Just got trur duals installed with hooker longtubes
Old May 30, 2003 | 07:38 PM
The Man's Avatar
Just got true duals installed with hooker longtubes
Damn it sounds mean. I went from hooker shorties and Flowmaster cat back(3" single) to Hooker longtubes, 3" pipe to 3"in and 3.5" out X pipe, 3.5" Dynomax Bullets mufflers. I am going to do dome testing nest week and see what difference it makes (probably very little on motor) shooting 175-200HP N2O. Ground clearnace in very good. I have went over every speed bump in this town with NO problems. I will try and post some pics here pretty soon.
Old May 30, 2003 | 08:12 PM
The Man's Avatar
pics
here are some
Attached Thumbnails Just got trur duals installed with hooker longtubes-1992-z28-pics-001.jpg
Old May 30, 2003 | 08:13 PM
The Man's Avatar
here is another
here u go
Attached Thumbnails Just got trur duals installed with hooker longtubes-1992-z28-pics-006.jpg
Old May 30, 2003 | 08:16 PM
The Man's Avatar
another
again
Attached Thumbnails Just got trur duals installed with hooker longtubes-1992-z28-pics-004.jpg
Old May 30, 2003 | 08:17 PM
The Man's Avatar
pics
pics
Attached Thumbnails Just got trur duals installed with hooker longtubes-1992-z28-pics-010.jpg
Old May 30, 2003 | 09:02 PM
Shagwell's Avatar
Car: projects.......
Looks good man! Kinda like mine is about to be...Nothing beats true duals! I'd expect a decent gain w/ LT's and the x. Both should help your torque numbers, as well as help the gases get out faster at rpms.
later, justin...
Old May 30, 2003 | 09:18 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
how much did it cost and is it custom or can u order it?
Old May 30, 2003 | 09:26 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
it is all custom
Old May 30, 2003 | 10:35 PM
The Man's Avatar
duals
It is all custom. I took it to the local shop and told them what i wanted. He is a damn good muffler man. The X-pipe came off my friend 95 Cobra(DR. Gas). The x-pipe had 3.5 " pipe front and rear, but my shop can only been up to 3". I wish they had mandrel bent(full flowing) bends, but this is more than enough for what i have NOW.lol I love the way a X pipe sounds over a H-pipe. It sounds like it just gained 300HP.(wished it had of lol) I figured on the motor(it may help alittle, but on the bottle i'm hoping for alot. I changed from the same set up to just a true duals(using shorties still) on my 85Iroc a few years ago and gained 4mph in the 1/8(on motor) It did have a hot 406.. but i hope I can gain a few mph(3-4mph) on the bottle and up my best from 95mph to around 99 or 100mph . I know it will be alittle tuff though. I just recieved my 225HP and 250 HP pills. I might try them out before to long(after i upgrade the stock Delco pump..Its on the way).
My goal is to also run a 6 in the 1/8(basically like it is). I would like to run a 6 just using a 175-200Shot. This damn weather is not helping my chances. It hit 100 degrees for the first time this year.
Old May 30, 2003 | 10:38 PM
The Man's Avatar
forgot
I bought the headers off a fellow thirdgen'er and the X-pipe was a buddy deal. The muffler shop was a another buddy deal$150.00 I probably have under $400 in the whole exhaust.
Old May 30, 2003 | 11:01 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Nice setup man !
though u have no ground clearance
proplems since ur car sits high due
to big rear tires.
A lowered car would have problems..
cant wait to see ur results though
congrats !
Old May 31, 2003 | 11:56 AM
The Man's Avatar
the race
The headers were a PITA. I think my mounts are worn and needed replacing. I had a big problem with 2 tubes on the passenger side. I had to move my Knock sensor, remove my oil cooler(for now),Mini starter, Cut some of the k-member(by a-arms).
The main reason I went to all the trouble and changes is for a race coming up at the local track.
Anyway, I live in a small town and there are a few 3rdgener's out here. It has come down to a guy I know(82 looks like a 92) and me for the quickest 3rdgen in town. he has a 355, 750cfm ,solid roller250+ @.050, Dart Pro-1's, T350, 3.73, 2 stages of N2O. He is a dumb *** when it comes to tuning and working on cars. His dad is someone else I can't stand. He thinks his car is the S*** and is better than anybody else. I heard him say he had the fastest 3rd gen in town.
He car does not leave well. He is also scared of N2O. He leaves on 125 and then uses the 2nd stage175 after the leave. the best he has run is 7.21 . He claims he only barley used the 2nd stage on that pass. He also run that pass a few months ago(winter) and at a better track.
I just ran 7.28(2 weeks ago) at our poor track. I also did it using my shorties and 3" cat back. I also came up with a SHORT Belt to bypass the PS pump(at the track only).The smog pump is already off of it. I installed a cooler stat(160), Walbro Pump(255) and 225HP/250HP N2O pills.
I have until June 21st(the race day). I am debating over the holley stealth ram before then. I am little worried about how it would run. I don't have time or ways for a custom chip. I am afraid of changing to much and not having enough time to test it out and get the bugs worked out of it.
Anyway I won't go on anymore. I feel like i don't have anything to lose. Like bring a knife to a gun fight.
PS He doesn't know I ran 7.28. He still thinks i only run 7.60's..lol
Old Oct 28, 2003 | 07:59 PM
91z383stroker's Avatar
Camaro pic.
Hey man first of all i just wanted to say damn nice exhaust, i want to do something like that, how much did that cost you.Well another reason i wanted to talkt o you was that, do you have pics of your car with a full body view.? i was wondering what size tires and rims you have on ther rear bc they looke nice. If you can post one of the cars pics in full view it would be great. Thanks.
Old Oct 28, 2003 | 08:09 PM
The Man's Avatar
here you go
here you go..i will post a few more
Attached Thumbnails Just got trur duals installed with hooker longtubes-1992-z28-pics-007.jpg
The Man's Avatar
again
again
Attached Thumbnails Just got trur duals installed with hooker longtubes-1992-z28-pics-013.jpg
Old Oct 28, 2003 | 08:10 PM
The Man's Avatar
last time
here
Attached Thumbnails Just got trur duals installed with hooker longtubes-1992-z28-pics-012.jpg
Old Oct 28, 2003 | 08:15 PM
The Man's Avatar
tires and exhaust
the exhaust cost me Around $150 for them to fit my X-pipe,mufflers, and redue the tubing i already had.
Front 15x5's with 26" sportmans
15x8(4.5" backspacing) with 28X11.5 ET Streets. They are a hair taller and about 1"narrower than the27x11.5 Hoosiers. I think it would look better if I had 28X12.5 ET streets.
Old Oct 29, 2003 | 02:34 AM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
how was your race? did you beat the crap out of the guy or did he back out? thanks, john
Old Oct 29, 2003 | 07:04 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
How can you take off-ramps and on-ramps at 70mph with those front skinnies?! j/k Car looks awesome. Is it mainly a straight line car or is it setup for dual purpose?
Tim
Old Oct 29, 2003 | 08:27 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
nice!!
Old Aug 1, 2004 | 02:00 PM
Yellow87Bird's Avatar
Car: 87 Formula 85 T/A
Transmission: 700-R4
where can i get an x pipe like that so i can do the exhaust system on my car?
Old Aug 1, 2004 | 04:09 PM
Momar's Avatar
www.drgas.com
Old Aug 3, 2004 | 11:10 PM
Dr G's Avatar
Re: the race
Originally posted by The Man
The headers were a PITA. I think my mounts are worn and needed replacing. I had a big problem with 2 tubes on the passenger side. I had to move my Knock sensor, remove my oil cooler(for now),Mini starter, Cut some of the k-member(by a-arms).....
The Man:- was it an oil cooler that had a sandwich mount section between the oilfilter and the bit above, if that makes sense? What are you planning to do to sort it? I'm having that problem just now as the oil lines from that sandwich plate come into direct contact with the headers.
Thanks for any help!
Old Aug 4, 2004 | 12:06 AM
Momar's Avatar
Go to this sticky subject. I believe it deals with the oil cooler. It either has to be removed, or modified. https://www.thirdgen.org/techbb2/sho...hreadid=148210
Old Aug 10, 2004 | 01:42 PM
KYL98's Avatar
Car: 1991 Z28
Hey sorry to hack into this post, But I was curious with the 28in tall tire in the back, how much was your speedo off? Any problems with the tires rubbing, etc?? Car looks awesome.....you do the stripes yourself? Im currently doing mine in black w/red stripes.....Nice exhaust too....:rockon:
Old Sep 21, 2004 | 03:08 PM
MustangMuncher's Avatar
Car: 89 Camaro
Transmission: Coan rebuilt TH700R-4
I like the paint on the car and all, but dear lord look at the height of the car. To install those pipes and have the down tube you need to fit a body bag under the wheel well.
Old Sep 21, 2004 | 11:44 PM
nick418's Avatar
Engine: L98, Hemi 6.2
i love your car and your exhaust looks great man, you cant beat true duals
Old Jan 17, 2006 | 09:54 PM
87GTAMAN's Avatar
Car: 1987 Pontiac Trans Am/GTA
Engine: L98 350 TPI,
Axle/Gears: 9 bolt w/ 3.23 posi
nice pics and sound clip. that is one sweet car. where did you get those gfx? i would like to use those on my GTA.
Old Jan 17, 2006 | 10:41 PM
jerrod75110's Avatar
Car: 89 camaro
Engine: 383
Transmission: 350 tci 3000 stall
I wanna run duals on my car as well. did you get the hooker super comps ? how loud are the bullets?
Old Jan 17, 2006 | 11:34 PM
The Man's Avatar
exhaust
I took it to the muffler shop and had them make it. no big deal.
The ground effects are the factory Z28's
Old Jan 18, 2006 | 05:23 PM
AC's Avatar
AC
Car: Used to drive a camaro
The Man, what x-member are you using and auto or manual? I put in my TKO600 with a Spohn with the driveshaft safety loop, doesn't leave much room to run under. Curious on your routing, looks straight under the xmember
Old Jan 18, 2006 | 05:32 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Sweet.....awfully low though.....I scrape now being careful, and that's just a
cat-back.
Old Jan 19, 2006 | 07:25 AM
The Man's Avatar
exhaust
At the time I had the stock crossmember (A4) and had plenty of room. I switched over to the Spohn Torque Arm(with loop) and I had to lose the x pipe. I am changing trans(PG) and instead of buying a spohn, I might have one custom made and attach the loop using my subframe connectors so I can reinstall the x pipe.
With the stock crossmember..ground clearance was fine(went over speed bumps with a problem. With the spohn loop on it..just to low.
With just bullets(sounds ok I guess..really don't like it), but with the x pipe...BAD ***.
I have some video with and without the xpipe. You can tell a big difference.
Old Jan 19, 2006 | 11:26 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Axle/Gears: 8.5" 10-bolt 3.73 Posi
guess no one noticed this thread was 3 years old.
So The Man.. did u ever run the guy with the other thirdgen?
Old Jan 19, 2006 | 01:46 PM
The Man's Avatar
yes and no
we lined up twice...the first time his waterpump went out in the burnout box..then the next time I broke 9 teeth off the ring gear.... We never line up again. I was having N2O problems the first 2 races, but I tried to race anyway. After I figured out my N2O problem he wouldn't line up against me. He moved out of town, but his car is still he at his parents..he just got his cage put in it. I am redoing my car now...HE IS IN FOR A SUPRISE!! When we both get them done..then I will finish it.
Old Jan 26, 2006 | 09:41 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Nice car man, your car is what helped me decide on my wheel choice and sizes. I got the same ones
Old Jan 26, 2006 | 01:12 PM
The Man's Avatar
nice car
thanks...your car is nice... I would love to change to some Weld Magnums(chrome ones)...don't have the money....Problably just buy some 15x10's to put on the back of mine with the 29.5x10.5 MT. Man they fill up the fenderwell.
Old Jan 30, 2006 | 09:41 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
I gotta quick question. How did you get the exhaust tubing to clear the trans x-member? I'm doing my own duals but am having problems trying to figure out where to route the tubing with long tube headers.
Old Jan 30, 2006 | 10:49 PM
The Man's Avatar
exhaust
if you use the factory crossmember and have 26" front runners and 27" or taller rear tires you can run the pipe under the crossmember. When I put some 26 on the rear it did drag on some places..with the 28 I had...no problem with speed bumps or anything.
Old Jan 30, 2006 | 10:50 PM
The Man's Avatar
crossmember
i forgot, if you use a spohn crossmember, the exhaust will me lower cause how the crossmember is made and even worse with a DS loop(the one that comes on the spohn crossmember).
Old Jan 30, 2006 | 11:12 PM
Engine: 355 chevy
poop, lol.
I don't have the spohn x-member but I do have a drive shaft loop.
Old Jan 31, 2006 | 05:29 PM
AC's Avatar
AC
I'm trying not to hijack this thread. I have a spohn xmember with ds loop and Hooker 2210's. Here's what I was planning on doing for a true dual route around the xmeber. BUT, I'm going to use some drgas.com oval tubes until I get into the ds tunnel, then transition back to full round.
Attached Thumbnails Just got trur duals installed with hooker longtubes-blueirocunderview2.jpg
Old Jan 31, 2006 | 05:36 PM
The Man's Avatar
nice
when i change to the spohn X member, I had to loose the x -pipe. I went ahead and run the 3" pipe under the x member. Ground clearance still wasn't a problem, but it was lower than before. I probably going to make my own x member for my PG and install a DS loop straight to the car instead of it mounting to the x member, so I can reinstall the x-pipe.
Old Jun 2, 2009 | 07:32 PM
Jekt's Avatar
Car: 1983 camaro
Engine: 350 soon to be 355
Re: Just got trur duals installed with hooker longtubes
just wondering if you had dropped your car at all or if its stock height.
Old Jun 2, 2009 | 07:57 PM
The Man's Avatar
stock height
Old Jun 2, 2009 | 10:31 PM
Jekt's Avatar
Car: 1983 camaro
guess mine shouldnt be so bad since im only going to go 3in all the way back. i wanted to drop an inch but dont know if that will be possible. missouri roads SUCK!!
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
Dialed_In
Aug 20, 2015 01:45 PM
