1 3/4 on a 305, Bad idea? HELP!
Old Sep 8, 2004 | 06:55 PM
LUVmy92's Avatar
Car: Camaro
I have a 305 and am in need of headers. I know the 1 5/8 headers are recommended for the 305 but I plan on a 350 or 383 swap and I dont want to buy headers twice. What kinds of negative effects if any will I see by going to the larger 1 3/4 size? I am thinking Hooker 2055's coated with no air tubes. I am a novice when it comes to headers and I have done as much reading as possible but I need real world answers. The going rate seems to be $500 (Hookers) to $650+ (SLP's) for a good coated header. I dont want to **** away that much money on something that will get ruined somehow or cause problems with my crappy *** 305! Help me make an informed decision.
Old Sep 8, 2004 | 09:44 PM
25THRSS's Avatar
I don't think it has all that much to do with Cubic Inches, more rpm than anything and hp. Either will be fine, but you won't see any real negative effects from 1 3/4 on a 305.
Old Sep 8, 2004 | 10:40 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
He is correct on this one
Old Sep 8, 2004 | 10:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As you said 1 5/8" would probably yield better results but since you are going with a bigger motor in the future there is no point in getting 2 sets. Also, anything is better than the stock manifolds and you will still see power gains.
25THRSS's Avatar
Ofcourse I am
Old Sep 9, 2004 | 12:20 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Just get the 1 3/4" and be done w/ it. The only downside you might see is a little bit more loss in torque over the 1 5/8" due to lack of velocity of the exhaust gasses. It won't hurt anything though.
Old Sep 9, 2004 | 09:08 PM
rsn932's Avatar
correct me if i am wrong but dont they only come in a 1 5/8 version?
when i bought mine like 2 months ago i never saw a 1 3/4 version of them in any of my research
so if you want 1 3/4 shorties, SLP is your only choice
Old Sep 9, 2004 | 09:28 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Correct and correct.
Old Sep 9, 2004 | 11:22 PM
Abubaca's Avatar
Sal, you will probably notice a slight torque loss. I noticed it on my L98, but you've got the 3:73 too. That'll help even it out.
I'd go with the 1.75 SLP's!!!
Old Sep 10, 2004 | 12:21 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I agree. Those will be a good header for both.
Old Sep 10, 2004 | 08:46 AM
LUVmy92's Avatar
Car: Camaro
Ok I must have read for too long when I saw the 1 3/4 on the 2055's. Well I really want the SLP's but I dont like the $600+ price for the coated headers. Oh well I guess I gotta pay to play.
Old Sep 11, 2004 | 02:18 AM
joshwilson3's Avatar
Old Sep 11, 2004 | 09:42 AM
LUVmy92's Avatar
Car: Camaro
1 5/8 is recommended for the 305 by a few companies. The 3.73's will help with the slight loss of low end torque (basically just get the damn thing going) from the use of 1 3/4 headers, according to the way I read it. The ceramic coating will add dollars to the final cost but it will stop corrosion, increase exhaust flow, and keep the temperature of the headers lower (longer header life). The pretty finish is just an added benefit. it all comes down to what you consider too much money to pay for headers!
Old Sep 12, 2004 | 04:55 AM
Old Sep 12, 2004 | 02:16 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
im running slp 1 3/4s on my 305 with 3.73. i have a lt1 intake so that killed some torque as well. but it still has enough torque down low to burn off 1st and most of 2nd if i can overcome the awesomeness of spohn suspension, but thats on crappy tires, on a crappy road, and really beating hard
Old Sep 16, 2004 | 05:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Of course it has something to do with cubic inches. How could it not?
Primary tube diameter is all about exhaust velocity. The larger the tube, the less the velocity at a given RPM. With a small displacement engine, at low RPMs, the exhaust will get "lost" in large diameter primary tubing, and velocity will "die" - killing the scavaging effect. RPMs have to be higher in order for the velocity to stay high enough to produce the scavaging.
With a larger cubic inch engine, the exhaust mass, and therefore volume, will be higher for each exhaust pulse. Therefore, the velocity will be higher at the same RPM as the smaller engine. Therefore, you can use larger primary tubing and still maintain velocity. Or, put another way, the velocity will be higher at a lower RPM in a larger displacement engine than a smaller displacement engine.
The smaller the engine, the higher the RPM for proper exhaust velocity for good scavaging. The larger the engine, the lower the RPM for proper exhaust velocity for good scavaging. The larger the engine, the larger the primary tube for good scavaging at higher RPMs.
Cubic inch displacement is directly tied to primary tube diameter, and primary tube diameter is directly tied to power band. You can't separate the three.
Old Sep 16, 2004 | 12:30 PM
CaysE's Avatar
I think I'm starting to understand engines finally... because I have a question for five7kid!
Isn't your explanation based on the assumption that the heads are the same? Or rather, the exhaust valve lift and diameter are the same? I'm just talking theory (because I don't know the actual flow numbers on different heads), but I'm guessing that the heads on a 350 have larger exhaust ports (or farther lift) than a 305, meaning the same header can have less of a scavenging effect on a 350 than a 305.
I know I'm wrong somewhere... where is it?
Old Sep 16, 2004 | 04:20 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
wouldnt the amount of exhaust be determined by how much air/fuel enters, and how much of it is burned? if there was 100% volumetric efficiency would exhaust still be necessary?
Old Sep 16, 2004 | 05:27 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Exhaust is still necessary. You may burn everything up in the cylinder but it doesn't just disappear. "Matter is neither created nor destroyed, it simply changes form."(Chemistry class) So no matter what: as long as you're sucking stuff into the engine you're still gonna have to spit it back out.
Old Sep 21, 2004 | 11:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If there was 100% volumetric efficiency would exhaust still be necessary?
Yes. There are engines out there that run at (or very near to) 100%... like competition blower motors running HUGE amounts of boost. They still need exhaust systems.
Old Sep 21, 2004 | 11:52 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I understand where you're coming from, but there's something a bit wrong here.
The 305TPI (LB9) heads are VERY similar to the iron 350TPI (L98) heads. They have the same 1.84/1.5 valves and flow very similarly (meaning they will be a restriction on a 350 motor before they are a restriction on a 305). From what I've seen, they only flow 2-3cfm difference. The L69 HO carbed motors also had very similar heads to the LB9.
However, this is not the case for the crappy stock heads on L03s and LG4s. They are much poorer in design.
In any case, if the exhaust flow is LIMITED enough by the heads, then bigger headers would make scavenging even worse because there would be even less air coming into them at even slower speeds... if that makes sense. The idea is you want the air to get out of the cylinder as fast as possible after combustion. If you slow the air down at all, you reduce the scavenging effect.
Old Sep 22, 2004 | 06:00 PM
five7kid's Avatar
A couple of minor details: L98 heads have 1.94/1.50" valves and 64cc chambers vs. 1.84/1.50" valves and 58cc chambers for LB9/L69/LG4 heads. However, the port volumes are very similar.
FWIW, I put 1-1/2" primary (long tube) headers on my '71 GMC 350 pickup a few years back, attaching to the same dual exhaust that I had installed on the factory manifolds. The difference was amazing, even more so than going from single exhaust to dual. The small primaries were ideal for the small valves/low RPMs of that 350 utilized to keep gas velocity up and promote good torque/pulling. 1-5/8" primaries would have moved the exhaust power band up, creating a mismatch with the rest of the combination.
My observations above assumed that all else remained equal, with only displacement changing. 2" primaries are often used on race 350 motors that rev to 7000, but that doesn't mean that all 350's should use 2" primary headers.
Old Sep 23, 2004 | 12:55 PM
Old Sep 23, 2004 | 01:20 PM
Air_Adam's Avatar
Originally posted by joshwilson3
So should I go with 1 5/8" or 1 1/2" primaries for my stock 305 TBI?
thanks
Get 1-5/8"... 1-1/2" just sucks on any SBC if you wanna go fast.
Old Sep 23, 2004 | 02:04 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Dont get the Coated SLP's. Get normal SLP's and have them coated. Their coating sucks. I have seen the pics. Pay ACS to do it. Also the 1 3/4's are best if you plan on putting some bigger cubes in.
EDITED: I have seen the pics of their coating after 6 months, and yes I own a pair myself.
Old Sep 23, 2004 | 03:37 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Would the 1 3/4" headers be sufficient for an engine with around 400cid?
pimp2303
Jul 27, 2017 02:03 PM
Derick15
Sep 17, 2016 05:28 PM
Jae992
Aug 27, 2015 09:07 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
