FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
9 Bolt Rearend Information
Old Feb 2, 2003 | 03:24 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Everything you ever wanted to know about 9 bolts!
Link to new updated post:
https://www.thirdgen.org/techbb2/sho...hreadid=239666
Old Feb 20, 2003 | 03:46 PM
SIMON HOLTBY's Avatar
Wow, lots of useful information there. Thanks for taking the time to give so much info.
Any idea what model Vauxhall's had the axle fitted?
I changed the wheel bearings some time ago and there still seems too much endplay. You can hear a 'clonk' with the rear raised from the ground when you pull/push the wheel. There seems to be no adjustment on the rear bearings unlike the front ones. Any ideas?
Simon
Old Feb 20, 2003 | 04:23 PM
drain89's Avatar
No but I found on a jensen-healey site that they used the rear in they're vehicles and they listed a vauxhall part number for service parts for the rears. I'd love for somebody in the UK to find out more about parts availablity on various models (hint, hint, hint). I've had basically no luck with Australian sources or vendors so maybe one of you guys can help. Here's a link to the site with the Jensen info: http://www.web-masters.com/gms/rear_axle.html
NOTICE that that diff carrier is a 2 pinion design, not the better 4 pinion design used in our cars. But it's a good lead.
As for your endplay, I'd check that the bearing retainers are pressed on far enough or that the axle splines or side gear splines aren't excessively worn. Miles (88427camaro) is VERY wise of these rears so I'd definately ask him.
Good Luck!
Draino
Old Feb 20, 2003 | 05:46 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
draino, ok heres a question for ya, if i have a posi carrier with a 2.77 gear on it, and i have a 3.27 gear set. will the 3.27's (or 3.45's) fit on the 2.77 carrier. or did they have different series like in a ten bolt?
Old Feb 20, 2003 | 07:27 PM
drain89's Avatar
No they won't work. Just like most other rears they are a different series. The 2.77 and 3.08 use a different carrier than the 3.27, 3.45, & 3.70 gears that were available in our cars and 3.23, 3.73, 3.90, and 4.10 gears available at www.diffsolutions.com. As far as I know Miles is the only vendor working on offering a ring gear spacer but I don't believe it's available yet.
Good Luck!
Draino
Old Feb 20, 2003 | 07:47 PM
pskel350's Avatar
Good Luck!
Draino
I am also interested it the spacer, so i emailed Miles a few weeks ago and said that the spacer should be availble late Feb. or early March.
Old Feb 23, 2003 | 04:44 AM
drain,
Yes, I'll see what I can find out about UK parts availability for these axles. Whats the deal are you wanting to source parts from the UK?
Simon
Old Feb 23, 2003 | 08:45 AM
drain89's Avatar
Bingo
Old Feb 24, 2003 | 12:06 PM
Drain,
I have e-mailed a couple of guys with Jensen Healeys to see if they can help. I have printed out info from that link to a Jensen Healey site you quoted earlier and will take it to a Vauxhall garage when I get time to see if the part numbers mean anything to them.
What parts specifically are you after that you cannot get in the US? Have you contacted the manufacturers in Australia for details of distributors?
Simon
Old Feb 24, 2003 | 09:02 PM
drain89's Avatar
I'll probably buy a 4.10, or preferrably 3.90 ring and pinon set.
Instead of paying the price for 9 bolt parts, I'd rather find a used dana 44.
Old Feb 25, 2003 | 12:18 PM
Eightyninef's Avatar
thanks for mentioning my name.
Now I am offering 2 different methods of selling shims to tighten your posi carrier.
first is by individual shim. If you know what thickness you need, I can get pratically any thickness desired.
However most people have no idea, and you really can't decide until you pull it apart, so I decided the best way is just to sell an assortment of like 15 shims. Then you can play with them and see what fits best according to how much wear your cones and carrier has.
So please contact me directly for pricing and availability info.
Larry
Old Apr 1, 2003 | 02:12 PM
I have had no luck sourcing parts for our axles.
Sorry
Simon
Old Apr 2, 2003 | 04:49 AM
ausrs's Avatar
ever considered sending miles an email ??????????? maybe he could hook you up with his supplier in aus (just a thought )
at least that would mean gears could be shipped direct to uk instead !
Old Apr 2, 2003 | 11:59 AM
drain89's Avatar
Thanks for checking Simon. I had no luck in finding used gears for a good price from aus either? Since I'm in the states I'm gonna go with miles. I agree with ausrs though, I'd call miles and see if he can hook you up with his supplier that way you can get them as reasonably as you can in the UK.
Old Apr 2, 2003 | 01:48 PM
I'm not after any parts at the moment and only will be if something goes wrong. Thanks though.
From experience of shipping parts from the US to the UK it is very expensive you have to consider brokerage charges, duty charge, sales tax charge and the cost of shipping itself. Returning goods is not an economical option if there is a problem. I'm not sure if all these apply to you but it is worth considering if its all worth it or swopping to an axle with easy parts availability in the US is better.
I know very little about axles but I see the name Moser come up quite often with the few people that have Camaros here which I think is a modified Ford axle and parts for them are the easiest to obtain or so I'm told
Cheers
Simon
Old Apr 3, 2003 | 01:31 AM
ausrs's Avatar
what i meant was maybe miles can get in touch with his supplier and ship direct from aus to uk !
Old Apr 3, 2003 | 08:45 AM
Dr G's Avatar
Thanks for all the 9-bolt info Dwain.
Anyone in the UK tried Hauser Racing for 9-bolt parts? I haven´t spoke to them yet but have heard good things.
Old Apr 3, 2003 | 03:51 PM
drain89's Avatar
You're welcome Doc. Are you referring to Art Hauser? I didn't know he carried 9 bolt parts, but I'll call him and see what he's got and what kind of prices he has.
Old Apr 4, 2003 | 08:41 AM
Dr G's Avatar
Sorry Dwain, I was meaning http://www.hauserracing.co.uk/ in the UK. I´ve seen them advertised in numerous US and custom car mags over here.
I hadn´t heard of Art Hauser before, but if you find that he stocks anything for 9-bolts then let us know.
Gordon
Old Apr 10, 2003 | 06:11 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
When I changed axle bearing in my GTA, after pressing out old bearing I've noticed that the retaining plate (the one held with 4 bolts) was kinda "convex" - after getting mech. stress for 13 yrs. it simply didn't hold outer bearing's ring in its place. I've used hydraulic press to make it straight or even bent a bit to the other side. Also used larger shims for retaining bolts. To bad, you've to do it on disassembled unit...
Old Apr 14, 2003 | 02:34 PM
Thanks z that turned out to be my problem also. I used my adjustment tool (hammer) and vice to correct the fault making it concave to make sure all was tight.
I bet Camaros are a rare sight in Poland like the UK?
Simon
Old Apr 14, 2003 | 05:35 PM
z_power's Avatar
Car: '89 GTA
Hmmm, I must say 3rd gen Camaros are harder to find than Firebirds in Poland, but I think f-bodies are the most known US-cars here. And if you live in UK than you know how expensiv it is to keep your car in A+++ condition - sh. rates, customs, VAT etc... Anyway, it's good to hear you've fixed this clinkin' wheel
Cheers,
Michal
Old Nov 7, 2003 | 03:47 PM
drain89's Avatar
Moderator: Please make this a sticky.
Old Mar 17, 2004 | 11:32 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I got this in a response to an e-mail sent to Street Machine magazine in regards to the 9-bolt articles:
Street Machine ran a Borg Warner diff rebuild feature over the July/August and the September 1998 issues.
From Craig Parker @ Street Machine
Back issues are available here;
We have back issues available online. Please click on the following link to order online.
http://magshop.com.au/Product.asp?ProductID=2293
. Please note that we do allow 28 working days, that's approximately 4 - 6 weeks for delivery of all back issues.
Check out the new Magshop F.A.Q by following the link!
http://magshop.com.au/HelpFAQ.asp
Old Mar 17, 2004 | 11:56 AM
drain89's Avatar
Excellent work!
Old Mar 17, 2004 | 12:02 PM
misinformation
not for nothing, and I have never read that particle magazine before.
other mags, like some corvette mags, and other GM only mags have MIS-information loaded into their articles. some of the technical stuff is so far off base, it's a joke. Seems like the writers are just regular car guys like most of us, who just so happen to write articles in there spare time.
so be careful about what you read.
The 9-bolt article posted here by hunter is pretty good, and so is the GM service manual. both combined make great information to rebuild a rear.
Old Mar 17, 2004 | 12:51 PM
drain89's Avatar
I just ordered my copies.
Old Apr 2, 2004 | 02:08 PM
SLP_GTA's Avatar
marked
TTT
Old Apr 2, 2004 | 02:38 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
didnt see it mentioned but, Ford uses the 9 bolt center section in their Escapes and Mazda Tributes. probably not hte heavy duty M78 tho.
Old Dec 1, 2004 | 11:48 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
An update for the Street Machine Magazines.
They are no longer available..never got mine after waiting a few months.
Question about the 9-bolt - does it use the same u-joint retaining straps and bolts as the 10-bolt rears?
If not anyone have part numbers for the bolts/retaining straps?
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
FormulasOnly
Sep 6, 2015 10:42 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
