Just Rebuilt my Frontend(pics inside)
Old Jan 1, 2004 | 03:10 AM
FastZ28*84's Avatar
Car: 84 Z28
Engine: 72 350 .030 over
Transmission: 89 WC T-5
As the subject says I rebuilt my frontend. I sandblasted the a-arms,swaybar,and motor mount peices, then painted them with POR-15 gloss black along with the new steering peices. I used all new Dana steering components: tie rods, center link, Idler arm, and ball joints. I replaced the a-arm bushings with Global West Del-a-lum bushings. I also added a TDS wonder bar, and Spohn solid tierod adjusters. New ES greasable sway bar bushings and endlinks. I also replaced pass side motor mount, I did the driver side mount about 8 months ago. Here are some before pics then the after pics along with a pic of my Global west LCA's and panhard bar and my exhaust. Enjoy and post any comments.
Old Jan 1, 2004 | 03:17 AM
FastZ28*84's Avatar
Car: 84 Z28
Before rebuild
Attached Thumbnails Just Rebuilt my Frontend(pics inside)-before_rebuild.jpg
Old Jan 1, 2004 | 03:20 AM
FastZ28*84's Avatar
Car: 84 Z28
all apart
Old Jan 1, 2004 | 03:21 AM
FastZ28*84's Avatar
Car: 84 Z28
Old motor mount
Attached Thumbnails Just Rebuilt my Frontend(pics inside)-oldmotor_mount.jpg
Old Jan 1, 2004 | 03:23 AM
FastZ28*84's Avatar
Car: 84 Z28
New motor mounts.
Attached Thumbnails Just Rebuilt my Frontend(pics inside)-newmotor_mount.jpg
Old Jan 1, 2004 | 03:24 AM
FastZ28*84's Avatar
Car: 84 Z28
after rebuild
Old Jan 1, 2004 | 03:26 AM
FastZ28*84's Avatar
Car: 84 Z28
Del-a-lum bushings
Old Jan 1, 2004 | 03:28 AM
FastZ28*84's Avatar
Car: 84 Z28
Here is a pic of my SpinTech muffler 3" in and dual 3" out.
Old Jan 1, 2004 | 03:30 AM
FastZ28*84's Avatar
Car: 84 Z28
Here is a pic of the underside of the car from the rear, you can see my LCA's and more.
Old Jan 1, 2004 | 05:14 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Looks awesome, 110% better!!!
Could you post the Dana part numbers?
Nice job!
Matt
Old Jan 1, 2004 | 09:02 AM
_max_'s Avatar
nice work
Old Jan 1, 2004 | 02:10 PM
Spdfrk1990's Avatar
I wanna redo mine again and paint the a-arms with some rust proof paint this time. Then get those del-a-lum bushings instead of jus the poly ones. Looks like you need to paint the rear end now.
Old Jan 1, 2004 | 04:05 PM
ebmiller88's Avatar
NICE!! Gotta love POR.
Ed
Old Jan 2, 2004 | 12:01 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
That looks awesome man.
Now if you get some SFC's, springs and shocks, you'll be set up real nice.
Like someone said, please post some part numbers and prices.
Old Jan 2, 2004 | 03:12 AM
Carbonsteel's Avatar
I'm about to rebuild my front end too.
Do you have to have any special tools?
I've also heard that hte centerlik has to be replaced in EXACTLY the same position.
Any tips you can pass along would be appreciated.
Old Jan 2, 2004 | 05:22 AM
Matt_Ky's Avatar
POR = ?
Old Jan 2, 2004 | 08:09 AM
Car: 91 RS
Engine: 350 TBI
Originally posted by Matt_Ky
POR = ?
It's like spray on bed liner for your chassis
Old Jan 2, 2004 | 08:13 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
POR = ?
http://www.por15.com/
Our POR-15 Rust Preventive Paint, acknowledged worldwide as the finest rust preventive coating ever developed, stops rust permanently and is the product by which all others are measured.
its cool stuff....
Old Jan 2, 2004 | 10:14 PM
FastZ28*84's Avatar
Car: 84 Z28
I have the part numbers but couldn't find anyplace online that sold them. I got them at a small local parts store. They are "BEST VAL-U CHASSIS PARTS" brand. On the boxes they say Best Val-u chassis parts/ Dana corperation. The part numbers are :
SPI 505-1026B Balljoints 12.62 each
SPI 401-1316B Tierods 25.20 each
SPI 401-1317B Tierods 15.78 each
SPI 450-1065B Idler arm 35.39
SPI 435-1075B Center link 42.15
Total plus tax (6% in PA) 195.83
The parts place told me the SPI stands for Spicer, another brand of Dana I think. I don't remember which tierods were inner and outer, sorry.
The special tools I used was a pneumatic chisel with a fork for splitting the tierods and spindle off the ball joint. A spring compressor to aide in removal of the coil springs. An impact wrench was nice but not necisary. When it came to pressing out the old A-arm bushings I took them to the local shop and had the old bushings pressed out along with the old balljoint. I then sandblasted and painted the A-arm and took it back to have the new balljoint and bushings pressed in. Off my head I can't remember anything else.
I don't think that matters as much as the idler arm going back into the same position. Regardless I still am getting a frontend alignment.
I have had my Global West SFC's for about 2yrs now and still didn't get around to installing them or look into a local shop doing it. I would like to install them myself but people don't reccomend installing them on a lift. I am too lazy to put it on jackstands and crawl around on my back trying to weld.
As for the springs I can't lower it if I want to get up my Fathers driveway to use his garage. The tailpipes drag slightly as it is. I did cut one coil off the fronts to bring the frontend down a bit, as it sticks way up since I lightened it. I have alum L98 heads, an AC Delco Alum/plastic radiator, no smog, and plastic headlights instead of glass. I also have a factory fiberglass hood off an 83 Z28 I want to put on.
Thanks for all the cool comments guys. If I missed anyones questions let me know. Thanks
Old Jan 3, 2004 | 03:04 AM
You'll have to let everyone know how it drives.
Old Mar 1, 2004 | 12:13 PM
FastZ28*84's Avatar
Car: 84 Z28
It finally was a nice day saturday so I got it out and drove it around. It seems to drive alot better, doesn't pull near as bad on uneven pavement.
Then Sunday I took it down to Maple Grove and went auto crossing for my first time. That was a blast, a big rush to say the least. It seemed to stick pretty good but I had difficulties putting the power to the ground. The track wasn't the greatest either. Alot of different surfaces and transititions from flat to not so flat.
All in all I'm happy with how it drives now compared to how it was before the rebuild.
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
backtothe80s
Sep 5, 2015 12:39 AM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
