Everyone who has had thier cars to the scale what wieght?
Old Mar 18, 2001 | 08:18 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I just wieght mine at the scale to day and got 3340 lb. the only things I've taken off have been the A/C and A.I.R. system. My sicker says 4200 lb. Almost a 1000 lb diff.. Just want to see some other peoples wights.
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, rapid fires, and 170* Stat.
Old Best 15.414 @ 87.47.
“Fallen But Not Forgotten”
Old Mar 18, 2001 | 09:15 PM
LottaBallsCamaro's Avatar
Unless youve got a convertible then you read your sticker wrong. I dont know how much they weigh exactly but I would say 3200 to 3400 is an educated guess
91 Camaro RS, 305 TBI
92 Lumina, 275,000mi and humping!
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
350hp 305TBI I dont care what you say!!!!
RAM air hood & Z28 wing.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Subframe connecters.
Old Mar 18, 2001 | 09:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The sticker is the GVW. Passengers and a full load. Put 4 passengers at 200 pounds each and there's an extra 800 pounds right there. Not that a 200 pound person would like to sit in the back.
Old Mar 18, 2001 | 09:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Don't forget 200 lbs of luggage too.
Old Mar 18, 2001 | 10:02 PM
Mike89GTA's Avatar
3330 pounds with 1/4 tank and 230 pound driver. No jack/spare either. Aluminum heads, t5 transmission, subframe connectors.
Old Mar 18, 2001 | 10:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I'm glad you added the driver weight. Hard to race without one.
I still need to re-weigh the race car now that the big block is in but last year with a small block the car weight was 3045 going down the track.
Old Mar 19, 2001 | 12:28 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Damn, you guys have light cars. Mine was 3400 lbs (on a manual scale) without driver. Thats with aluminum heads, T5 trans, subframe connectors, etc.
Your sticker that says 4200 lbs, that is the max weight the car can carry.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 19, 2001 | 01:56 AM
The ODB's Avatar
I have always weighed my cars very regular.
stock 1986Irocz, automatic, power everything, with T-tops= 3450 lbs (no driver)
Old Mar 19, 2001 | 06:46 AM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Good I though something wasnt right. I got that wieght with a just filled full tank of gas, auto, t-tops, and some junk in the car.
Old Mar 19, 2001 | 06:50 AM
2BALL-Z's Avatar
Mine is 3400 bone stock ('89 Iroc 305, 5-spd, no ttops) I put 4th gen manual seats in my car, which reduced the weight a lot! Im also going to put a fiberglass hood on and remove the a/c. So, Im anxious to see what it weighs after the "diet."
Old Mar 19, 2001 | 09:59 AM
burnoutrpm's Avatar
mine is 3241 with me out of the car.
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 19, 2001 | 10:04 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I weighed my car last time I was at Englishtown Raceway Park; here's the deal:
1986 Firebird (no ground fx kit)
2.8 V6 engine
removed a/c compressor/condensor/accumulator
steel wheels
1/4 tank of gas
Myself in the driver's seat
Weight: 3370 pounds
[edit] Wow, looks like my car's a bit on the chubby side! Maybe this extra stuff will help figure out the weight diff?
front tires: P225/60r15
rear tires: P275/60r15
I weigh 135...
At the time I weighed the car, I had finished my axle swap, so it had rear disc brakes on it instead of drums.
[This message has been edited by TomP (edited March 19, 2001).]
Old Mar 19, 2001 | 10:40 AM
vortech305's Avatar
damn why is everyone car so heavy. Mines weigh 3075 lbs. Nothing taken out. Just the car itself. Maybe cause it had the 3.1 6 cyl in there.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 19, 2001 | 10:56 AM
327 firebird's Avatar
Mine is 3100 lbs. Thats with no gas and no driver. Its an 85 v-6 firebird. It now has a 327 V-8 with aluminum heads and intake, fiberglass hood and all the old emmission and computer and harnesses taken out. Plus no spare tie or jack. But added for weight is a bulletproof bellhousing a richmond 6 speed (heavier than the t-5)subframe connectors and beefed up suspension. Oh yeah it never had AC and it has aluminum wheels and a new 9 bolt disc brake rear end (aluminum ausi calipers 12 inch rotors)and its a hard top.
[This message has been edited by 327 firebird (edited March 19, 2001).]
Old Mar 19, 2001 | 05:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
But my 3045 was with me (about 160), cast iron heads, custom made SFC (heavy steel) and a 70 pound roll bar. My goal is to get the car down to 2800 with me in it, race ready. The only way I can shave off the extra 300 pounds is to spend a lot of money. I could remove a lot more weight with fiberglass doors and fenders, complete Lexan windows, and maybe next year the tubular front crossmember and control arms.
Old Mar 19, 2001 | 09:59 PM
Stell1579's Avatar
without me my 88 iroc with everything in it, was 3460
-Stell
1988 IROC-Z 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans, K & N, SLP AirFoil,180 Thermostat+ Temp Switch, Relocated MAT, Cold Air. ,MSD Ignition wires and a few other misc goodies
1988 Pontiac Trans Am. 305 TPI Beyond MINT Condition. Dynomax Catback
Old Mar 20, 2001 | 12:42 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
how much does AC, AIR, spare and jack, and other junk like that weigh? Im just curious cause I have all that trash.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Mar 20, 2001 | 01:07 AM
The ODB's Avatar
A/C = 30 lbs
airpump = 10 lbs
spare/jack = 50 lbs
other junk = 3360 lbs
Old Mar 20, 2001 | 07:25 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Budweiser - 50 lbs.
Old Mar 20, 2001 | 07:29 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
3270 with me, giant air tank (has to weigh 25 to 30lbs. Tool box 15lbs, And a whole bunch of junk, full gas tank and steel wheels on the front, I weigh 190.
John
82 Firebird,408,Dart Iron Eagle 215's,Cam 229/239, .498/.520,TH350 Tranny, 750 Speed Demon carb, Hooker Headers(I.E. POS) Manual steering, Also a cowl for the big hole in the hood.
Shooting for low 12's.
Check out my birds new home.
Old Mar 20, 2001 | 12:48 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
3550 pounds w/o driver.
You guys with sub-3100 pound third-gen cars are deluding yourself. The only sub-3100 F-car I ever saw was on the autocross circuit in the MOD class, and it had no interior or dash, it had two lightweight racing seats, an 8-point roll cage, and swiss-cheesed panels.
Get a more accurate scale!
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Mar 20, 2001 | 12:52 PM
TTA's Avatar
TTA
3645 With me in it and 1/4 tank of fuel. I weigh about 175.
I agree... 3300 pound cars with people in them? heheh its nice to dream.
Mike
1989 Turbo Trans-Am
11.25@121.25
Only had the valve covers off once... 106K miles and still going. 300+ Runs.
1998 Trans-Am LS1 6 Speed
13.10@106 Bone Factory Stock
Old Mar 20, 2001 | 12:54 PM
UVA3rdGen's Avatar
I think last time it was wieghed to balance the wieght jacks it was around 3200 with driver and not sure how much gas(I could be wrong). Since then i have taken out the rear seats, all the none functual stock seat belts, air pump and it never had a spare and jack in it. Also a lot of the aftermarket components like the spindles, springs, and seats are a lot lighter. I really want to find some scales to wieght the car again. I was hoping for low 3000s with the radio system and muffler out becuase I do not think their is much more I could do minus gutting the light plastic interior or the rear hatch if I was pyscho.
She is not the fastest thing in a straight line but she sure will stick in the turns.
Hawian Orchid X-SCCA showroom stock 2 time national/ 1 time regional (not with me driving) champ 1LE 92 Z-28
-suspension parts include koni reds, eibach racing springs, weight-jacks, relocated control arms, and the list goes on for suspension; Port & polished TPI system sitting on top a fully blueprinted, balanced and matched race built 305; centerforce II clutch; custom 3.4 auburn rear, custom dual cat exhuast with hooker aerochamber muffler; 1LE fuel pump and gas tank; SS track baer braking system; griffin aluminum radiator; 6 point bolted roll cage with 5 point harnesses; pioneer speaker system; sparco seats, just about as light as you can get a weekly driven 3rdgen.
[This message has been edited by UVA3rdGen (edited March 20, 2001).]
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
these guys are racers at the track. Dont be so sure their cars are heavier, after all they should know and as of now its 15:1 in their favor.
BTW, thanks ODB....I think Ill start a bit of a diet for my car and shoot for 3300 W/O driver. Id say thats an attainable wieght for a non-power anything car.
Old Mar 20, 2001 | 01:25 PM
vortech305's Avatar
Your right i goofed off i saw the last paper i got from weight from my camaro w/ no gas and without me 2098 lbs. Do i look like a guy that would lie.
92' camaro
Soon to come!!!
Other car;
Old Mar 20, 2001 | 01:44 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
3700 With me in it, no AIR, no spare, about 200 lbs of steroe equipment. I weigh 200. Less than 1/8 tank of gas in full race dress.
14.3's on stock 305. I have a full trunk full of 10 inch subs, amp and a huge speaker box.
Jamie James
1986 Iroc-Z 305 TPI
1.90 60 ft 14.15@ 95.75
1.74 60 ft 12.84@107.75 on the bottle.
My IROC:
http://personal.nbnet.nb.ca/jjames/homepage.htm
Old Mar 20, 2001 | 08:10 PM
Digger's Avatar
My 82Z, t-tops,factory alum rims,aluminum borg warner t-10, fiber glass hood, aluminum intake 1/4 tank of gas and some junk weighed in at 3366 lbs. I weigh 180 , so thats 3546 with me then add some extera weight for full tank of gas, so 3600 lbs with me in it.
82 Camaro Z28
35 w/4 bolt mains
9.5:1 comppresion
heavily ported 882 heads
gasket matched Torker intake Edelbock Performer 750 carb
Speed pro cam 222 @.05 .447 lift
Edelbrock Flow Pro 1002 air cleaner
Headman headers with straight pipes
Borg Warner T-10
Posi
Fiber glass hood
Another 82 Camaro Z28
Black w/blue pearl w/silver racing stripes
355
Edelbrock Performer intake and 750 carb
Pro Flo 1002 Air cleaner
4 bolt mains
69 camaro heads 64cc
9:1 compression
TH-350 w/stage 2 shift kit
275/60R15 out back
205/60R15 front
Old Mar 21, 2001 | 09:32 AM
90 Z28SS's Avatar
On Route 66's scale , I weighed in at 3390 with me in the car . No A/C , all smog gone , light wheels , fiberglass hood ect.
Derek 90 IROC 5.7
Mods: All the usual bolt ons , 2500 stall , 373's , SS hood , lotta reduced weight.
Best Et: 13.16@101
[This message has been edited by 90 Z28SS (edited March 21, 2001).]
Old Mar 21, 2001 | 02:17 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
I weighed mine at a local feed mill.
With driver (160 lbs) and an almost full tank of gas......drum roll please.....
3600 lbs.
1985 Z-28, tpi, basically stock......so far
SEE YOU LATER INTIMADATOR
R.I.P. #3
Old Mar 21, 2001 | 02:24 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
On a CAT scale, driver in (200 lbs), half tank of gas, no spare, and options in signature. 3550 lbs. I was suprised. I thought it weighed more. My friends '89 notchback Mustang weighed 3360 with him (160 lbs) and a quarter tank.
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Double-Pump This! EFI Rules!
Definition:
NOPI: n. 1. import 2. Sticker worth 47 hp 3. import with 6" exhaust tip
antonym: smallblock
Old Mar 21, 2001 | 04:50 PM
Pony Killer's Avatar
Car: 1986 Z28
Transmission: th400
3604 with spohn torque arm, me a full tank of gas, clothes for a month, a cooler with lunch and drinks, and school books. Englishtown 2 years ago
i've got a good deal more welded in underneath now, and the car's going on a diet
if i can get the race wieght to like 3400 with me i'd be happy
It's always SOMETHING
Old Mar 22, 2001 | 12:37 PM
RGZWS6's Avatar
At Rt 66 scales:
3750 with me in it and a little less than half a tank. Headers were about the only weight difference taken from stock. Ran a 16.3 with no O2 sensor. Stereo equipment added some extra weight. Oh yeah, I had to poop that day too. Thats an extra 5 pounds!
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
Old Mar 22, 2001 | 01:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
At Bandimere scales, 3450 w/driver, trunk emptied (spare, jack, etc. made about 50lb difference), 1/2 tank gas. That's typical, I weigh every day I race (if the scales are working).
No ground effects, spoiler, etc. AC compressor & hoses removed (but not evap or cond).
Ground effects stuff is heavy. If you do 1/4 miles, every 100 lbs costs you about a tenth, typically.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Mar 22, 2001 | 01:34 PM
Andy89RS's Avatar
3260 with over half a tank of gas. No driver, no spare and jack, no back seats, 305 w/ T-5, manual windows, and a hard top.
Old Mar 22, 2001 | 09:05 PM
20-psi's Avatar
3640 at the scales at Englishtown several years ago after making a 12.75 pass.
Pete
Old Mar 30, 2001 | 08:00 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
3750 lbs. at Englishtown, ran a 14.45 @ 94.7 MPH
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 30, 2001 | 10:06 PM
RyanSS's Avatar
My last car 92 RS LO3, stock, power windows, locks alarm, speakers, box, amp, tools(5lbs), other crap(25lbs.) no driver.
3340lbs. on scale at landfill.
Old Mar 31, 2001 | 09:07 AM
82camaro's Avatar
Car: 82 camaro SC
Everybody needs to use the same accurate scale. I weighed mine, drove 30 miles to another scale and it gained 213 pounds. Both 'claimed' to have calibrated scales.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jan 3, 2005 | 04:54 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I have the following two cars:
1992 B4C with aftermarket control arms and panhard, and small 4 point bolt-in highway patrol roll bar, slp headers, aluminum heads, aluminum water pump, no cats or smog equipment, and a 275# driver.
This is "The JYD" it is a 1985 "ZERO OPTION" 2.8 T5 sport coupe that had an iron headed 355 T56 swapped into it along with true dual exhaust, and a heavy moser 9"
which can be seen HERE
was weighed as 2840 one scale and 2864 on the other (minus driver) I drove from one grain/feed scale to a "CAT" truck stop scale) with the following:
the V6 was switched to a iron headed V8 SBC
the light T-5 was switched for a heavier T-56
the light 7.5" rear swapped for a 9" moser
heavy steel subframe connectors
nitrous bottles, headers, second fuel pump, ignition system, bigger radiator, heavier exhaust, and larger battery were among the many weight adders in this car as well.
I am currently looking to find out what other scaled zero option sport coupes weighed at the scale.
Old Jan 3, 2005 | 06:01 PM
five7kid's Avatar
Dang, Tom, what prompted you to dredge this old thing up?
The scale photo looks familiar, though.
Old Jan 3, 2005 | 06:19 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
a discussion about how light the JYD is and me trying to find out why. I made the following post:
https://www.thirdgen.org/techbb2/sho...hreadid=273235
and I was referred here by another member's search
Old Jan 3, 2005 | 07:24 PM
five7kid's Avatar
Oh. I don't frequent them parts.
Old Jan 3, 2005 | 07:36 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
If you go to the BFE shootout you might get to see the JYD in person.
Old Jan 3, 2005 | 07:53 PM
five7kid's Avatar
I'd rate the chances of me being able to justify that somewhere between slim to none. I've already been asked to suspend all local activity, even.
Love to see it, though. Looks like it ran very strong at Bandimere.
Old Jan 3, 2005 | 09:21 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
suspend all local activity?
Old Jan 4, 2005 | 12:52 AM
five7kid's Avatar
Translation: "Take a break from racing."
Old Jan 9, 2005 | 08:33 PM
anondude13's Avatar
_
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
