Where Is VATS Module
Old Nov 12, 2003 | 11:22 PM
John V's Avatar
Car: 89 IROC, Convertable
Transmission: Automatic
Help Please
I have a 89 IROC convertable and have been told by several people that I have VATS. My problem is I bought it at an auction and it came without keys. When I tried to order new keys from a local locksmith they got a key code from GM. They looked it up and found no VATS code for it. The locksmith said they can make me a key for the ignition and door locks but they need the VATS code and say it is a number between 1 and 15. Does anyone know where I can find the VATS module to make sure I have VATS and if I do where I can find the code?
Thank You
John V.
Thanks for the help, Problem found and solved
Old Nov 12, 2003 | 11:57 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Module
It's on the right side behind the dash just above where your feet would be, right next to the ECM. It's a little black box about 3'X5" and it says "pass key" on it.
Old Nov 14, 2003 | 07:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you have VATS, there will be two white wires wrapped in orange coming from the steering column and connecting to two wires (purple/yellow & black/white) Unless someone has previously bypassed it. And as dyno don has mentioned, the VATS control module is mounted behind the dash just below the center air vents.
The Trickster!!!!!!!!!!!!
Old Nov 20, 2003 | 05:41 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
whats the easiest way to bypass VATS? cause its screwing up my gauges since i converted the original motor to a carb..my gauges dont work unless my door is open or unless you hold the key for like 30 seconds before u start it
Old Nov 21, 2003 | 07:23 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can have the VATS disabled in the eprom chip, however what you are describing does not appear to be VATS related.
Old Nov 21, 2003 | 09:11 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
theres no computer trickster
Old Nov 21, 2003 | 09:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Then you shouldn't worry about bypassing VATS since you have already done it by removing the computer. The only two items affected by VATS through the computer was the starter enable relay and the fuel injectors. Since you now have a carburator instead of fuel injectors, you can rule them out.
The Trickster!!!!!!!!!!!!!
Old Nov 22, 2003 | 11:04 AM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
hmmm...well..thats odd..lol...any ideas on what it could be?
Old Nov 22, 2003 | 11:39 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You might want to go thru and check your wiring harness to make sure everything is wired up properly. Did you change out the wiring harness when you converted over to a carburator or did you simply re-route the existing wire harness? Another thought, did you remove the starter enable relay from the starter circuit?
Old Nov 22, 2003 | 03:05 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
we used the original wiring harness from the TBI...not all of it..maybe like 20 % that we needed
Old Nov 22, 2003 | 03:12 PM
onebinky's Avatar
sounds like you have a bad ground behind the dash somewhere, and when you open your door it is sourcing ground through the door pin. You should have something like 3 ground locations behind the dash.
Matt
Old Nov 22, 2003 | 06:09 PM
slammnmini's Avatar
Car: 91 RS
Engine: Carb 350
ahhhhhh yes this would make alot of sense...
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
