Best for AutoX: Pwr or Manual Steering?
Car: 1986 Z28
Engine: Code "H" LG4
<Double posted>
My PS pump is shot. I'm considering a S-10 conversion.
How would this effect handling used in Autocross?
Manual or rack steering is more precise. So if being 1 inch off 'the line' means alot to you then this might be something you want to look into. But also remember that Camaro's are heavy and depending on how wide your rubber is in front, it might be so hard to turn the car that you cant keep it on the track! The best would be a power rack but that would require some s10/4th gen madness fabrication. Z28Racer (the mod) has alot of info on this. I once thought Manual steering would be no problem but he set me straight hehe.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
PA racing is the only company I know of making the power rack, or even a manual rack, a fairly painless deal, but as fate would have it, their K member that is required doesnt look like it will stand up well to the stress of roadracing, and so far we have nothing from Road Tech along the lines of them making a K member with stock spring perches and A Arms to match, let alone adding a power assist rack setup to the mix.
Trust me, I muscled a 540hp '68 vette with 275/40 17's fr and 335/35 17's rr in autocross for a few years before adding a powersteering unit--it immediately dropped 2-3 secs off my times.
You'll have to work way too hard with a manual rack. Its more for roadracing
Originally posted by Joey1986Z
Z28racer....
you are over my head.....
please lower your altitude......
thanking you in advance.
Z28racer....
Car: '87 Camaro LT
Engine: 355 L98
i drove a 4cyl s10 with a 5spd that had a manual box, even with that it was a pain in the neck to steer at low speeds, like in a parking lot
. it can only be worse in a heavier car with wider tires
. it can only be worse in a heavier car with wider tires Supreme Member
Car: 1992 RS
Engine: 406 Stealth Ram
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
If somebody would like to try a fourth gen steering swap I have a new rack form a 98 ss camaro, tie rod ends, hoses and u-joints sitting in my attic I have over $500 in the parts. I would like to sell them since my wife has redirected my priorites.
Car: 1986 Z28
My former wife started redirecting my priorities. That's why she now has the distinction or EX proceeding the word wife!
When my pwr steering pump went, I had one hell of time trying to steer it (especially in parking lots!). It was pretty hard to turn the wheels lock to lock. I was running 235/60/r15's up front which didn't help either.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
