Edelbrock intake and heater valve
Old Mar 24, 2001 | 09:39 AM
EVILFACE's Avatar
Got a few questions for everyone.
I plan on getting a Edelbrock intake for my 305 TBI and probably putting it on myself. Is it as simple as it appears? Does the distributor need to be removed? What's a good set of gaskets to use?
I'll also be putting on some chrome valve covers and want to move the heater valve and direct the heater hoses to the other side of that large black thing that sits above the passenger exhaust manifold, is this all right to do? I'll still be leaving it connected.
Thanx
EVILFACE
88 Camaro
Stock 305 TBI Auto,Flowmaster, Full 3" Exhaust, B&M Megashifter
Runs A Blistering 16.5 @ 81.5 mph
Old Mar 24, 2001 | 05:25 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
The manifold is easy to change really. Get Fel-Pro gaskets. You will have to remove the distributor, just mark it good adn you won't have any problems. Instead of relocating the heater valve, I removed it. I just capped off the pipe the opening on the top of that metal pipe that runs along the passenger side near the manifold, and ran a hose from the manifold's heater hose output to the heater's input. It worked pefectly and there's less garbadge in the way now. You also have to cap off that vaccuum line, no biggie.
Old Mar 24, 2001 | 06:22 PM
snflupigus's Avatar
duke does that screw with your heater controls in the car then?
Old Mar 24, 2001 | 10:16 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
What is the connection that both hoses run to that has that little hose/wire running from it? I thought it ran to the temp quage on the dash
Old Mar 25, 2001 | 12:03 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
The controls work exactly like they did before.
Pukka, that's the heater control valve. the line running from it is a vaccuum line, it controls the valve itself. If you remove the valve, you have to plug the line or you'll have a vaccuum leak whenever you turn the heater on. I just cut mine really short and used a lighter to melt the end closed, pinching it with a pair of pliers. I've had no advers effects, most cars built earlier had it setup without the valve, I just looked at how the heater hoses were on my Suburban and copied that.
The control valve opened and closed to control the coolant flow into the heater core. When the valve is closed, no coolant goes throught the heater core at all,it just circulates back into the radiator, when it's opened it flows through it.
Should I make a tech article about this?
I'm making one right now on how to swap one of these manifolds on, mabye I'll just includ this with it.
Old Mar 25, 2001 | 10:30 AM
EVILFACE's Avatar
Good tip Duke. Do you happen to have a pic of what you did?
EVILFACE
88 Camaro
http://www.evilface.com/evilscamaro.htm
Old Mar 25, 2001 | 05:35 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
I will have a pic soon. I don't have a digital camera, so I have to scan the pictures, which are still on film, which hasn't been used up, so I'll have it soon with the manifold tech articles.
Old Mar 25, 2001 | 06:51 PM
snflupigus's Avatar
so what was the purpose of gm designing them now with that valve? cut incar heat when not wanted?
Old May 24, 2001 | 03:19 PM
Tas's Avatar
Tas
I want to do this heater valve delete thing soon. Will this make the car hotter inside? Can I delete the heater valve and still not have coolant going throught the heater? Then hookup the heater again in the fall?
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 24, 2001 | 04:08 PM
EVILFACE's Avatar
I've got the heater valve removed. I ran a 7 inch hose from the intake to the heatercore on the firewall, then capped the metal heater hose line that runs along the passenger exhaust manifold. The heater works fine and I haven't noticed any extra heat coming into the car.
<img src = "http://www.evilface.com/camaro/engine/capped.jpg">
EVILFACE
88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element
Runs A Blistering 16.5 @ 81.5 mph (due to major tire spin)
Old May 24, 2001 | 04:16 PM
cobrakiller1989's Avatar
While your on the subject, i have an edelbrock TBI manifold for sale in the classifieds for $125 plus shipping. it only has 3,000 miles on it.
Old May 24, 2001 | 07:59 PM
Tas's Avatar
Tas
what kind of cap is that? where would I find it? Hardware store?
Old May 24, 2001 | 08:09 PM
EVILFACE's Avatar
It's one of those "HELP" items in the cooling section at Autozone, and comes in a package of 2 for 1.49. They had about 4 different sizes and the one I chose is the largest they one, fits pretty good.
Old May 24, 2001 | 08:11 PM
Tas's Avatar
Tas
Sweet! I'm tempted to go do it right now I just took my last final today yippeee
thanks
-Tas
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
1985chevydude
Aug 20, 2015 12:29 AM
