How much power can the 700R4 handle
Old 10-05-2005, 01:07 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
How much power can the 700R4 handle? Around 400 or so? I am thinking about a Pro-Charger with a 6-8 boost. Right now I am putting out 307 at the crank. The supercharger should bring me over 400. Will I need a new Tranny?
Old 10-05-2005, 09:16 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
If it's your original transmission then I wouldn't expect too much out of it. It might last for a season or so.
Old 10-05-2005, 09:40 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Its only as strong as you build it.
A stock 700R4 behind a stock 305 bites the dust fairly fast. But a good built trans will take 400HP easily.
I would reccomend you either building up the trans you have or getting a new unit built to handle your power range, Your not going to go too far with a stock trans behind a blown engine.
Old 10-06-2005, 07:07 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I am going through the same thing. plus i have been told that a t5 wont cut it if i wanted to go stick shift. is the m6 the same as the t56? what should we do to our 700r4s though. ive got a 350 horse motor and 3.73 gears. i have a shift kit here but it isnt installed yet. what else should i get? stall converter? what size, and what else? would it be more worth it to just buy a t56 instead?
Old 10-06-2005, 09:09 PM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
The 700r4 that I have is suposed to handle 600-650 HP. Had it built locally. Just like the other guy said, there only as strong as you build them...
Old 10-06-2005, 09:22 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
In the end it will probably cost you about the same amount to build equally strong 700R4 and T5's, So really its up to you. Do you like the fun of a stick shift or the consistency of an auto?
Personally im looking into junking my th-350 and going to a built up 700R4. As much as i would love a manual i would rather get more consitency in my shifts.
So...
If they say it will handle xxxHP hold them to it, and if your under that and it blows take it back to them for warranty.
Old 10-06-2005, 09:26 PM
ZZ4 86 Z28's Avatar
i believe i didnt make a typo and say t5...if i did i meant t56.
Old 10-06-2005, 10:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I've had my stock (shiftkit) 90,000 Mile 700R4 behind my 383 for 2 seasons now, runs 12's and still chirps the tires. I'm hopeing I can go another 2 seasons lol
Old 10-07-2005, 04:53 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I built a 700 for Brutalforms 92 Formula last winter. With a horrible tune it made just under 500 hp and just under 600 ft lbs of torque. Nothing inside the trans is tricked out. Minor upgrades and blueprinted unit. Even with 1.6 60' times, it held up well all season. It is our rolling R&D test rans. I am pretty sure it has picked up a minimum of 50 hp and 50 ft lbs since the tune. When we break it, we will post the what's and why's. We actually hope to break it to find the weak links. At least I hope so, I am sure Tom does not . The key to durability, imho, is attention to detail and blueprinting. This takes time, and therefore, cost's money.
Old 10-07-2005, 05:12 PM
ZZ4 86 Z28's Avatar
should i put the shift kit in myself, or have a shop do it. how much should it cost? will it help the amount of power it can handle?
Old 10-07-2005, 05:14 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
B&M kits are easier than transgo to install.
Old 10-07-2005, 05:18 PM
ZZ4 86 Z28's Avatar
o, i got the B&M. but i dont think ive done anything mechanical yet. ive done plenty of body work and painting, a little bit of electronics. but nothing really mechanical yet.
Old 10-07-2005, 05:21 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
B&M kits contain excellent instructions. Follow them to the letter and you will be fine. Dive in.
Old 10-07-2005, 05:52 PM
Car: ws6
Engine: ls1
Transmission: m6
I want to install a 6-speed,but I dont want to slow the car down. GM says the 700R4 is the perfect mate for the 350 engine.
Old 10-07-2005, 06:01 PM
ZZ4 86 Z28's Avatar
how much power can a t5 handle? people say it will not go good with my 350 horse motor. but ive seen 383's with t5s. what if i got a built t5? i dont drive the car hard at all. tell me breaking stories to dissuade me.
stalkier
12-06-2015 11:25 PM
sailtexas186548
08-24-2015 10:11 PM
g.l.mos
08-22-2015 12:02 AM
sreZ28
08-14-2015 07:48 PM
Quick Reply: How much power can the 700R4 handle
