Anybody with a Vortech have a custom 8 rib crank pully made?
Old Aug 10, 2001 | 07:50 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
I want to get one built with an underdrive on the accesory side and 8 rib on the supercharger side. Possibly a 10 rib. Any body done this?
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04
on Drag Radials
Old Aug 11, 2001 | 06:29 AM
PROCHARGED89Z's Avatar
I dont have any info for you but If you are going with custom pullys,ASP in TX is the best bar none.They made me a crank pully 1/8 shorter than stock to keep my pullys in line with my crank trigger mounted behind it and it was so dead on,excellent product.They deal with Vortech pullys all the time as they make many for the mustang crowd,Check em out
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Aug 11, 2001 | 07:44 AM
Guido's Avatar
Car: 2000 Trans Am
I had ASP make me some 8 rib pullies. It is 8 rib. I dont think you could fit a 10 rib on there. It is VERY tight on the top.
It cost me about $400+ and took over 6 weeks to get done since it was one off and not part of their normal manufacturing. That sucked.
Right now, I am fighting belt slip problems. I cannot keep the bracket from flexing under boost. Ive never thrown a belt off. But is slips like a ****.
I am in provess of building a brace for it and will have photos of that soon. My crank pulley is 1 piece with two sections on it. 6 rib for the accessory and 8 rib for the blower. its 7.5" dia (stock) and the blower pulley is 2.95".
I would MOST HIGHLY advise a brace of some sort if you are going to an 8 rib or larger. The bracket vortech supllies cant handle anything more than 6 in my opinion since its hanging out and is a cantilevered (sp?) load on it.
Here are some photos of my setup.
Good luck. If any questions ask.
-86 IROC
11.31 @ 120.2 mph
-=ICON Motorsports=-
Old Aug 13, 2001 | 06:50 AM
Wow thanks for the pictures and the info. I actually never even thought about the bracket flexing. You think the belt is sliping because of this?
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04
on Drag Radials
Old Aug 13, 2001 | 09:52 AM
Guido's Avatar
Car: 2000 Trans Am
Im almost positive.
Ive tried it tight. Ive tried it not so tight. Ive tried a new belt. That actually didnt help ANY at all. lol
That pic with the ribs removed was the belt Ive gotten more boost with. lol
-86 IROC
11.31 @ 120.2 mph
Old Aug 14, 2001 | 06:50 AM
I have the same problem with my 6 rib. I was using a 3.33 SC pully, up from the stock 3.48, with the stock crank pully, and I was getting 10lbs of boost. I figured I would get more boost with a 3.12 pully. Not happening. I can't even get more then 8lbs now.
I figure with the limited area of the 6 rib, as I got smaller in diameter, I lost even more surface area. I actually thought an 8 rib would be better. Did you try a 3.125 pully? You might get some more boost. A 10 rib would do the trick if we can just fit in there. I think I'm going back to the 3.33 pully for now and get my boost back. Thanks for all your help.
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04
on Drag Radials
Old Aug 14, 2001 | 07:31 AM
Guido's Avatar
Car: 2000 Trans Am
Man, 10 ribs would be pushing it i think to get a radiator hose in there. Unless you could build another bracket that lowered the vortech further towards the ground.
Also, the sway bar gets really close when your down that low.
I have not tried another pulley. It costs too much and takes too long for me. Im planning on selling my Vortech and taking on another project this winter.
Old Aug 15, 2001 | 06:39 AM
I hear a turbo spooling in your future.
Come on guys anybody else with a custom 8 rib pully?
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04
on Drag Radials
[This message has been edited by '91 Formula (edited August 18, 2001).]
Old Aug 18, 2001 | 10:07 PM
ttt
Old Sep 6, 2001 | 08:55 PM
Ordered my custom 8 rib crank pully and 3.33" sc pully. With this combo I should see about 47,000 impeller speed at my shift point. Amount of boost? We shall see.
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
Old Sep 9, 2001 | 12:13 AM
superstreet's Avatar
If you want to go to a wider belt,(10 rib or 12 rib),I cut off the top radiator outlet and TIG'ed a block-off plate then took a hole saw to the side of the radiator and TIG'ed in a 1 1/2" size tube, 90* elbow to let the hose snug right up against the engine side of the radiator.
Old Oct 23, 2012 | 11:40 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Re: Anybody with a Vortech have a custom 8 rib crank pully made?
i know this is a super old post, but anyone have any info still on how the 8 rib crank pulley worked out and where to buy?
Old Nov 21, 2012 | 10:44 PM
ervin's Avatar
the smaller the pulley ,the less contact surface.Anything 3'' and under not good idea.I do have question.What programming are you f body guys using with super chargers.I want to inject my 177 wieand 377 jimmy.I use a 730 ecu my vette.
Old Nov 23, 2012 | 04:27 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
cog drive,the rest..6 rib
Old Nov 13, 2013 | 03:10 PM
Car: 1987 GTA
can you provide more info on your cog drive? where did you get it, especially the crank pulley...
Old May 9, 2014 | 01:19 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
http://www.cbrperformanceproducts.co...rib8.65ply.htm
Might be able to use this new 8.65 pulley made for prochargers, or their 7.65 pulley. Might have to shim it to get either to line up.
Old May 9, 2014 | 01:32 PM
Car: 1987 GTA
great post.. I found something similar and I am trying to make it all work! ill post pics
Jeremys87
Jul 14, 2022 09:08 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
