My Ultimate TBI Photos! + A question....
Old Nov 28, 2004 | 06:32 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Just finished the Ultimate TBI mod, but I had a question for you others who have
done it also. What did you use to clean the metal shavings off with? Did you dip the unit in some soultion? What is the safe way to clean it? I was going to use an air compressor after, but wanted to know what do dip it in....Here are some photos, some were before I sanded the edges though....
that was fun.
Old Nov 28, 2004 | 07:44 PM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
dip it into a bucket of carb cleaner
Old Nov 28, 2004 | 07:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It looks good but I would add a radius to the inside lip there. to clean it I just used some compressed air and some good ol carb cleaner. Just make sure there aren't any significant chips in the spring or around the throttle blades.
Make sure to keep carb claner away from the IAC and TPS. I would not submerge it in it at all.
Old Nov 28, 2004 | 07:46 PM
nidyanazo's Avatar
Cool, I got another Question...What is a "cold immersion cleaner"?
Would carb cleaner fit that catagory?
Old Nov 28, 2004 | 07:52 PM
nidyanazo's Avatar
Thanks Shifty I'll work on that radius and post some more pics....
btw. Is WD-40 Ok? I don't have any carb cleaner...I could get some though...
Old Nov 28, 2004 | 08:12 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
You'd probably be OK with WD-40 (what can't it do, right ), but I'd just go ahead and get some carb cleaner. Once you get some you'll wonder how you went without it.
Old Nov 29, 2004 | 03:55 AM
nidyanazo's Avatar
Now I just need to get some super-fine grit sandpaper to finish it off.
:lala:
Old Nov 29, 2004 | 05:34 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Looks much much better now
Bubbajones_ya
Jul 6, 2024 08:32 PM
Linson
Sep 21, 2015 01:08 PM
david068513
Sep 18, 2015 10:36 AM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
