View Poll Results: Which front brakes to do?
Do the LS1 F-Body front brakes
26
68.42%
Do the C4 front brakes
10.53%
Do the C5 front brakes
18.42%
Stick with the stock front brakes
2.63%
Voters: 38. You may not vote on this poll
LS1 Front brakes for 3rd Gen?
Old Jun 13, 2004 | 04:27 PM
Firechicken91's Avatar
Car: 1991 Trans Am
Engine: 350c.i. TPI (coming soon: 357c.i. TPI screamer)
OK, I've done the LS1 rear disc brake swap and I've seen people doing the C4 and C5 front brakes, but how about LS1 F-body front brakes? Has anyone out there done this? Can it be done relatively easy? I know you probably think that I should just go ahead with the C4 or C5 swap, but if I'm going to do this, I'd like to have the fronts match the rears. Thanks for any help.
Old Jun 13, 2004 | 05:31 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Talk to Ed Miller. He can fill you in on all the pros and cons on using LS1 brakes up front. I'm pretty sure using GTA wheels will be a problem though.
Old Jun 13, 2004 | 05:33 PM
JERRYWHO's Avatar
Try this link for more info.
https://www.thirdgen.org/techbb2/sho...hreadid=183169
I have the LS1s on the front and rear.
Jerry
Old Jun 13, 2004 | 06:15 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
It all depends on your wheel size and style. Give us more info on what wheels you plan on using.
Old Jun 13, 2004 | 07:07 PM
Car: 1991 Trans Am
As for wheels, currently I'm running the 16x8 WS6 style crosslace wheels. In the future, I plan to upgrade to Corvette Grand Sport 17x9 fronts and 17x11 rears using Skulte spacers. Am I correct in assuming the LS1 F-Body brakes will fit in my 16x8 wheels? Thanks again for the help.
Old Jun 13, 2004 | 07:17 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Without using a 3/16" or so thin spacer between your GTA mesh wheel and the rotor, they won't fit...there's interference between the back side of the wheel and the outer edge of the caliper. I'm currently working on another LS1 setup that will go on a car with GTA wheels and I'll post pics of it later this week. If you go to the different set of wheels that you mentioned, you'll be fine. As for spacers, I'd go with a 2" only spacer up front and not the 2.25" thick that guys usually run with 4th gen or C5 wheels.
Pics of the interference I found is on Page 7 of the big LS1 brake thread:
https://www.thirdgen.org/techbb2/sho...0&pagenumber=7
Ed
Old Jun 13, 2004 | 08:31 PM
Car: 1991 Trans Am
Thanks for the help with the wheel clearance issue. I skimmed over those seven pages and gathered some good information. I also discovered a problem...
I don't know/trust any local machine shops to perform the hub mods or make the caliper brackets. The one shop I trust is terribly overpriced and a month behind on their work (my short block is sitting there now).
Do any of the people that have done the LS1 conversion offer kits? If not, can they get me just the hubs and brackets? Thanks for the help.
Old Jun 13, 2004 | 09:41 PM
I would recommend waiting to upgrade the brakes till you get the GS wheels. That way to can run the larger C5 brakes.
And as far as you wanting to match the front brakes with the rears, C5 rears are the same as LS1 rears.
Old Jun 14, 2004 | 06:44 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
PM ED
Old Jun 24, 2004 | 05:33 PM
Car: 1991 Trans Am
This comment started the gears spinning in my brain, so the other day while I wasn't busy at work (Wyatt-Johnson Buick, Pontiac, GMC), I had one of our parts guys look up part numbers for C5 rear brakes and LS1 rear brakes (we looked up calipers, rotors, and pads to keep things simple). Nothing matched. I was surprised to find out that the rotors for the C5 rear brakes are left and right specific. Am I looking up the wrong stuff or are the C5 rears not really the same as the LS1 rear brakes?
Old Jun 24, 2004 | 07:39 PM
ebmiller88's Avatar
Here's a pair of Vette rear calipers from Ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
Now here's the LS1 calipers from the tech article on the home page:
http://members.fbody.com/86firebird/ls1/ls1brakes.htm
They look like the same damn thing to me. Both single piston, both have the same casting marks and "PBR" in the same spot. It would be worth it to me to try and find out.
Ed
Old Jun 24, 2004 | 07:44 PM
ebmiller88's Avatar
First link:
Old Jun 24, 2004 | 07:47 PM
ebmiller88's Avatar
Second link:
Old Jun 24, 2004 | 08:28 PM
The differences are most likely do to the vettes having IRS and the fbodys having a 10 bolt. The design is the same, yet mount differently, hence the different p/ns.
Its like the 3rd gen 1LE calipers and the C4HD calipers. Same thing, just a different spot where the banjo bolt goes in, so different p/ns.
But from a braking stand point, they are the same. And just looking at them, they are the same. How they bolt on is different. And I guess they have directional rotors too.
Old Jun 24, 2004 | 09:33 PM
ebmiller88's Avatar
Back to the front brakes....
A lot of guys have asked if the LS1 brakes fit into stock 16" Formula wheels. Yes they do, and with no interference as there is with the GTA mesh wheels. They fit great. Here's a pic of the wheel on a LS1 kit I sent out this afternoon. I also made this similar post in the huge LS1 thread over in FAQ:
Old Jul 6, 2004 | 06:14 PM
Spdfrk1990's Avatar
You know i got looking at work and i can get LS1 front calipers for 26 dollars unloaded tho only way i can getem. Would it be too much of an exspence to change from my 1Le's. I know the rotors will cost me more but man 26 for the calipers isnt bad. Where could i get a bracket and hub?? and how much. Also would they brake much better then 1Le's u think. Ahh **** wait it would be a lil more cause i dont have a core.
Old Jul 7, 2004 | 12:37 AM
The caliper is a little better but its still just a 12" rotor.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
