Modified Lt1 Intakes Conversions by John Millican
Old Aug 2, 2003 | 05:14 PM
xxxirocz88xxx's Avatar
I bought an Lt1 intake off Lt1intake.com on May 19 about 2 months ago or so and im completely and utterly disappointed and extremely aggravated with John Millican's products he sells. I have a whole list of problems I could go on for hours explaining every detail of every problem I have had. Let me start with the basics, for one I paid a total of $610 for the entire conversion not including the programmed chip which I don’t even know if it even works right. But I think all of you out there would figure that if you pay that much for an intake you all would expect it to be done right the first time. But no John Millican from my point of view def doesn’t come close to even giving you your moneys worth.
Let me go on with all the problems I have had with John Millican's lt1 intakes 1) bolt holes aren’t modified right, not even close to lining up with the holes on the heads additional modifying will have to be done yourself 2) leaks coolant and oil like crazy 3) Lt1 intakes done have distributor holes so John Millican drills a hole in the back of the intake and screws a angled piece of metal on the back of the intake to acquire the correct angle for the distributor. the problem I had with this is that piece of metal he made was to thick 3/16 does make a dif people, and when it comes measurements on engines and parts there is def no room for error. well because of this error my oil pump shaft had slack in it there for it ground down the inside of the shaft causing the oil pump not to work unfortunately I did not notice this for a few min so my brand new engine was running with no oil for *** knows how long im glad it didn’t do any harm.
Now I emailed John Millican and he says it’s not his problem he won’t give me my money back because I already installed the intake. How was I supposed to know all this would happen with out installing the intake. now my every day driver my 1988 iroc-z Convt. is a hunk of junk sitting in my garage. To top it off I had to buy some hunk of junk to drive around. Any one else have theis problems.... ill post more about this later when I fig out what the hell im going to do with this situation..
I have agreed to give john abother try to see if he can get the job done the right time the second time since he wont give me my money back. we will se how it goes.
Old Aug 2, 2003 | 06:56 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
That really sucks, sorry to hear that!!!
If you want better exposure to people that may have used the intakes repost this in the Vendor board.
Old Aug 3, 2003 | 03:15 PM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
man i wanted to do that mod too
Old Aug 3, 2003 | 06:30 PM
Guest
Guest
Posts: n/a
I should move this but... not going to.
Copy on the other board.
https://www.thirdgen.org/techbb2/sho...hreadid=194501
Old Aug 4, 2003 | 12:53 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
This seems odd as I have seen lots of posts from satisfied customers of John's. I would like to hear his side of this story as well.
Old Aug 13, 2003 | 09:37 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Even with used parts, when they are purchased from someone who is in the related business, the customer expects, and rightfully so, the product to be better than buying from a individual, and the courts will side with the customer.
NEVER EVER modify anything you might need to return to the seller without first getting his permission.
Old Aug 16, 2003 | 09:44 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Funny John.
1 warning. 2 doesnt come.
Old Aug 16, 2003 | 09:57 PM
Guest
Guest
Posts: n/a
Consider this post locked.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
okfoz
Aug 21, 2015 07:38 AM
