What do you think of Scat 9000 cranks?
Old Jan 10, 2003 | 08:38 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Looking at which crank I should get for my 383. I have a 350 4-Bolt block...will be using 4340 forged rods, SRP forged pistons....Im not sure if I should go with a Scat 9000 crank...or a 4340 forged crank. I will probably pushing 450-500 horsepower....keeping it under 6500rpm. I am also planning on running a 150-200hp shot of nitrous. I want the engine to survive...but I'd rather put my money else where if the crank will be strong enough for my setup. What do you guys think?
Old Jan 11, 2003 | 06:39 AM
ede's Avatar
ede
i'd buy a forged crank but i wouldn't buy anything from scat if i could help it.
Old Jan 11, 2003 | 09:16 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
If you do dont use a Fluidampr/Streetdampr on it or this will happen
3700lb car running high 12's..As you can see the block broke before the crank..
Daz
Old Jan 11, 2003 | 10:12 AM
mult68's Avatar
ouch...umm..maybe i will get the forged.
Old Jan 11, 2003 | 07:06 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Daz
Daz
was this a Scat Crank, I was thinking about a Scat 9000 for my SBC 400 that will have about 450-500 hp/tq. i read wgere David Vizard was using these same cranks in his motors.
Old Jan 11, 2003 | 07:56 PM
Z_Ghost's Avatar
What ede said.
If I had seen this I would have thumped you today.
Old Jan 11, 2003 | 09:46 PM
mult68's Avatar
haha phil...didnt know you ever read these forums....cool meet today huh?
Old Jan 11, 2003 | 11:18 PM
Z_Ghost's Avatar
Good way to learn lots of stuff about thirdgens and cars in general, I read almost all the boards here.
It was a great turn out, lots of thiregens on a cold day.
Old Jan 11, 2003 | 11:39 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Originally posted by DTL504
Daz
Scat9000..One piece rear seal,external balanced
daz
Old Jan 12, 2003 | 07:57 AM
DTL504's Avatar
I guess I will be buying a Eagle Forge Rotating Assembly.
Thanks for the info Daz.
David
Old May 20, 2003 | 11:22 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
hmmm
dude if ya do go with scat, then make sure to look it over real close, and check for missed burrs in the oiling holes in the throws.... they costed me a 5000 engine, well a rebuild atleast.....
Old May 21, 2003 | 11:46 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Wow! This is the first I have heard of people unhappy with Scat products. What is the problem? Quality control?
Old May 22, 2003 | 02:06 PM
badgta's Avatar
Car: 1991 FORMULA
well
it was burrs..... if you have say ever grinded somthing, and you still have hose peices of metal that is still part of what you grinded but readt to come off......
i washed it down and everything, but they just didn't dislodge.....
i called brian at scat and he said it was my resoncibility for not seeing it and i should have sent it back, i told him it shouldn't be the coustermers responcibility to have to look over their work and he ought to be ashamed of himself.....
phil at flatlander told be it was scats fault and he would pay to have the crank turned and send me new bearings......
i'd get one from them again if i had to, i guess i was trying to just drive home about checking and washing everything down to it's at a point where you can eat of it... this way you know it's right!
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
