3/8 or 7/16 stud vs hyd. or mech roller
Old Jan 28, 2004 | 07:52 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
Ok... here's the deal. I have a comp cam XR288HR retrofit cam(236-242/.520-.540/100 lsa) which i was going to put into my 383 along with the retrofit hydraulic roller lifters.. which are absurdly expensive at nearly 500 bucks.
Now from a cost/benefit point of view.. I am beginning to have second thoughts, and am considering running a mechanical cam and lifters(which are about half the cost).. but I will have to change my valvesprings. So... is it ok to run my 3/8 stud/roller rockers with a mechanical cam given the increased spring pressure, or should I go to 7/16?? Or can i just slap on a $100 3/8 stud girdle from moroso and call it good?
Questions? Comments? Opinions? Hate?
Old Jan 28, 2004 | 07:54 PM
OMINOUS_87's Avatar
So you wanna run a solid roller right?
Old Jan 28, 2004 | 07:57 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
I am highly considering it.
Old Jan 28, 2004 | 08:05 PM
OMINOUS_87's Avatar
Old Jan 28, 2004 | 08:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How much lift and spring pressure are you talking about here?
Old Jan 28, 2004 | 08:36 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
I would run the comp cams 977 valve spring which has a 155# seat pressure at 1.85 install height and a 441 lb./in. spring rate.
The cam I am looking at is a Comp XR274R (274/280-236/242-.564/.570-110) mechanical. Another problem arises though with this.. considering that the 977 springs are only good for 600 max lift, and i would be at 601-608 with my 1.6 rockers. I believe this could be remedied by having an install height of 1.9" with 133# seat pressure, and considering I am running titanium retainers.. I dont believe I would have a problem with valve float.
Also if I do run and install height of 1.9"... that would open the door to the next size cam being the XR280R(242-248/.570-.576(.608-.614 w/ 1.6's)).
Old Jan 28, 2004 | 08:49 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
FYI I am currently running the comp 987 spring which has a 121# seat pressure at 1.80" install and a 344# spring rate.
Old Jan 29, 2004 | 01:18 PM
79_EFI_Z's Avatar
Car: 79 Z28
Engine: 383
Anyone have any ideas?
Old Jan 29, 2004 | 02:12 PM
ede's Avatar
ede
well i was inclined to post earlier today and say you'd need 7/16 but i don't know for sure and haven't looked.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
