Steel Braided Brake Lines
Old Nov 2, 2003 | 06:47 PM
M84Z28's Avatar
Car: Black 1984 Chevrolet Camaro Z28
Engine: LG4 305
Where is a good place to get steel braided brake line for a 84z28?
Old Nov 2, 2003 | 10:19 PM
z28cdoyle's Avatar
Car: 85 IROC
Transmission: Tremec 5 speed
I would try the usual places; Summit and Jegs.
Old Nov 8, 2003 | 05:48 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I picked up Goodridge for my 82 and love them. I got them through Classis Ind
Old Nov 8, 2003 | 07:44 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
are they pre-bent or just lenghths of straight tube?
Old Nov 9, 2003 | 02:32 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
they are braided stainless steeel HOSES....that replace the rubber lines
Old Nov 9, 2003 | 05:53 PM
joshwilson3's Avatar
Old Nov 9, 2003 | 10:05 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
EAR-28A180 for front disks or EAR-28A190 for 4 wheel disks. I've heard stories on here about the russells and personally I bought the earls because of it and had no trouble with them so far. The install was a breeze for a beginner and they inproved the pedal feel greatly. From someone with them on his car, I'd say get them. They'll probably last longer then your car and the pedals will always feel better.
Old Nov 10, 2003 | 01:20 AM
Old Nov 10, 2003 | 07:24 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
No, no, no and a THOUSAND times NO. I have corrected people a thousand times now. Earl's offers 4 kits for our cars. You need to buy the right one. There are THREE different kits for 4 wheel disc applications.
PN28A300 is for 4-wheel discs where you have Iron front calipers and aluminum PBR rear calipers. This is most often for cars 1989 and after.
PN28A520 is for 4-wheel discs where you have Iron front calipers and iron rear calipers. This is most often for cars pre-1989.
PN28A190 is for 4-wheel discs where you have aluminum PBR front calipers and aluminum PBR rear calipers. This is for 1LEs.
PN28A180 is for front Iron calipers and rear drums.
The 28A190 kit can work on the Iron front calipers also if you follow the modification that I did here ...
https://www.thirdgen.org/techbb2/sho...hreadid=171532
Tim
Old Nov 10, 2003 | 10:44 AM
Old Nov 11, 2003 | 08:26 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
do they have a set that will work with a 4th gen disk rear with the 'old' caliper style (LT1).
Old Feb 5, 2004 | 07:42 PM
chevy8ford's Avatar
Car: 88 Firebird
bftd. What's the difference? Hose length? Fittings? Any specifics? Thanks
Old Feb 6, 2004 | 12:13 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
I got mine from Spohn. I trust Steve a lot more with his descriptions than the ones from Summit. They're kind of lacking on descriptions on the hoses IMHO.
Old Feb 6, 2004 | 05:31 PM
ronterry's Avatar
Car: '94 Corvette
'joshwilson3', the hard line on the drums is actualy better then steel hose. However if you can replace that little section of rubber hose the connects the hard line from the body to the hardline on the axle - that would help.
So you'll probably be looking for a (3) hose kit for front disk/rear drums cars.
Ron
Old Feb 7, 2004 | 07:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This link should provide all the info you require:
http://www.spohn.net/category.cfm?categoryid=1095
JamesC
Old Feb 7, 2004 | 10:16 AM
TRAXION's Avatar
JamesC
Ummmm .... no. That link only provides a place to order. Steve's page has no REAL Earl's part numbers and the pictures are incorrect. The same picture is used for every part. The only thing that link provides is an advertisement to order the correct part through spohn ... when, in fact, if you know the correct part number (as I posted above) you can order from anywhere. That link is further cornfusing because of using the same picture for every part.
Tim
Old Feb 7, 2004 | 10:31 AM
JamesC's Avatar
The only thing that link provides is an advertisement to order the correct part through spohn.
I guess my point was that it made ordering easier, at least in my opinion, because you can order a specific application without knowing a part #--and it is from a board sponsor. That said, any and all info is beneficial.
JamesC
Old Feb 7, 2004 | 12:17 PM
chevy8ford's Avatar
Car: 88 Firebird
So does anyone know what the physical differences are? Between the part numbers?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
