pulls to the right
Old Apr 15, 2003 | 11:12 AM
jawzforlife1's Avatar
pulls to the right
Last summer I put on some ZR1/SS wheels so I needed adaptors in the front (got them from www.skulte.com) and with those wheels I got wider tires (from 225 to 255). Well now every time it put the brake on the car pulls to the right. With out the brake on it drives perfectly straight. Any ideas??
Old Apr 15, 2003 | 02:57 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I have this same problem.. with mine, I need to rebuild the calipers. I think they are leaking... it could also be the rubber brake line. Those are two possibilities.. mine is so bad that if I hit the brakes doing anything above 40, it will try to shoot the car into the next lane. So I always have to compensate for braking... little rough on the tires, but I'll get the problem fixed one of these days.
Old Apr 15, 2003 | 03:29 PM
Ya only does it if I'm above 40 mph, otherwise I dont dotise it. Keep me posted if you figure it out. I still wounder if ih has anything to do with my adaptors/wheels/wide tires??
Old Apr 15, 2003 | 06:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
TZF, yeah, that's definately a collapsed brake line. The offending line is the one -opposite- the direction your car shoots for. Reason is that a clogged line delays brake fluid to the caliper- but the "good" line allows full pressure, so your car yanks to that "good" side.
Replace both at the same time; usually when one goes, the other's not far behind. The Haynes 82-92 Camaro or 82-92 Firebird manuals show you how to do this; it's about $25/hose, $2 for two copper "crush" washers (for the hose-to-caliper connection), and $5 for a huge bottle of brake fluid.
Old Apr 17, 2003 | 12:31 PM
ebmiller88's Avatar
Yup, just what Tom said.
Ed
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
sylentnite
Sep 9, 2015 02:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
