TV cable adjustment problem
Old Sep 6, 2005 | 11:51 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Not sure how to adjust it...Under WOT it shifts way to soon, and the shift seems slow and sloppy. If I hold the gear by putting it in 1st then waiting untill I want to shift, it does. Also when coming to a stop the trans clunks down from 2nd to 1st. This is happening now after I switched my throttle body for another one that I ported. It does have more top end HP and low down grunt, but the trans isn't having it. 700-r4 with a GMPP 350 crate in a 92 suburban....
Please advise!
THANKS!!
Old Sep 7, 2005 | 12:21 AM
nidyanazo's Avatar
Also it dosnt shift right at part throttle, like it takes to long, and then does a firm shift.....I'm pretty sure it's out of adjustment....
Old Sep 7, 2005 | 02:18 AM
nidyanazo's Avatar
I looked at the tech articles, and it's not the same to adjust for me. There are 3 cables going to the throttle body, one I know is the throttle, another is the Tv cable, but what it the 2rd one for?
This is pissing me off. It seems like under WOT the TV wont open all the way. Anyone know how to adjust it?
Old Sep 7, 2005 | 02:53 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
i might be able 2 help u out man, i had the same problem. ive only got two lines though. not 3 or whatever. what u do is u press on the bottom one's (tv cable) adjuster. its like a black button u can press on. press it in and move the cable so its end piece is up against the part on the throttle body. then wile still holding it down, open the throttle all the way, let go of the button and let it go back slowly itll click a few times and the end of the cable should be flush (up against) the piece of the throttle body like it should be. because right now its real loose right? if this doesnt help it could be disconnected at the trans.
good luck man!
Old Sep 7, 2005 | 03:28 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
Transmission: 700R4...3.27 posi being installed
the other should be cruise control. Im having the same problem too. My is when i accel it will smoothly shift through 1,2,3,4 but get stuck in 4th at 40 at 1000 rpms. I don't know if you know why mine is doing it let me know.
Old Sep 7, 2005 | 03:31 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
The 3rd cable should be the cruise control cable.
There's 2 ways to adjust the TV cable. The first way is pretty much how 91blue_fire mentioned. Just find the throttle bracket with the TB cable on it, press in the D-shaped button on the TV cable, pull the black cable towards the firewall as far as it will go, and then release the button. Get in the car, and slowly depress the accelerator pedal to WOT. You should hear the TV cable click. At WOT, the cable should be at maximum tension. Test drive and see how the transmission acts.
The second way is to take it to a professional transmission shop and have them adjust the TV cable according to pressure readings from a transmission pressure gauge hooked up to the tranny. I've heard that this method is a lot more accurate.
Old Sep 7, 2005 | 04:28 PM
nidyanazo's Avatar
I got it. It now shifts properly. You actually have to move the cable housing all the way back to the bracket. The "D" shaped button is very hard to press....Atleast on my unit it is. Just took some time to get it right. A good site for info is:
http://www.tvmadeez.com/article/index.php
Old Sep 7, 2005 | 05:49 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
so you need to remove the TV off the bracket and pull it towards the firewall while the tip is still on the throttle????? Because im having trouble in 4th at 40 where it sits at 1000 rpms and i was told to check the TV cable. my old boss did it where he pressed the "d" button and with the engine off he pulled the throttle to WOT and it made it a little better but not as good. should i do it the other way probably get a better result? Let me know thanks
Old Sep 15, 2005 | 12:16 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
t
thanks for the ling mine is now set properly
thank *** that there is a searchg on this site so I don't have to ask the sam ? that others have
thanks again
GB
rick
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
db057
Sep 4, 2015 07:57 AM
