Firebird 6" thick parts book
Novass has bought the book from me, so he will now be taking over these fullfillments. Thanks!
I aquired a 6" thick parts and illustrations manual from an old pontiac dealer. It covers all Firebirds, Formula's, and Trans Am's for the third generation (82-92). It has every part number known to man for every firebird car between 82-92. The book weighs in at 13 Ibs.
So if you need any GM part number for any reason for any firebird, let me know. I just got this book so I will have to learn how to use it cause it's almost 2,000 pages.
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Need GM part number for the Idle Air Control sensor and the Throttle Position Sensor on an 85 IROC (305 tpi)
TPS - 17111606
NOTE: These #'s are for Firebird, but since the 1985 LB9 is the same, I am 99% sure that these numbers are correct for the Iroc as well.
Car: 1991 Camaro RS
Josh, how about a part number for the distributor cover that mounts at the rear of a TPI plenum for a 1990. Will the book tell you if it's the plastic or aluminum cover? Thanks.
*Keep in mind that the aluminum extension uses different screws than the plastic one.
Plastic Extension - 14083696
Screws for plastic extension(3X) - 14083852
Aluminum Extension - 10108425
Screws for aluminum extension(3X) - 14082425
Hope this helps.
-Josh
Thanks! Cant seem to find that IAC part number onthe GM parts sites though
. I found it at www.auto-parts-for-less.com. IMO they are 2nd best next to www.gmpartsdirect.com.
when you get to the first mentioned site above, click on ''order gm parts and enter the P/N and make of your car. it will give you a few results at $65 apiece. so this part number is correct.
hope this helps.
-Josh
Josh, I have another one. How about the fuse panel door on the lower dash panel for 90-92 Camaro interiors?
this is the one in my 88 TA, i dont know if this is the one you want or not, but ill show a pic, and let me know if this is the one or not.
-Josh
Car: 87 GTA
Thanks for doing such a great service Josh. Can you get me a PN for the bushings that the front turn signal lights assembly screw in to. It's just a little plastic/rubber bushing that the screw goes in to. Thanks.
$2.14 - www.GMpartsdirect.com + s/h
$3.21 - www.auto-parts-for-less.com + s/h
-Josh
Complicated P/N
Josh, can you get me a part number on front and back ujoint that will fit an aluminum driveshaft that came out of an 871le transam and is going in a 84 transam with a 10 bolt rear and a t5 tranny?:hail:
Car: '89 Firebird Trans Am WS6
Engine: 305 TBI (L03)
hey could you tell me the part number for for the fog lights on a 89 trans am?
Also the fuse panel door on the same year car?:d
Thanks a ton!:hail: :hail:
1) '87 350 TPI Dipstick tube - 14101124
2) Fuse Panel cover (pictured above) - 10019617 (discontinued)
3) 89 TA foglights - Lens - 16502945, Housing - 16503526, if you need any screws, retainers, brackets, clips, washers, or whatever else you need for it let me know.
4) '90 Formula hood insulation - 14099508
5)And for the U-Joint, all i could find is the U-joint for the 88 JG1 TA, i couldnt find the 87 w/a JG1 option.
NJITIROC - I picked mine up on ebay for $30, it came straight off of the shelf of a bankrupt Pontiac dealership. I have seen a few brand new ones on ebay as well, but they went for a little bit more money and didn't come with a fancy thick metal binder.
-Josh
-Josh
joshp14,
Any idea on part number/name for the air deflector/spoiler thing on the front of this firebird? It just before the front tire on the bottom. I can't find it anywhere and I need a new one for my 88 Formula. This is not my car BTW, it's justins86bird's car. It was the best picture in the Reader's Rides I could find. Thanks.
Rick
Rick
Originally posted by FIII
joshp14,
Rick
joshp14,
Rick
It lists for 21.60 at www.auto-parts-for-less.com and it doesnt show up at gmpartsdirect.com
Joshp14,
I don't have the aeropackage (mine looks like the car in the pic), but you did point me in the right direction and I found most of the part I needed in about 30 seconds. Thanks for helping me out!
Rick
Rick
Originally posted by NJITIROC
where can i get a book like that for 3rd gen Camaros?
Originally posted by 83crossfireZ28
we have like 10,000 shop manuals and parts books in a semi trailer... gm, ford, dodge.... cars, trucks... bla bla bla... we dont sell our parts books tho
Car: 87 GTA
Hey Josh. I received my parts today from the first question I asked you. Perfect!!!! Thanks a million. Well, I got another one. How about the four bolts/screws for the radiator shroud on top. 87 GTA. Thanks again in advance.
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
Ok, here's a couple. I need numbers for the plastic contact switches for the horn that are inside the airbag assembly on a 91 TA. I also need numbers for the bolts that attach the runners to the plenum on the TPI system.
87GTA Runner - Bolt for upper radiator mount - 11516594
91DropTopTA - Plastic Contact switch w/wire - 17989608, there are 3 different size bolts that are used when attaching the runners to the plenum/manifold. My book doesn't say where exactly they go...but i will give you EXACTLY what my book says for the description of each bolt:
14081016 (PAN HD, TORX, M8x1.25x39.5)
14081017 (TORX, 8x1.25x54)
14081014 (M8x1.25x30)
i also have a question for you 91droptopta, how many bolts TOTAL hold the runners to the engine..both sides together, and this includes to the manifold?
Car: 87 GTA
Hey Josh, me again. How about hood insulation and window weatherstripping, both sides, for 87 GTA. The weatherstripping is the ones that go on the door opening up to and around the windows, not the ones actually that mount on the doors. Thanks again Josh.
Hood Insulation Clips (just in case) - 3977775
RH Upper Door WS - 20606242
LH Upper Door WS - 20606243
Car: '91 Firebird vert
Transmission: auto
got one for you josh:
3rd brake light for a '92 firebird convertible (same as '91/92 bird and T/A verts..........also same as IROCs). it's built into the spoiler on the decklid. here's a pic
also the right spoiler piece for the same car. the spoiler is actually 3 pieces, and all i need is the passenger side piece (or if they come together, that's fine).
thanks bro
thanks bro
brake light - 919872 - $120.00 f/ www.auto-parts-for-less.com
RH Molding - 12510812 (discontinued)
josh you rock
hey josh, i wish you had one for camaros. but anyway i just wanted to say thats its great to see ppl helping eachother.....all i ever see on the net is ppl screwin eachother....so good job and keep helping ppl! you rock dude.
-Ryan-
-Ryan-
Car: 87 GTA
Hi Josh. I'm going to pick up my weather strips and hood insulation tomorrow. I'm glad you remembered about the clips, because I didn't. I'm getting them , too. Thanks a bunch. Well, I've got another one. How about a radio pod for an 87. This might be a tough one.
If this is what you are talking about, then the number is 10125293. The vents in the side, and the bracket inside the top come with this pod too. Keep in mind that it doesnt come with the radio trim plate.
Car: 87 GTA
That's it buddy. You came through again. Nice gauges BTW. I also notice you have the rare badge signifying a premium sound system. Do you know if you can get them anywhere. I'm putting in a killer system and it would be a nice little touch.
not sure man. i have the p/n for the little 'performace sound' badge, and that is 10041405, but im not sure if its discontinued or not. On mine it looks like it's riveted or the prongs are melted into the back of the trim plate. only other place you could try is ebay or a boneyard.
Car: '89 Formula 350, T-Top
Axle/Gears: Stock 3.73's
89 WS6 wheel centers
Hi Josh, Jim here, would you be able to tell me the number for a 1989 Formula 350 w/ WS6 silver wheel center cap. I lost one with the black WS6 logo on it and can't find it any where. My car only has 16,000 miles on it. thanks in advance.
