Kandied91Z... clean engine post >>
Old Feb 16, 2003 | 12:48 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
A few days back, you had a post regarding clean engine bays...
Well, I started thinking about it, then went out and "cleaned" mine up a bit.I removed the A/C, made plates for bock offs, re-routed the wires, etc. I am not done yet, but figured I would show some pictures and get some feedback from them. Let me know how it rates..... I know it is far from the cleanest, but I am happy with the way it is turning out so far.
Jason
Old Feb 16, 2003 | 12:53 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Another
Old Feb 16, 2003 | 12:54 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
A shot of the battery area...
Old Feb 16, 2003 | 12:56 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Feb 16, 2003 | 01:08 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
awesome man... how did you re-route wires?
Old Feb 16, 2003 | 01:49 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
hey hard is it to take out the A/c im picking up a A/C delete setup and i want to put it in this week, how long did ti take you and what all did you have to do. thanks for any info
Old Feb 16, 2003 | 02:14 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I ran the wires through the support between the inner fenderwell and the fender, then along the inner fender to the front. I had to add about a foot and a half to the wires running to the fans, but other than them, no wires needed attention.
As for ease of removal, the actual removing of the A/C is simple and should be accomplished in just a few hours. I have spent a ton more time on mine only because I wanted to change a few things.
Old Feb 16, 2003 | 04:52 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Hey Jason,
Engine is looking GREAT! (as well as the rest of the car!!)
Just a quick question, are those Edelbrock TES headers? If so, I see you plugged off the AIR tubes, what did you use? I no longer need to have my IROC AIR equipped, so I'd love to rip it all out but need to plugg those tubes.
Thanks!
Ken
Old Feb 16, 2003 | 09:24 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
you ever sell your old engine that you had a couple of months ago?
Old Feb 16, 2003 | 11:01 AM
Squeeks83's Avatar
hey chevyken,
i pluged my AIR tube holes, all i did was go the the local hardware store and picked up some 1/4inch i think brass plugs, they also have aluminum. they were like $.30 each. good luck
Old Feb 16, 2003 | 11:47 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
ChevyKen... I used some brass pipe plugs. They came with a hex on them, so I shaved the hex off, then polished them up and used a strap wrench to tighten them. I think it cleans up the engine compartment a ton, and yes, they are Edelbrock headers.
Thunderstick..... I never had planned to sell my engine..? This is the same engine that has been in the car for a few years.... Maybe it was someone else ? When I pull this one out, it is going to go in one of my older Camaros.
Thanks for the compliments!
Old Feb 16, 2003 | 01:01 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
just wait till i get my car back :lala:
Old Feb 16, 2003 | 01:48 PM
MdFormula350's Avatar
very awesome engine bay!! nice, clean, and plenty of room!
Old Feb 16, 2003 | 01:54 PM
i guess you dont have heat? i dont see a standard heater box installed..
Old Feb 16, 2003 | 02:11 PM
johnyIROC's Avatar
Yes... that is my question exactly. Where is the heater blower motor? That is pretty much what I want to do with my firewall.... it would be even cooler to relocate the booster...but with the clearance on these cars it's not really an option.
Old Feb 16, 2003 | 02:40 PM
BORLAZ06's Avatar
daym...thats clean lookin.
Old Feb 16, 2003 | 04:46 PM
Car: '91 Z28
Axle/Gears: 323's
yea, sorry - i sure did have you confused with someone else... engine bay looks good, by the way...
KAM
Old Feb 16, 2003 | 04:56 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
squeeks83 and Jason,
Thanks a lot for the info!
Ken
Old Feb 16, 2003 | 07:46 PM
JimmyG-91Z's Avatar
:hail: :hail:
That's awesome thats exactly what I want to do to mine, remove the heater box, mine came without ac, and hide the wires, thats friggin sweet, keep up the good work man
Old Feb 16, 2003 | 08:52 PM
89transam's Avatar
Does your car pass smog?
Old Feb 16, 2003 | 09:24 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
It gets smogged every 2 years....
Old Feb 17, 2003 | 12:24 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
emissions testing... what's that ??!?
nice car man, really clean!
Old Feb 17, 2003 | 06:01 PM
Stang Eater's Avatar
I removed my heat and A/C as well, some areas of my engine bay need to be blasted and painted, but I figured I would leave that until I paint the car, since I'm changing colours....this will do for now though! It's near the bottom of this thread....
https://www.thirdgen.org/techbb2/sho...hreadid=158897
Old Feb 17, 2003 | 06:27 PM
DABE's Avatar
looks good!
Old Feb 19, 2003 | 12:08 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
run down to your local chevy dealer and get them to order you the replacement caps for the tops of your struts...
cost me all of less than 2 bucks and it will be just one more 'finishing touch' to clean up stuff
Old Feb 19, 2003 | 12:25 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
An idea I had one day was to mount the alternator where the compressor is located. That way you don't need the mounting equipment for the ac.
I once saw a coil mounted in front of the windsheild underneath the screen. don't remember what that area is called, but thats where the coil was.
nice job on the passenger side wires.
another suggestion would be to purchase a smaller engine overflow container, but it looks great the way it is now. I'm very impressed.
Old Feb 19, 2003 | 12:56 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Thanks again for all the compliments.
Justadba... I left the caps off because the struts are Koni adjustables... The caps need to be removed any time changes are made, it is easier to set them on the shelf
Old Feb 19, 2003 | 01:25 PM
justadba's Avatar
understood....:lala:
Old Feb 19, 2003 | 01:27 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Very nice job man. I wish my engine looked like that.
Old Feb 19, 2003 | 01:54 PM
91tirespin's Avatar
Car: 91 camaro rs
Looks great, I'm plannin to clean mine up when I swap my engine.
Old Feb 19, 2003 | 09:01 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Can you do me a favor and show me close ups of each side of the TB?
Also, on the routing of that passenger side plug wires. Ive been trying to do mine like that with TES headers but I havent found a way to keep the wires from hitting the #8 exhaust pipe. What did you use.. or do they actually hit?
Old Feb 19, 2003 | 09:20 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
My wires don't touch the header at all.... I will e-mail you pics...
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
