did a cranking compression test
Old Nov 29, 2003 | 06:31 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
here were my results
1 195
2 205
3 200
4 210
5 200
6 210
7 205
8 210
all in all it turned out pretty well i think
in general it seems kinda high but the engine did start out with 9.3:1 and the previous owner claimed the heads were shaved
add that to a low end torque cam (XR252) and i guess that warrants the rather high cranking compression
engine runs great too, sucks i found an oil leak, but thats good in a way because i have to add a quart a month, thought i may have been burning oil, but that idea is now laid to rest
Old Nov 29, 2003 | 08:53 PM
Vader's Avatar
Cranking compression tests always have numerous variable due to battery and starter condition, enging temperature, valve timing, cam profile, altitude, etc. The most important factor is the difference in the results, from the highest to the lowest cylinder tested. The old standard allowance is for no more than 10% variation from highest to lowest. Yout 7% looks very good by that metric.
Old Nov 29, 2003 | 11:00 PM
cool
i did it when the engine was warm (20 minute drive home from work)
the starter is brand new and it does spin rather fast
and i am 2 miles inland from the atlantic ocean
and the smaller duration of the cam leaves for less time the valves are open
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
