Stock subs in Firebird
Old Nov 18, 2002 | 12:42 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I found these at the junkyard in a 8x Firebird... have AC Delco stamps on them, so what is it? There is a 4x6" speaker on top and a 4" speaker. Please email me if you know!
Old Nov 18, 2002 | 12:44 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Almost forgot, these were where the 6x9's go. Here's a back pic:
Old Nov 18, 2002 | 01:59 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
yup. Every GTA had them.
Old Nov 18, 2002 | 07:56 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Oh...
D'oh! Thought I had something good there!
Old Nov 18, 2002 | 08:32 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Really? I did not know that I had them back there. I thought I only had 6X9s. Cool
Brian
Old Nov 19, 2002 | 01:32 AM
WS6_355_TPI's Avatar
I have them and I dont have a GTA.
I also checked with a buddy of mine with a GTA... doesnt havem.
Maybe ours got mixed up at the factory
Old Nov 19, 2002 | 09:35 AM
Jim85IROC's Avatar
Apparently I'm wrong.
Does your buddy have an 87? This may have started in 88, I'm not sure. It's also possible that it was an option, but I didn't think it was. My GTA has the gain control slider on the dashboard to control the output level, which is part of the same system.
This may have only been part of the same system that used the steering wheel controls, which obviously didn't exist in 87. I suppose that in 90-92 models with the airbag wheel the system may have changed too.
Old Nov 20, 2002 | 07:10 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I got a '86 TA parts car with the gain switch. It must have been an option.
Old Nov 21, 2002 | 02:59 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
it was an option, my '84 T/A had those. I threw them in the trash. and mounted 6x9"s on the cargo cover. the amp that powers the subs is under the glove box area, or where it would be under the dash. it's probably a 3 watt system and sounds like A$$. the only GM system half decent is the "monsoon" system in the fourthgens, I hate factory systems....they never sound right.
Old Nov 21, 2002 | 06:05 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
my doesn't have them. In fact, if you're interested in selling those, let me know.
Old Nov 21, 2002 | 06:37 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
Definetly was an option!!
Old Nov 21, 2002 | 09:40 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
according to the gta source page the sub system in the gtas stop before 89 due to a change in wiring harness. it does not mention (that i know of anyways) when the option first appeared in gtas or any other kind of firebird.
it was not on the other hand "standard equipment" for gtas. only about 4000 or so gtas in 87-89 received the sub system (reportedly only 3 in 89). if anyone was wandering thats about 20-25% of 87s and 88s. obviously much less for 89s. i have no clue as to the numbers for other firebirds but im guessing they are even less than gtas considering the intended luxery of the gta.
jacob
p.s. oh, and those subs were powered by a seperate 30 watt amp by the way.
Old Nov 25, 2002 | 07:41 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I have the same speaker set up in my '86 T/A. I have replaced the 4x6's but have had a hard time finding replacement 4" subs. I like my car to look stock but have a little "umph" to it.
The 4" subs have a "bostwick" logo on them, but I don't remember seeing any like that. I think Best Buy may sell them although I haven't been there in awhile.
I also have the slider "gain" control **** which still works, but the subs are shot. I was trying to find out which under console unit is actually the amp but I am not sure which unit it is. There is a blue box on the plastic slate, but I can't take it out.
Anyone know?
Old Nov 25, 2002 | 03:47 PM
mudaholic's Avatar
nobody makes 4" subs because thats stupid. rockford fosgate makes 6.75" true subwoofers, although personally im quite skeptical of them.. has anybody heard these?
anyway, if you're looking to keep a stock 4" 'subwoofer' back there, you can pick up a 4" woofer from somewhere like radioshack.. you'd be better off replacing the whole thing with some 6x9s tho, you'll get better sound and bass
Old Nov 26, 2002 | 07:02 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Negs on the 6x9's. The 4x6's really sound great and I'm not looking to advertise my arrival five blocks before I get there. I'm 38 years old and tend to like the music just loud enough for me, not the car next to me. That's for you younger guys.
Anyhoo, I tried radio shack and they didn't have them either. They only had a dual-cone set up. I may try Best Buy or Circuit City when I get back to the US. The kicker is, that when I put in a non-stock head unit the subs will not work. So I have to go back to a stock unit. They are okay, the one that I have is a tape deck and the deck is made by Blaupunkt. I would like to replace it with a 4th gen CD head unit but I'm not sure about the wiring pattern and if it will drive the subs.
I intend to place a small amp in the T/A, that will run the 4x6's and the small subs.
Probably just a 175-300 watt one will will be enough.
Old Dec 19, 2002 | 09:56 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Try Crutchfield, they have 4" speakers with nice ranges. I don't know if you'll ever find another "sub" though.
Old Dec 20, 2002 | 03:52 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
no company makes 4" subs. you wont even find pc speaker setups with that small a sub. 4" is way too small to be able to produce midbass, let alone bass. 6x9s arent loud. people who crank their systems are. your best bet would be to put in a decent set of 6x9s (i think kicker makes a set of 6x9 "subs") or a set of coax speakers back there. plus there is a "fader" on radios for a reason....
Old Dec 20, 2002 | 04:22 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The only way i know of to get a sorta 4" sub, would be a component set that uses 4" speaks, and then they're still not really subs.......
Old Dec 22, 2002 | 03:51 AM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
UQ7 RPO Option BTW my 85 trans am has them
Old Dec 22, 2002 | 11:52 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yep, I have a set of these too in my camaro. (NOT stock, BTW, from a firebird parts car that had the performance sound option)
I have a pair of rockford fosgates in them, I will grab a picture of them a little later on.
Old Dec 25, 2002 | 10:33 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
tamu130:
Where is the 30 watt amp located? I have the same option and i think either one speaker is bad or the amp is bad.
Old Dec 25, 2002 | 10:42 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
Originally posted by Project_1986_TA
tamu130:
no clue!! sorry but i got that info from the gta source page..... www.gtasourcepage.com . i think thats it. if you go there, you can probably ask the guy that runs it. he might know or could tell you who to ask. now that i think about it, its probably under the dash somewhere but i dont have a gta or anything that i can go look at to find out.
good luck,
jacob
Old Dec 27, 2002 | 07:17 PM
JT 85 TA 305's Avatar
4"?
I have the same setup in my 85' TA and I thought that the bottom speakers were around 5" or 5.25" but I could be wrong. Anyone know how to get this setup to work using the slider switch with an after market head unit?
Old Jan 1, 2003 | 10:40 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
they are called subs by gm. they are actually producing mid bass. there are several company's out there that produce mid bass 4 in. you just have to look for them. you could probably put 5.25 components in there, but get some with mid bass specs.
thanks
anthony
Old Jan 2, 2003 | 12:19 AM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
Ya, isnt the option called ESR (Extended Sound Range)?
My brother's friend's IROC has that logo on his dash and he has those speakers too. Look into that peoples...
Old Jan 2, 2003 | 09:29 PM
@ZZKKER's Avatar
the ers just has better speakers in the stock places ( ie- the 6x9's have bigger spyders and magnets, and a round surround as to the dipped in half moon type, and the 4x6's have bigger spyders and magnets also.) but the speakers are still the same size as the normal stereo. only the firebirds got that round 4" / 4x6 housing in the back. that was the equivilant of the bose system in the camaros.
thanks
anthony
Old Jan 29, 2006 | 02:23 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Does anyone have any pics of their modified speaker boxes with aftermarket speakers? I just picked up a stock set of boxes off eBay for like 30 bucks, the stock speakers look decent, but was wanting to upgrade. And yes, the speaker diameter measures 5" with kind of odball mounting tabs...I believe that the ported enclosure with this 5" mid bass would compliment the soundstage better than 6x6's just "hanging out" using the sheetmetal of the sail panels and rear quarter as an enclosure...besides, the 2 2" rockford p2's in the well give me the lows that I'm wanting, I'm looking for a nice hitting mid bass to round out the overall sound...so any pics would be appreciated....rock on guys...thirdgen all the way!
Old Jan 29, 2006 | 05:33 PM
tamu130's Avatar
Car: '88 GTA
Engine: TPI 350
Transmission: auto
wow... this is quite an old post here. i dont even remember it. you cant blame me though, i posted on it over 3 years ago.
jake
p.s. i dont even drive a third gen anymore. im rolling a 2000 ws6 now
Old Feb 15, 2006 | 10:40 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
haha I started this post how many years ago?
Old Feb 15, 2006 | 12:14 PM
@ZZKKER's Avatar
too many. So when are you going to get back into f-body ownership again?
Old Feb 15, 2006 | 12:36 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Soon as I can! I really miss driving one, but driving my other cars has it's good points too!
toronto formula
Nov 10, 2015 06:17 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Linson
Aug 21, 2015 02:12 PM
Randomtask2
Aug 13, 2015 01:57 AM
