need help wiring a/c delete box
Old Jan 14, 2004 | 02:29 PM
CamaroEFI's Avatar
i got an a/c delete heater box out of an 84 camaro. obviously there is a difference between the 91 a/c equip. heater box and the 84 a/c delete heater box...the connections don't match up. i left all the wires from the original heater box so can someone please tell me which wires connect to which connectors on the a/c delete box
Old Jan 14, 2004 | 05:30 PM
Racer350's Avatar
Car: 1988 IROC-Z
Axle/Gears: 3.45
the easiest way to do it is to use the resistor block from your ac heater box and install it into your non ac box. you just have to drill mounting holes and then all of your existing wiring will stay the same, just plug in the connector.
Attached Thumbnails need help wiring a/c delete box-heater-box.jpg
Old Jan 14, 2004 | 09:05 PM
CamaroEFI's Avatar
great..i threw my old box away. i didn't think i would need it again. any other way??
Old Jan 17, 2004 | 09:41 PM
BOTTLEDZ28's Avatar
Transmission: A4
go back to th bone yard and get the sensor. If no dice there then do to dealer.
Old Jan 22, 2004 | 03:44 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Their fairly cheap, go get yourself a new one from a dealer....
Old Jan 24, 2004 | 02:22 AM
smokingss's Avatar
Need the resisitor block? Im parting out a 92 RS, if you want, i'll take it out for you and send it to you free of charge.
Old Jul 20, 2004 | 12:36 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Axle/Gears: Moser 4.56
Do you still have it,, or another one?
Old Jul 20, 2004 | 12:37 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
I wish I would have checked here before ditching my old box. Yet another lesson learned the hard way.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
