Picture of a Stealth Ram in a 92 Camaro
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here's a picture that Doug Flynn emailed to me. It's a polished stealth ram installed into an otherwise bone stock 92 Camaro L98.
Car: Death Mobile
Engine: 666 c.i.
Originally posted by Z_Ghost
I think if you slam the hood a few times it will shut, it looks good though.
It would be nice to know how well it runs.
The hood closes and doesn't rub even under engine torque. That was the whole point to this project. And for those looking for power numbers, that's all listed in another post.
Guest
Posts: n/a
Originally posted by 86305
I know how much the fuel rails and intake cost. How much is the plenum and the throttle body.
Car: '87 Z
Engine: 355 in the works
So this will fit without any mods? I can just put it on like swaping out a new base and runners(except of course this has a new plenum)? Would it happen to work on an '87 LB9 with MAF?
Do the fuel rails come with it, too? If not, how much are they?
I'm guessing since the MAP sensor's hanging loose out in the middle of nowhere that the stealthram has no provisions for mounting it. Not a big deal. You could just get a MAP bracket from a TBI car and maybe extend the wires.
Hey guys,
Here's the deal,
Here are the parts we needed to install this.
-Used a 85 Camaro Carbureted upper radiator hose (Dayco 71028) (trimmed the ends back)
- Use a std. small block Chevy waterneck (Mr. Gasket PN 2661)
-Two 1/4" x 1/8"NPT straight barb fittings (rear of intake, MAP sensor and other items, I run only one line to MAP)
-One 3/8" x 3/8" NPT straight barb fitting (rear of intake other vacuum items)
-One 3/8" x 3/8" NPT 90 deg. barb (goes under plenum, used for brake booster)
- 2 feet 1/4" vacuum hose
- 2 feet 3/8" vacuum hose
- (1) 5/16" compression fitting to -6 male AN
- (1) 3/8" compression fitting to -6 male AN
- (2) 3-1/2 foot -6 line with female hose ends. Goes from inlet and outlet to fuel stock fuel lines which are cut from underneath car, the two compression fittings are installed on the stock fuel line.
- (3) 1/4" vacuum plugs for EGR solenoid and throttle body
- (1) large clamp
All the vacuum ports are machined into the plenum. The current lowers don't have the late style center bolts machined, but I am getting future ones machined correctly to fit both. Can't say when for sure. Used the stock air inlet.
You lose EGR and we didn't hook the coolant to the throttle body. Need to use the small cap GM HEI. Coil mounted with stock bracket in stock location.
Didn't have to modify any wiring.
Fit pretty good I thought.
Here's the deal,
- (1) large clamp
Car: '87 Z
Would the stealth ram be TOO much intake for a 305 TPI? Or is it as always, as long as I match it with other components for that RPM range(heads, cam, etc.) I'll be ok? It looks like an absolute KILLER deal for the price... I'm tired of seeing super ram and mini ram raping with prices
If this comes out for centerbolt style, I will love holley forever, givin the power back to the people and their cars - where it belongs :rockon:
If this comes out for centerbolt style, I will love holley forever, givin the power back to the people and their cars - where it belongs :rockon: Thread Starter
Originally posted by camaro-mayhem
now lets see a dyno
now lets see a dyno
Originally posted by Jim85IROC
Dude... go read a post or 2. There's a stealth ram post or 2 or 10 already that have dyno numbers from a bone stock L98.
9192camaro
16
Feb 3, 2019 12:21 AM
Linson
Aug 21, 2015 02:12 PM
L98GTA87
Aug 11, 2015 06:55 PM
