VATS bypass module
Old Apr 9, 2005 | 01:23 PM
91rs5.0's Avatar
Car: 91 RS (Black, T-top)
Engine: 5.0
Transmission: 5-speed
VATS bypass module
I found this on ebay http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true . Seems like a good alternative to having a pcm reprogrammed.
Old Apr 9, 2005 | 09:01 PM
TexasLT1's Avatar
Car: '92 RS
thanks, but its been posted plenty of times before.
Old Apr 9, 2005 | 09:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Why not just get the equipment to program the computer yourself? If your going through the trouble to swap in an LT1 or LS1, surely you will get the bug sooner or later to do some "tweaking" to the VE or spark, especially if you do heads/cam. I bought HP Tuners for my LS1 well before I ever installed the engine. I knew I was going to tune it, so modifying the VATS, turning off rear HO2S codes and disabling CAGS was an added bonus.
Old Apr 10, 2005 | 03:49 PM
TexasLT1's Avatar
Car: '92 RS
Obviously that would be the most intelligent option for most people, but then again, if its cost $100 extra up front, how many people on this board will pay it?
Old Apr 10, 2005 | 07:10 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
that depends on if there is any equipment that CAN delete the function.
A bcm w/proper vats bypass resistors could work, the item in the like worked for me before I deployed and now have some electrical gremlimsto track down, or pay $500 for hp tuners to it, becasue teh beta v6 f-dofy program doesn't have it yet.
Old Apr 11, 2005 | 12:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Instead of trying to retrofit a BCM, I just used the stock thirdgen VATS module. I don't know about LT1 PCMs and there tuners, but w/ my LS1, I can choose between Serial theft signal, PWM theft signal, or just turn it off.
I think if your in a time crunch or financial bind, those modules would be the way to go, just don't think they are the only way.
I also noticed they have Tachometer modules at half of what I paid from Dakota Digital. If they are just as good as the SGI-8, then thats a good buy as well.
Old Apr 11, 2005 | 10:14 PM
TexasLT1's Avatar
Car: '92 RS
not quite as easy to do with LT1's. to do the swap correctly and keep VATS, you have to replace the VATS module with a new one so that it can learn the key pellet value.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
