JET carburetors
Old Jul 5, 2004 | 09:51 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
JET carburetors
I've got a fuel leaking problem on my 84 t/a with a stock q-jet. The leak is coming out of the fuel inlet into the carburetor. A while ago, my dad rethreaded it, but we still have to tighten it everyonce in a while, cause it keeps getting loose and leaking. after i put the 350 in, (hopefully next fall) i don't want to deal with the fuel leak. Are JET q-jets a good choice?
Old Jul 5, 2004 | 10:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If yours is an american G-jet, yours is computer controlled. I think the JET carbs are non-CC.
Old Jul 6, 2004 | 01:03 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
They'll rebuild pretty much anything.
Old Jul 6, 2004 | 05:13 PM
84 t/a 5.0's Avatar
Yeah, mine is CC'd. If they rebuild it, how could they fix the leak problem if we already rethreaded it? Any other options, or am i gonna have to keep retightening it when it leaks?
Old Jul 7, 2004 | 01:07 AM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
According to one of the magazine articles on this site JET will do CC Q-jets. However I'd discourage going with them. I just got a stage 2 non CC Q-jet from them like 6 months ago. Man they screwed that thing up pretty good. It has taken me a while to undo some of the crap they did (hows about a metering rod with a broken tip and a cracked accelerator pump seal for starters!) . But since some of the tuning on a Q-jet is done with drill bits it makes me wonder. Jet's Q-Jet guru Sean Murphy left the company a while back and has his own carb place now. That would be a better option or to try The Carb Shop in Ontario Calif. if you are serious about a professional rebuild. Oh and jacked inlet threads are common on Q-Jets, so I think the pros know how to fix them.
HTH
Old Jul 9, 2004 | 03:28 PM
CaysE's Avatar
Where is Sean's new place?
Old Jul 9, 2004 | 11:41 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Sean Murphy Induction
www.smicarburetor.com
(714) 842-1881
17662 Metzler Lane
Huntington Beach CA 92647
That's according to the Oct. 2003 CHP.
Old Jul 9, 2004 | 11:47 PM
THEGENERAL's Avatar
have you tried putting any plumbers tape on the fitting going into the carb to help seal it up alittle .....should work just fine
Old Jul 10, 2004 | 01:02 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Plumbers tape and gas dont mix very well. Try Teflon thread sealer instead.
Old Jul 10, 2004 | 02:58 PM
ljnowell's Avatar
either one will work fine. Used em both and never had problems. As long as the tape says for use on metal and not plastic, cause yes, there is a difference.
Old Jul 10, 2004 | 03:30 PM
br()bert's Avatar
Car: 85 firebird
The thin white pipe thread tape(teflon tape) gets eatten away by fuel. When i got my mallory fpr i ignorred the warning that said "do not use teflon tape as a thread sealer" Two months later my fpr was leaking like mad, all the teflon tape was gone.
Now i use permatex thread sealant with teflon. It doesnt get eatten by gas like the tape does.
Old Jul 10, 2004 | 04:39 PM
ljnowell's Avatar
Never had it happen to any of mine. Always used it at the fuel pump, on heater hose fittings, even tranny fittings at the radiator. Pretty much anything.
Old Jul 10, 2004 | 04:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I just went to Lowe's and picket up a roll of thread tape that says it was rated for gasoline. Haven't had any problems to date.
Old Jul 10, 2004 | 05:58 PM
br()bert's Avatar
Car: 85 firebird
Got me then, mine didnt last. Maybe it was the type of tape i had.
Old Jul 10, 2004 | 08:06 PM
THEGENERAL's Avatar
thats what i used too and never had a problem with it at all
Old Jul 16, 2004 | 06:50 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I am VERY happy with my stage 2 Streetmaster Q-jet. I gave them all my specs over the phone, and it performed out of the box- I have never touched the idle mixture screws, and my A/F ratio was right on at the chassis dyno.
Old Jul 17, 2004 | 01:19 AM
CaysE's Avatar
Is it computer controlled?
Old Jul 17, 2004 | 01:42 PM
Car: 3
Engine: inboard
Mine is not, however, about four years ago in HOT ROD they did a project where a Firebird owner built a 385 stroker and it had to pass AZ emissions, they used the CC Q-jet on an Edelbrock Performer manifold and had JET go through the carb, they were very happy with it.
Old Jul 17, 2004 | 05:21 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Four years ago Sean Murphy was working for them, not any more.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
