 44 and want to change the o2 sensor only i dont know where it is located can someone please help me
Old Dec 11, 2004 | 09:19 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
drivers side ex. manifold
Old Dec 11, 2004 | 09:29 AM
cjcland's Avatar
i still dont see it
is it down about 1 foot coming strait out towards the outside of the car and by replacing this will it fix the code 44, i recently had the fuel filter changed and it still runs like crap and checked the codes and it came up 44 so I thought i would change the o2 sensor and see if it worked
Old Dec 11, 2004 | 09:55 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Driver side exhaust manifold. I beleive it points forward. You should be able to see it from under the hood but you can't miss it from underneith. It is the only thing that taps in the exhaust manifold. Keep looking, its there unless it fell out.
Old Dec 11, 2004 | 10:21 AM
cjcland's Avatar
is this it
is this the o2 sensor this pictue is to the rear and down a foot or so on drivers side the arrow points towards the front of car
Old Dec 11, 2004 | 10:27 AM
Car: '88 Trans Am
Engine: 5.7L TPI
nope thats not it!follow the ex. manifold to the connection of the drivers side y-pipe,at this point you will see,feel the o2 sensor it has one wire coming from the dr.side motor mount to the sensor
Old Dec 11, 2004 | 10:36 AM
cjcland's Avatar
ok this must be it then
this does have only one wire and point kind of forward at a slight angle towards the fender----and will replacing this fix the code 44 problem ??
Old Dec 11, 2004 | 10:39 AM
Car: '88 Trans Am
Engine: 5.7L TPI
thats it!it looks relatively new but it can still be bad,if the o2 sensor has been bad long enough it can kill the map sensor,dont forget to disconnect the battery before you do your work or the problem may still exist in the ecm.
Old Dec 11, 2004 | 10:41 AM
cjcland's Avatar
will this fix a code 44
so if i change this o2 sensor will it fix the code 44 problem?
Old Dec 11, 2004 | 08:20 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Keep the receipt if it does not fix your code 44. Make sure to disconnect your battery (will erase all codes stored in brain) after you install the new O2 sensor.
Old Dec 11, 2004 | 11:45 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: will this fix a code 44
Only if it was due to the sensor itself. It could also be caused by a short to ground, the motor being lean for an extended period of time, or air finding its way into the exaust stream (probably not as much of a problem with manifolds).
Old Dec 23, 2004 | 11:39 AM
cjcland's Avatar
well i switched it out and i am still having trouble it runs real rough when first starting, surges up and down and then kind of smooths out once warmed up but still a little sluggish so far i have changed the o2 sensor, TPS the brain box and fuel filter and im still having trouble im going to change the coolant temperature sensor next to see if that fixes the problem, probley get flamed to death for saying this but never had much trouble with the 302 in my mustang the camaro has been one thing after another ( still love the car though, just frustrated)
Old Dec 23, 2004 | 12:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What year and type of engine is this? The 8th character from your VIN would help.
Old Dec 23, 2004 | 12:18 PM
cjcland's Avatar
its a 91 rs with a 305 5.0L im pretty sure its a throttle body injection, it has two jets that sit on top and spray directly into the carb. 8th character is an E
Old Dec 23, 2004 | 12:21 PM
five7kid's Avatar
Yes, should be TBI.
You might get more help over on that forum.
Old Jan 3, 2005 | 07:24 AM
cjcland's Avatar
OK Here is a list of all I have done to try in fix this problem
new brain(computer) same chip
TPS
CTS
O2 sensor
air temp sensor
idle controler
fuel filter
new cap and rotor
new plugs and wires
after replacing the plugs and wires and cap and rotor it runs alot better, but its still rough idle at start-up and has a hesitation when you give it gas from a stoplight or even if i am already moving there is hesitation.........im running out of ideas here
Old Jan 3, 2005 | 11:53 AM
CONV Z28's Avatar
Car: 91 Z28 conv
Engine: Scoggin-Dickey Chevrolet TPI 350,MSD,Flowmaster, BBK,edlbrock,Fastchip,24lb svo injectors
Transmission: 700r4 Bowtie stage 3 / 2400 RPM stall converter
Maybe bad head gasget? pull your plugs see if any have a green tint to them.
Old Jan 4, 2005 | 05:11 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Check the TPS and IAC by reading up towards the end of the "new to TBI" sticky. Dimented goes into great detail on adjusting your TPS and IAC. The IAC can cause your car to run like poo if messed with. Does the EGR valve move freely? IS it gummed up? What is your fuel pressure?
Old Jan 7, 2005 | 08:44 PM
cjcland's Avatar
Its Fixed !!!! heres what I did i had a mech shoot some fuel injection treatment directly into the fuel lines to clean the injectors and now it runs like a champ, thank you so much for all the help on this forum and i hope this helps someone else who is having the same problem
Old Feb 22, 2005 | 10:32 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
how much does an o2 sensor cost and where can i find one?
Old Feb 24, 2005 | 08:11 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
From an Auto Electric (speciality) Parts Store, get a Standard Plus, USA made under $25.
Old Feb 24, 2005 | 08:29 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Oxygen (O2) sensor for our cars usually cost between $10 to $20. You should be able to get them at any auto parts store.
Old Feb 24, 2005 | 09:02 PM
BCdawg57's Avatar
k thanks guys
Vintageracer
Sep 24, 2017 12:34 PM
Lbibb
May 5, 2016 12:00 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
