Gauge pods? Not for me!!!
Old May 9, 2003 | 12:41 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
For guys who know me, you know I like to be somewhat different in things I do to my car. It gives mods a "custom" look. I like to think I do everything in good taste -- nothing too drastic.
I also like instrument clusters that look like the cockpit of a 747. So for you guys who want an "alternative" to gauge pods, consider the following locations I'm about to post pics of. Albeit, they do require a little custom fabbing, but I feel it was worth every minute.
The first location is where my console ash tray used to be. I have three digital gauges under the smoked plexiglas. First a pic with the gauges off.
Old May 9, 2003 | 12:44 PM
Willie's Avatar
And with them on. These are three air temperature gauges I use to monitor air temp in:
1) Custom air filter box,
2) Supercharger discharge (but before the intercoolers), &
3) After the intercoolers, but before the throttle body.
Willie
Old May 9, 2003 | 12:46 PM
Willie's Avatar
The second location required even more fabbing. Here's my newest panel with the digital gauges off.
Willie
Attached Thumbnails Gauge pods?  Not for me!!!-digital-panel-2nd-gen
Old May 9, 2003 | 12:49 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Willie, you da man! Still waiting for new dyno results and some times from your new setup though!
Guages look killer!
Mike (1bad91Z)
Willie's Avatar
And on. An explanation follows.
Old May 9, 2003 | 12:53 PM
Willie's Avatar
I have a Kenne Bell Boost-a-pump. It's an electronic device that raises voltage to the fuel pump under boost, which creates more fuel volume. It also regulates voltage to the pump regardless of electrical load. The red gauge on the left is a Nordskog voltage gauge that reads voltage at the fuel pump. The higher voltage under boost is controlled with the **** located where the original cigarette lighter used to be. It's adjustable up to 17 volts. After a pass, I can hit the "review" button on the gauge to see what maximum voltage was during the pass.
The remaining two gauges are Dakota Digital's exhaust gas temperature and tranny temperature gauges. The numbers you see are not valid as I have yet to install the sending units.
Willie
Old May 9, 2003 | 12:58 PM
Willie's Avatar
Mike,
It looks like you chimed in before I had a chance to post all my pics! In any case, I recently had 3.23's installed (from 3.73's) and have not completed the break-in period yet. Once I'm good to go, I plan on it!!
Willie
Old May 9, 2003 | 01:28 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Willie, that's fantastic. I've been toying with the same ash-tray idea, but it appears that you've beaten me to it. It looks fantastic.
Old May 9, 2003 | 01:32 PM
BTS88IROC's Avatar
Very slick, I like it alot. It looks like you cut the ashtray part off from the rest of the shift plate, correct??
Old May 9, 2003 | 01:36 PM
DaGoat's Avatar
Damn man that looks sick. :hail:
Just curious as to where you got the guages and are they seperate from the smoked plexiglass?
Also on a side note how's that cd player treatin you? Mine crapped out on me after about a year or two.
Old May 9, 2003 | 02:13 PM
Willie's Avatar
Note: All my gauges are 2-1/16" round. The three air temp and voltage gauge are Nordskog (Summit) and the remaining two are Dakota Digital.
Jim,
Thanks. At least now you know it can be done. The gauges are not flush with the smoked plexi. They are about 1/2-inch below and angled slightly from horizontal (facing the rear). If you decide to try the same, please note that if you use analog gauges, they will not show through the smoked plexi very well. An option would be to use clear plexi, I suppose but I don't think it would look as good.
If you or anyone else would like more pics of the area below the plexi, I can easily remove it and take some.
Yes. Now all the retaining screws are functional. The former ashtray with plexi panel is removed with four screws, leaving the shifter portion intact.
Just curious as to where you got the gauges and are they separate from the smoked plexiglass?
I bought them from Summit and Dakota Digital. They sit behind the smoked plexi so you cannot see them, except when the display is on.
I've never had anything but good luck with Sony stereos. This one is no exception. In fact, my wife's very old Sony deck still functions and it's over TEN years old...
Willie
Old May 9, 2003 | 02:16 PM
DaGoat's Avatar
Please do, and Thank you.
Very nice setup once again.
Old May 9, 2003 | 02:17 PM
johnsjj2's Avatar
Car: 1991 Z-28
Willie, that does look great. If I had a need for that many gauges, I would love to use your idea, but alas, I don't need that many. Those digital ones under the glass are sweet as hell!!
Old May 9, 2003 | 02:36 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Ha, you guys aren't even scratching the surface when it comes to gauges in Willie's car. Like he said, He likes his guages to look likes "instrument clusters that look like the cockpit of a 747" and he isn't kidding. There are so many freakin gauges in there it's crazy. He took me for a ride and I swear I asked for at least 15 minutes "What's that, What's that.........and What's that". If your into eye-candy(gauges, LED's, *****, etc.) ******* car is for you.
The one thing I like about all the gauges and what not in ******* car is that it's all there for a purpose. It's not all show and no go, as some of us can say we've witnesses. Keep up the good work there Willie. Oh yeah, let me know when those gears break in so we can head to the track.
Eric
Old May 9, 2003 | 04:21 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Thats awesome, I like how you can't see them unless the are on. Very nice job.:hail:
Old May 9, 2003 | 07:25 PM
MILT's Avatar
Where's the flux capacitor!? J/K, the gauges look very 'professional'
Old May 9, 2003 | 08:18 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I have complimented your car in the past, but i just wanted to say again that it is a pretty clean example of what a car should be. Not rediculous looking, clean in and out, and damn quick too! One of my favorites on the site. Keep her clean man.
Old May 9, 2003 | 08:36 PM
WillWood's Avatar
Car: 1966 Volkswagen Beetle
Engine: Flat-4
Transmission: swing axle
That looks bad a$$ :hail: :hail: :hail: :hail:
Old May 9, 2003 | 08:48 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Wow, looks nice. I am putting in Dakota Digital Amp temp and volt gauges in my overhead console but wasn't sure the smoked plexi would let enough light thru. From you pics it looks like its plenty bright. Do you have the dim wire hooked up so they dim at night?
Old May 9, 2003 | 10:02 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I am definitely liking that!!
Wonderful work!!!!:hail: :hail: :hail:
Old May 9, 2003 | 10:55 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Simply Amazing once again! Willie I have said it before and I will say it again you are the man!:hail: I will take as many pictures as you can post lol.
Old May 10, 2003 | 08:39 AM
Willie's Avatar
I completely agree. I like the way the upper display panel turned out so well that I'm planning a similar one for my convertible. But like you said, I don't need that many. Most of the gauges I have in my coupe are related to racing and I don't race my convertible. What I'm planning on doing is using a couple (maybe?) of digital gauges and incorporate my LED indicators, all behind smoked plexi in a similarly sized panel.
....Let me know when those gears break in so we can head to the track.
Eric, thanks again for the compliments. I only need ~100 more miles to complete the break in process so by next weekend, I should be ready to go on some "data runs". Right now, I know my fuel pump setup is adequate to ~10-psig boost. Beyond that, I don't know. If it's not, I'll have to do an in-tank replacement before I race. Also, I know Tom will be moving to San Antonio sometime this summer. He's seen some of my prior runs on tape, but never in person. He's told me he wants to see my run in person, so I'd like to get to the track before he moves.
Where's the flux capacitor?
It's mounted off my ceiling behind the rear seats!!
Keep her clean man.
I'm doing my best to keep everything "tasteful".
From your pics it looks like its plenty bright. Do you have the dim wire hooked up so they dim at night?
Justin, the Nordskog voltmeter (red display) is plenty bright, both day and night. However, the Dakota Digital gauges seem to wash out somewhat in daylight hours, especially around high noon. I had to make a choice being seeing the gauges in full brightness of hiding them behind the plexi. I would have gone with all Nordskog gauges, but they do not make an EGT gauge and Dakota Digital was the only one in digital that I could find.
Knowing that the plexi subdues the display, I did not hook up the "dimmer" wire on any of the gauges.
And thanks to everyone else for your kind words. It does mean a lot. I did not post these pics to show off. I wanted to show you guys that a windshield pillar gauge pod is not the only solution to adding gauges. I feel I came up with some killer ideas that look totally custom and you guys are more than welcome to try the same.
I will post more pics of my "former ashtray" gauges without the surface panel this morning to show how I did it.
Willie
Old May 10, 2003 | 10:08 AM
Willie's Avatar
Just shot some pics. This one shows most of the parts I had to modify or fabricate. The first thing you'll have to do is cut apart the ashtray section from the shifter section. Be very careful as both parts will be reused.
The piece shown on top is obvious. Again, you'll have to be extremely careful when cutting the hole in the plastic as it has to match the plexi exactly.
The center piece is an overlay for the gauges -- so you cannot see the gauges themselves but it allows the display to show through.
The lower piece is fabbed out of 1/16" sheet metal and is used to hold down the transmission plate on all four corners.
The one part that isn't shown is the plate that holds the three gauges. You'll get an idea of how that one is made in the next pic:
Old May 10, 2003 | 10:17 AM
Willie's Avatar
This pic shows the gauges in place. The plate is 1/16" thick sheet metal with three holes. The "ears" on the ends are triangular in shape and bent 90 degrees so it's flush with the sides of the console. I used sheet metal screws to hold it in place. The console carpeting hides the screws. The screws aren't positively necessary as my panel fits rather tightly in place. Note the angle of the gauges. They are not horizontal, but face slightly towards the rear.
Old May 10, 2003 | 10:21 AM
Willie's Avatar
Next, lay the clear plexi overlay on top of the gauges. Note the overlay has three small holes to accomodate the ***** of the gauges. The overlay does not need to be glued or bolted into place, it just lays on top of the gauges.
Without the overlay, you'll be able to see the round rims around the gauges. I like seeing only the display, so I created the overlay.
Old May 10, 2003 | 10:23 AM
Willie's Avatar
Slide the metal brace into position. It fits between two existing plastic parts (on both sides) on the console, so it's held in place firmly.
Old May 10, 2003 | 10:25 AM
Willie's Avatar
Reinstall the transmission portion of the upper console using four finished screws.
Old May 10, 2003 | 10:26 AM
Willie's Avatar
Drop in the new finished "ashtray" plate and bolt it down! Finished...
Old May 10, 2003 | 06:11 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks a lot for taking the time to do that! It really makes more sense when you get to see the steps you took. Nice work
Old May 10, 2003 | 06:50 PM
pont82fbird's Avatar
WOW!!!!!!!!!!! :hail: :hail: :hail: that is really cool i think i might steal your idea when i get my procharger for my a/f and other things.
Old May 12, 2003 | 10:03 AM
Jim85IROC's Avatar
Willie
The new Sony stuff is horribly cheap, which is a shame. Their older line, specifically the line that included the one in your pics, was some of their finest stuff. Sony always had some of the best decks available, right up until they started the Xplod series.
Old May 13, 2003 | 12:38 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
That is one sick setup dude!! Looks like a space shuttle!! That is totally kick @ss!! :hail: :hail: :hail: :rockon: :rockon:
Old May 13, 2003 | 12:47 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Do you have pics of your car on another site or another thread? I am extremely interested in what the rest looks like if those are your gauges!!!!
Old May 13, 2003 | 01:00 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Click on the little icon "www" in blue under his sig. His car is white.
Old May 13, 2003 | 02:01 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Thanks, I feel dumb!
Old May 13, 2003 | 03:02 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thats cool. I know i don't care, so who cares what others think, right? Not me! later man
Old May 13, 2003 | 03:47 PM
formularpm's Avatar
Car: '89 Formula
Axle/Gears: 9 bolt
Do you have any pics of the entire interior?
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
willie
where did you get the smoked plexi at?
Old May 13, 2003 | 07:23 PM
Willie's Avatar
Other than the dash with added switches and gauges, the rest of my interior is stock. I get my plexi and acrylic in various colors and thicknesses from:
http://www.lairdplastics.com
Willie
Old Jun 22, 2003 | 10:57 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
Willie,
How do you wire up your fans with buttons. Do you make a fuseable link for them?
Can you please explain I am very insterested in doing the same thing.
mike
Old Dec 30, 2003 | 06:55 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
willlie,
what are the faceplates of the gauge clusters made out of. It looks very similar to the ashtray plate
Old Dec 31, 2003 | 09:34 PM
Willie's Avatar
Mike,
E-mail me with specific instructions on how you want your setup to work. I'll work it out from there.
Outlaw305,
The ashtray plate and gauge pod both use smoked plexi. The ashtray plate is less dense. I did this because this area is hit by sunlight which makes it difficult to see the readouts.
Willie
Old Dec 31, 2003 | 10:10 PM
Xceleratemaro's Avatar
uaaa woooooooooooow thats sweet * drulll* uaaa
Old Jun 6, 2004 | 08:21 AM
IroczInOz's Avatar
That looks way too good!!
Willie I have a question for you. What are all your LED's for I can read a few of them but some of then I can't make out.
Also CONV and TCC are you talking about the Lock up convertor and the TCC solenoid.
I am wanting to wire up a LED to light up when the TCC solenoid is engaged locking up the convertor. Any suggestions? How did you wire the LED up?
Old Jun 6, 2004 | 08:25 AM
EvilCartman's Avatar
Car: '82 Z28
Dang, way to bring back an old post
Old Jun 11, 2004 | 07:27 PM
treeohfive's Avatar
whoa.....phat.........now wtf is that panel of LED's below the a/c vents?
also, you got a pic of all the gauge setups in the car, i see other ***** and such, id like to see em
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
