taking off ac
Old Jan 15, 2004 | 04:55 PM
ejm's Avatar
ejm
Car: 83 Black T- top Firebird
Engine: Carbed 350
Transmission: 5 speed
taking off ac
hey i want to take the ac out of my car (what is the point of it if you have t tops) and want to know what i need to remove. So far i have the raditor off, the lines that go forward and the pump thing driven by a belt the the lines go. i know the canstier has to go but what else and will i lose heating . thanks eric
Old Jan 16, 2004 | 02:03 AM
MdFormula350's Avatar
http://members.***.net/iroczdave1/IR...rts%20Page.htm
you can get the heater box so u can have heat.
10055890
http://www.gmpartsdirect.com/
the delete pulley if u have the one belt system
if not (v-belt) u dont need it.
for a/c delete just remove all a/c lines, compressor, old box, the thing in front of rad. (condensor)
Old Jan 17, 2004 | 08:02 PM
92TRANSAMWS6's Avatar
10055890
[/B]
They only want $38 for the pulley.....they sell on ebay for over $65 and some of them are used.....bunch of idiots are making someone rich. Gives me an idea.
Edit: MD pretty much summed it up. Taking all that crap out frees up soooo much room
Old Jan 17, 2004 | 09:50 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Youll need a shorter belt to pull the compressor. You will still have heat. The only other thing i could thing that you could pull is the evaporator, but thats under the dash and a real pain. If you really want to pull it just follow the lines from the "canistor"/accumulator to the firewall. Its at the end of that yellow brick road.
Old Feb 12, 2004 | 10:41 AM
86iroctpi's Avatar
Car: 86 IROC
Anyone have a pic of how it looks in the engine compartment ofter it is all gone?
Old Feb 16, 2004 | 11:35 AM
souperman28's Avatar
Car: 89 IROC-Z
i will take a pic when i recieve the pulley
Old Feb 23, 2004 | 07:59 AM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Where does that Heater Box mount too? Do i still need the blower thats in the engine compartment attached to the firewall?
- Got a pic yet souperman28?
Old Feb 27, 2004 | 04:46 PM
Car: 1986 Vert Z28
Anyone?
What i want to do is tottaly remove the blower from the engine compartment, and the plastic shrought thats around it too. I'm thinking the heater box mounts to the underside the passenger dash. But does it still need the blower? I whent tooling around the junk yards and couldn't find one w/o AC, so i'm still pretty lost. I'd Apreciate any help.
Old Feb 28, 2004 | 02:44 PM
u take the big a/c box out and bolt in the smaller heater only box.
before
after
much roomier now.
Old Feb 28, 2004 | 03:02 PM
Pepsicola's Avatar
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
before
after
much roomier now.
Does it use the same wireing as the AC heater box??
Old Jun 30, 2004 | 01:59 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Axle/Gears: Moser 4.56
Got the heater box in, but am having trouble with these wires. I would like to know what color wires go to which terminals on the resistors. I have the three connector (three speeds?) box with a four connector cable. Also, I suppose I still need the relay, but what the heck is the other connector??
Old Jun 30, 2004 | 02:03 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
And the connector. I did notice it's labeled 1 2 3, so I'm thinking it's not that hard. I don't have a schematic, so I'm sucking.
Old Jun 30, 2004 | 05:22 PM
ejm's Avatar
ejm
Engine: Carbed 350
i made this post a long time ago. I went and got an a c delete box and did everthing said here but ran out of funds and moved on to other things but now i want to finish hooking it up. My question is can i reuse the blower from my a/c setup because it seems that the blower is to long to fit in the delete box
Old Jul 1, 2004 | 05:12 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
The blower motor itself will work, but the squirrel cage (white plastic fan blades) is too long. I cut mine down, just because I want to get this thing done, and don't really want to wait on parts. I figure if the fan blows to pass inspection, that's all I need.
Here's how this guy did it..
https://www.thirdgen.org/techbb2/sho...ht=a%2Fc+motor
Old Jul 12, 2004 | 01:58 PM
Car: 89 IROC-Z
i got the idle pulley on but i havent even tried to take out the hole module for the a/c it looked to complicated.
Old Jul 12, 2004 | 07:04 PM
Racer350's Avatar
Car: 1988 IROC-Z
Axle/Gears: 3.45
https://www.thirdgen.org/techbb2/sho...hreadid=218856
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Metalizer
Sep 13, 2015 12:56 PM
Fox118
Sep 12, 2015 09:29 PM
formula1LE
Sep 12, 2015 08:31 PM
