WTF is this?
Old Jan 16, 2004 | 01:51 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
WTF is this?
TSIA
sorry about the links, yahoo wont host
Old Jan 16, 2004 | 03:09 AM
Morley's Avatar
I think one of those is your power antenna relay, the other...not sure.
Old Jan 16, 2004 | 06:56 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
silver one is the rear defroster relay... i dunno the other one tho...
Old Jan 16, 2004 | 10:25 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The black box is your cruise control module. The other two are the power antenna relay and the rear defroster relay.
The Trickster!!!!!!!!!!!!
Old Jan 16, 2004 | 09:47 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
do you have intermittant wipers? Or the bose sound system?
Old Jan 18, 2004 | 05:39 PM
Xophertony's Avatar
Axle/Gears: n/a
my car does not have a power antena.
my wipers do have a delay, but it sucks, and how do i know if i have a bose sound system? when i hooked up my new (new to the car, its like 7 years old) cd player (whohoo go 30$ target brand) it went right in.
the black box with "ac" on it is my cruse control module? or is the far little black box my cruise control.
thank you all for the info.
i need more specifics if possable.
Old Jan 18, 2004 | 07:04 PM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
The black box is the timer for the intermittant wipers. All the cruise control electronics are built into the servo under the hood. I could confirm the relays pourpose if you could tell me what markings are on it and what color wires go to it.
Old Jan 18, 2004 | 09:22 PM
BigTiggBoy's Avatar
Car: 1986 Trans Am, 1997 Trans Am WS6
Engine: 5.0 Liter TPI, LT1
Transmission: 700R4, T-56
Axle/Gears: 3.27 9-bolt, 3.42 10 bolt
The black box with AC on it is the cruise control module. I recently had to repair my 86 TA cruise control and I had to test voltage readings at that module.
Old Jan 19, 2004 | 08:56 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
do you have intermittant wipers too? What voltages did you read there? Pull the plug out of it and see if your wipers still work.
Old Jan 19, 2004 | 09:54 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Serpent99,
I also have a 89 Iroc-z, I also have the GM service manual. The black box is your cruise control module. Your intermittent wipers are controlled by the wiper motor on the firewall in the engine bay. If you would like to have it, I can send you some information concerning their locations.
Old Jan 19, 2004 | 10:05 AM
SERPENT99's Avatar
Car: 89 IROC
Engine: 95 350 LT1
I just checked my car, sure enough, I got my wires crossed. It sure was the cruise control module.
I guess I'll be ripping that box out, I plan to use the cruise control servo from the 95 roadmaster that I got my motor from.
Sorry for the confusion.
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
