two 12"s with no power!!!
Old Jul 24, 2002 | 04:51 AM
SilverSub122's Avatar
i have 2 JL Audio 12" w0 @ 8 ohms and i was wondering what kind of amp i should get to power them. i was running a crossfire 4x100 but it broke so im in the market for a new amp. ideas?
Old Jul 24, 2002 | 11:34 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
the JBL BP1200.1 is a nice amp and it is only like $270.
Brian
Old Jul 24, 2002 | 01:37 PM
caleb's Avatar
Car: 89' Iroc
**empty**
caleb's Avatar
Car: 89' Iroc
the JBL 1200.1 will kill those subs they are only rated @ 125 RMS each, since the JBL powervavle amps are mono they only have one hook up wheich mean that you'll probably run in parallell, so if you got the JBL600.1 that would be the perfect amp
it puts out:
300x1 @ 4ohms and **This is where you would be if you wired in parralell giving them 150 each which they can handle**
600x1 @ 2ohms
Old Jul 24, 2002 | 02:35 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Those JL's only take 125 rms? That is pretty crazy, cause dont the hit like a *****? I might have to change my thinking over to JL.
Brian
Old Jul 24, 2002 | 04:21 PM
Polecat's Avatar
The W0's are really low powered, effecient woofers. You need an amp that will do most power at a 4 ohm mono load.
Something in the 125-130x2 area......I can get a Kicker IX1302 for about $175 shipped to you if interested.
Stereo, 130x2 and bridged is 400 watts into a 4 ohm load.Has a built in crossover and EQ as well.
Old Jul 25, 2002 | 04:59 AM
yeah those 12s will shake the paint off my car of the right song is on. that amp sounds interesting, im going to see what kinds of prices i can find at the local car stereo shops, but i will keep that one in mind, thanks.
Old Jul 25, 2002 | 02:11 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I've got 2-JL 10W-0's rated also rated at 125 rms. I'm feeding them 200 watts rms without any problems. I'm running a PPI Powerclass 50x4 that I picked up on Ebay for about $250. You'd probably be better off running a 2-channel amp though because of your 8 ohm voice coils.
Old Jul 25, 2002 | 02:15 PM
Polecat's Avatar
two channel amp wouldn't play a role, just need an amp that does most power into a 4 ohm mono load......
Old Jul 27, 2002 | 12:06 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
really now
I have sony xplod subs, the ones made in 2000. They are rated for 140 watts rms, I am feeing them 500Rms x 1 @ 2Ohm With NO problems. I just have my gain down all the way. And no, this isnt a cheap amp, Its a Concept cc-1002 that was $800 Canadian when I bought it new.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
