$3000 later, new engine, heads, and intake. Coolant in the oil, WTF?
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
Okay I have replaced my engine, heads, and intake trying to get rid of the coolant that keeps getting in my oil. I did a coolant pressure test and it looses 1/2-1 PSI over 2 min. When I run the car for about 15 sec and pull the radiator cap there is tons of foam which is the signs of a bad head gasket a heads gasket. How in the world is the head gasket blown if its brand new engine, heads, and GM head gasket. I also torqued the heads to spec and used permatec 2A on the bolts. Is there something I am overlooking??
I don’t have an air compressor so I can’t do a leakdown test.
Car: 1989 Iroc-Z
I just drained the oil for about the 7th time in 150 miles. This time I put about 30 miles on it and there is a slight trace of coolant in my oil. Tons better then before I changed the intake. I have changed the oil and filter about 3 times since I have changed the intake so it is not just residue left over. How can i figure out where exactly it is coming from?
Car: 1989 Iroc-Z
Also the coolant pressure tester bounces a 1-2 PSI when I rev the engine up to ~2000 rpm, is that normal?
Car: 1989 Iroc-Z
Originally posted by Dr.NickRiviera
do you have a new intake manifold? If not ,get it checked for cracks.
Originally posted by PLANT PROTECTION
Do you have any new pics of the oil?
I got fed up and bought an air compressor today to do a leak down test only to find no one sells leak down testers near me except Napa and they want $110! I have seen them on ebay for $40. Anyone know a good place to buy a leak down tester or has anyone built one?
EDIT: I built a leakdown tester today, you can see it here: https://www.thirdgen.org/techbb2/sho...hreadid=248479
I will do the test tomorrow and see if find the problem.
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Originally posted by 89 Iroc Z
I have to take a screw drive and stir up the oil to be able to see it well.
eightsixseven
Dec 16, 2024 01:50 PM
Navy8125
Aug 21, 2015 09:32 AM
