3.1 on the dyno...
Old Sep 13, 2003 | 01:24 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
3.1 on the dyno...
i'm supposed to be going to the dyno in about 7 or 8 hours! wish me luck. i'll let ya'll know what the little monster does. lol...i better not say too much until i get the numbers on it.
Old Sep 13, 2003 | 09:59 AM
Nixon1's Avatar
I'd love to see what it'll read...be sure to post!
Old Sep 13, 2003 | 11:02 PM
Car: 91 Camaro
unfortunatly i was not able to make it to the dyno today but i'm going to try to find another place that is closer where i can get it dynoed. hopefully within the next week or so, i definatly will get it done and will let ya'll know what i find out.
Old Sep 16, 2003 | 12:29 PM
Car: 91 Camaro
ok....i went to the dyno today. the numbers weren't quite as high as i hoped for but now i know what i'm putting to the ground. remember this is RWHP not at the crank. 134.4 hp @4800 and 155.0 torque @ 3900. again not quite what i expected but almost as much at the wheels as a stock 3.1 has. i have an auto tranny too which helps you lose about 30% of the power from the crank to the rear wheels. also, the was a real dyno that puts a load on the tires to measure, not just give a calculated number.
Old Sep 16, 2003 | 12:56 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well if ur losing 30% of hp from the crank to the wheels, then that should put you at 190 hp or so, which is eh, damn good. Especially considering that a 3.1L is actually only a 140hp engine, so i'd have to say that'd be impressive enough.
Old Sep 16, 2003 | 01:33 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
i thought auto trannies give a 25% loss and stick is 20%... thats still just a general estimate tho, since alot of it depends on the gearing. (and 700r4's are good in that department)
anyways, i would really like to see the graph, or at least post the HP/TQ at every 500rpm, i have never seen a dyno graph of a 3.1 and i am very interested.
Old Sep 16, 2003 | 04:13 PM
NHRATA01's Avatar
I'd like to see a 2.8/3.1 dyno at some point too.
Also JMHO, but I think you're giving yourself a bit too much parasitic loss. Modern auto's are around 20% (and GM is well known for making excellent autos that are very efficient and don't sap much vs. manuals), manual's are closer to 15%. Someone a while back found the T56 6 speed in 4th gen cars to sap 12% after going from an engine to a chasis dyno (obviously the 12% includes the differential).
Old Sep 16, 2003 | 04:33 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
I was going to say.. in this day and age it's more like -
15-20% for autos
10-15% for manuals
Old Sep 16, 2003 | 06:19 PM
Car: 91 Camaro
the guy at the dyno told me around 30% on autos and 20% on sticks....just depends on who you ask. that was running a full exhaust system and still the stock chip on my highly modded motor. i want another chip and i need to put a torque convertor lock-up switch on it to help get all the power that i can to the rear end. i'll try to get the graphs scanned and posted as soon as i can.
edit: oh yea, its still got the stock speed limiter too (110 but really about 87 with my 4.10 gears). and, apparently my tach shows about 600 rpms more than the motor is turning. their computer only showed up to about 5400 when my tach was showing about 6000.
Old Sep 16, 2003 | 09:45 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
lol
If anyone is interested (or wants a good laugh ) heres my dyno before I pulled my 2.8 (turned out to be a 3.1L heh not a 2.8L... said 3.1L on the crank... odd).... needless to say it was running **** poor. I looked at the timing a few days after and it was at like 2* at idle. No idea... but the car could not pull out 4th gear on the dyno.... 77rwhp was in 3rd after the pull in 3rd, the guy just told me to take the car off.. too much strain on it (dyno? ).
:rockon:
-Bud
Old Sep 17, 2003 | 11:48 PM
Car: 91 Camaro
here's a picture of my dyno sheet.
edit: ignore the spike at the end, it read somethin funny when the speed limiter shut the motor off.
Old Sep 18, 2003 | 01:27 AM
Doward's Avatar
So you'll be shifting about 5300
Any track times on her?
Old Sep 18, 2003 | 02:39 PM
Nixon1's Avatar
Not a bad curve. Surprising to me that these motors don't make much power over 5000...they fall off very quick!
Old Sep 18, 2003 | 03:53 PM
Car: 91 Camaro
i might try to get it to shift a little early. yes, 9.73 1/8th mile @ 73mph and a 2.14 60'
Old Sep 18, 2003 | 07:24 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I want to try and get my car dyno'd around here too to see what I've got, I just haven't had the time lately.
What mods do you have done to the engine? Looks like a great run by the way!
Old Sep 18, 2003 | 10:53 PM
Car: 91 Camaro
mods: 3.1 bored +.030", custom domed pistons, about 10.75:1 compression, biggest factory produced valves, 3-angle valve job, fully ported and polished heads, ported intake, 1.6:1 roller tip rockers, crane cam - .484 INT lift and .512 EX lift, hooker super comp LT headers, custom y-pipe, 3" "catback". just got back from the track and i ran a NEW RECORD time! 9.67 @73.16mph running open headers. the car sounds sweet like this. oh yea, 2.13 60' old best was 2.14.
WWasem, do you have antyhing done to yours?
Old Sep 19, 2003 | 01:30 AM
Nixon1's Avatar
Wow dude...you'd rip my V8 out of the hole badly!! Not to mention you're running some seriously fast times...I'm shocked.
By the way...your cam is freaking huge!!!
Old Sep 19, 2003 | 07:27 AM
Engine: 346ci LS1
Transmission: MN6
Wow dude! You weren't kidding when you said the engine was higly modified! :hail:
I have:
2.5" cat-back exhaust, SLP cold air intake, Hypertech Computer chip, 8.5mm spark plug wires. That's basically it for performance modifications, nothing heavy at all.
Old Sep 19, 2003 | 02:09 PM
Doward's Avatar
Damn... now I HAVE to land in the 14s to get ahead of you!
Ok.. 10psi. :P I can't wait to see what the turbo does... I know the exhaust is still kinked up, off the stock DSM O2 housing. I've got to build a custom stainless steel mandrel downpipe still...
Old Sep 22, 2003 | 05:20 PM
Car: 91 Camaro
side note: the energy suspension transmission mount looks much better than the factory replacement. i just installed one yesterday after ripping mine out thursday night at the track. they say it requires modification for it to fit...you gotta grind out one little whole on the crossmember because it is offset a tad bit.
Old Sep 22, 2003 | 05:24 PM
funstick's Avatar
dude send me a copy of your current bin file and some really detialed datalogs. also what size injectors are you running ? email at djfreggens@aol.com and we will talk turkey
Old Sep 25, 2003 | 08:49 PM
Car: 91 Camaro
click here if you want to see my car at the track. i was running open headers on it so, yes all that noise is from my little 3.1
Old Sep 25, 2003 | 09:00 PM
Engine: 346ci LS1
Transmission: MN6
Sweet video man!! Sounds awesome!!!:hail: :rockon:
I've been wanting to get some DV footage of my car I just haven't gotten around to it yet
Old Sep 25, 2003 | 09:21 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
damn! that f-er sounds awsome:rockon: i hope my dads car comes out like that, he wants to build his v6 too.
Old Sep 25, 2003 | 09:32 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if you take off the headers, that's what an open manifold 3.4 would sound like
Good clip, you would a$$ stomp my bird right now, but then so would that truck .
Old Sep 25, 2003 | 09:38 PM
Doward's Avatar
Nice! I found I didn't like the way my 2.8 sounded at 4k with open exhaust... too 'fart pipe' for me. Yours sounds nice though!
Old Sep 25, 2003 | 10:54 PM
Nixon1's Avatar
Holy crap, that video is amazing. I never would've imagined a V6 could pull that. Your car is AWESOME, man! ROCK ON!:rockon: :yourock: :hail:
Old Oct 1, 2003 | 12:32 AM
Car: 91 Camaro
wish me luck on the weather....i'm planning to go to the track again thurs. to see what the shift kit does for it! it'll chirp the tires pretty good hittin second gear on the street, i wanna see what it does at the track. weather is supposed to be a littlw cooler too....i'm lookin for 9.5Xs!! once i get the high stall convertor in, i'm lookin for another tenth or so.
Old Oct 1, 2003 | 06:56 AM
vortex's Avatar
Engine: 5.0
Hey... Doward here....
Are you doing anything Saturday? If not, you should come down to Corvette Master's in Maitland (Outside Orlando)... I'd love to get a couple 'impromptu' runs with ya.
Old Oct 1, 2003 | 09:48 AM
Car: 91 Camaro
what is corvette master's? i don't think i have anything going on, i might be able to come over there.....let me know what's going on there and prices and stuff. you can pm me or post here.
Old Oct 1, 2003 | 11:31 AM
vortex's Avatar
Engine: 5.0
http://www.fl-thirdgen.org/forum3/viewforum.php?f=67
check it out...
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
DIY PROM
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
