Can't turn high beam on
Old Oct 25, 2003 | 10:21 PM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
The only way to turn them on is by lifting the stearing wheel all the way up. How do I fix this?
Old Oct 25, 2003 | 10:32 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
sounds like it is time for a new dimmer switch. you will have to take the wheel off and work your way down the column removing the guts to get to the switch. hardest part is getting the wheel off. i don't think there is any adjustments but i may be wrong.
Old Oct 25, 2003 | 10:46 PM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
dimmer switch? I'm talking about pulling the stick back and turn lights on high
Old Oct 25, 2003 | 10:57 PM
JeffW's Avatar
Engine: 305 tpi LB9
hmm you people in virginia sure talk funny......
lol only kidding
the level on the column you pull to turn high beams on or low beam is called the dimmer switch it is inside the column the lever is attached to it.
Old Oct 25, 2003 | 11:00 PM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
hahaha my bad, that just showed my ignorance.
Ok so what do I do now?
Old Oct 25, 2003 | 11:07 PM
JeffW's Avatar
Engine: 305 tpi LB9
try the search feature on this site for dimmer switch and there should be alot of info on how to check and change if needed.
Old Oct 26, 2003 | 08:50 AM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
there is starting to be more and more VA guys. a kid i know has the same problem with his 92, and my 94 has the same thing. i found out that if i pull down and back they turn on and off fine. i wouldnt wanna go into my steering coloum to start with, and with that air bag i dont even wanna think of messing with
Old Oct 26, 2003 | 12:39 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It's a pain to disassmble the column.
Old Oct 26, 2003 | 12:49 PM
MdFormula350's Avatar
so if the high beams still work heres how to fix it cheap....
my actually stayed on highbeams untill i fixed the switch engaging problem.
you will see all this stuff after u pull the drivers side knee pad and fuse panel stuff. i put my seat all the way back and simply laid on my back starring up at all of this with a light, i tired to move the switch are with the two bolts but the one is very hard to get to and the zip ties were small enough and fit fine, a few zip ties later and some tape to hold them inplace and my highbeams work fine.
excuse the spelling
Old Oct 27, 2003 | 08:43 PM
Red90IROC's Avatar
Car: 1991 Trans Am
Engine: 5L TPI
MdFormula350 - that picture helps... I had a similar problem on my IROC, the headlight dimmer was very hard to operate and sometimes wouldn't work. I took off the knee panel under the dash (5 - 10mm bolts). Turns out my switch was fine. The problem was an extreme amount of friction between the dimmer switch actuator rod and the steering column sleeve. I put a few drops of motor oil on the rod where it was scraping the column - and it's worked fine ever since.
Old Oct 27, 2003 | 10:03 PM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
thanks guys and a shoutout to my boy in chesapeke haha lata
Old Oct 28, 2003 | 12:04 AM
GoonieZ28's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Transmission: ProBuilt 700-R4 & Vigilante Torque Converter
You don't need to remove the steering wheel. Just take off the hush panel, put the steering column up all the way, and move the front seet all the way back. Now all you have to do is lay on your back with your head by the break petal for a little while. No it's not too bad actually. There are three small bolts if I remember right that holds it in place. It may not be broken. You can loosen 2 of the bolts I believe and slide it forwards towards the steering wheel. You will notice there is a rod that goes into it. By moving the dimmer switch closer the the wheel, the rod can more easily push the switch all the way.
I had the same problem you're having. Dimmer switch adjustment was all I needed to do. Good luck.
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
