Got LS1 Rear Brakes on today
Old Apr 1, 2004 | 10:34 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
Well I successfully installed my brakes using my 87 hardline. It required slight bending on the passenger side and drivers side was about 10" to long. So I bent it in a S-shape by the t fitting. which by the way is in the same location.
Ive drove about 100miles with awesome results. No more groaning noises, no clanking of the pads over ever bump. A solid brake petal and increased stopping power by alot. I still cant lock up the fronts or the rear. I think due to cheap pads.
sorry no picture till tomorrow, only one.
But when standing back it looks way bigger in the rear. The rotor takes up almost the whole inner wheel. The front looks so punny compared to the back. Next 6 months I will have new rims and c5 13" Z06 rotor/caliper. Due to raise, and access to dealer discount at my job.
I ll try and upload the pic tomorrow if my girlfriend lets me.
Old Apr 2, 2004 | 03:28 AM
Kandied91z's Avatar
Old Apr 2, 2004 | 09:25 AM
RaGe's Avatar
Car: 1990 Firebird Formula
I got my install done this week.. I also have not yet taken pictures. (no digital camera)
I have been having trouble with a leak/brake light coming on. I thought I figured out my leak and drove around with no problems the last two days, but this morning I seem to have started leaking again.
I went to a 20" line on the drivers side and didn't have to bend it at all.
Still debating on the need for a new prop valve, as when there is a good firm pedal, the brakes seem about equal to the old drum setup.
I am thinking of replacing the soft rubber line that goes to the t on the rear axle, as this is where I tightened down the hard steel line the other morning that temporarily resolved my leak.
My experience thus far though with the discs working for a short period of time was that there was little difference in the feel of the brakes. Maybe a new prop. valve will help that. My guess is that I won't feel much difference until I upgrade to 12" rotors in front and match the system with the components I need. (m/c and prop valve)
Old Apr 2, 2004 | 07:46 PM
FLYNLOW92rs's Avatar
I do have LS1 rear brakes as well.......I'll get you a picture Kandied when i get the new wheels.....
Old Apr 2, 2004 | 08:01 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Here's two links with pictures on installing '98+ LS1 rear disks on a drum 3rd gen.
https://www.thirdgen.org/newdesign/t...reardisc.shtml
http://members.fbody.com/86firebird/ls1/ls1brakes.htm
Old Apr 2, 2004 | 09:59 PM
Dewey316's Avatar
Car: 1990 Camaro RS
why put the time/effort and money into a new prop valve.
get an adjustable one from wilwood. then you can really dial those rear brakes in.
Old Apr 2, 2004 | 11:50 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
agreed, theyre only like $40 from summit. i have one for my soon to come ls1 all around brakes
Old Apr 4, 2004 | 07:48 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
Pics
Old Apr 4, 2004 | 07:58 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
sorry here
having trouble resizing these hi res pics
Old Apr 4, 2004 | 08:01 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
Old Apr 4, 2004 | 08:02 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
Old Apr 4, 2004 | 08:04 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
sorry i Didn't have jack to take the wheel off
but im sure you get the idea i get more when i get a digi.
Old May 31, 2004 | 10:31 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
so what did you guys do about the parking brake cable?
Old May 31, 2004 | 10:34 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Ditto
Old Jun 1, 2004 | 07:29 AM
RaGe's Avatar
My parking brake cables are sitting on the floor of my garage...
I'll install them when I get a t56 and need them!
Old Jul 1, 2004 | 11:56 AM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
I want to do this swap on my ride, but how do I bend the line on my 87? It has the 4WD brakes. Is there a special tool that I will need?
Old Jul 2, 2004 | 09:01 AM
Spdfrk1990's Avatar
I got a question about the adjustable prop valve how are you gonna find one with the right threads. It would be a pain in the *** to try and reflare them all.
Old Jul 2, 2004 | 11:34 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
thats what you have to do. i decided against putting one on my car since its by no means a race car, and i didnt want to monkey with it, so i bought a 1le valve for my ls1 around swap. results next week hopefully
Old Jul 4, 2004 | 02:20 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Will those brakes work with a 9-bolt as well? Without making custom brackets and all that is.
Old Jul 6, 2004 | 03:50 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Follow the linky
https://www.thirdgen.org/techbb2/sho...hreadid=234163
Old Jul 6, 2004 | 03:57 AM
Car: 92' RS
Engine: LO3
Thanks Justin, that will be a future project. I'll see how I do with the fronts first. But that did satisfy my curiousity
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
