What is the optimal compression ratio for turbo?
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Sorry for such a basic question. Im about to build a new 355 shortblock and plan on installing a turbo in the near future. Going all forged and now is the time to lock down my compression ratio.
Car: 86 IROC-Z
Mainly a weekend cruiser and several trips to the dragstrip each year. Plan on running 93 octane. Amount of boost? Well that depends on how it plays out. Im guessing 9.0 is a safe target to shoot for then? ... and I have aluminum heads on top.
As low as you can possibly tolerate off boost… boost makes more power then compression any day. At some point I intend to build something in the 6.5-7:1 range and throw all the boost I can find at it. FWIW, there have been a few oem turbo 4’s in the 7.5:1 range that were plenty driveable and there were some NA V8’s in the 70’s that were in that range also and were tolerable…, so it can be done without suffering too badly. Hell, a lot of the 305’s out there as well as all the 2500 and 3500 truck 350’s through the 90’s and late 80’s were in the mid/low 8’s…
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I wouldn't go lower than 8.5:1 for the turbo.
-- Joe
Huh, I guess things like the sunbird GT and assorted saabs were totally unstreetable with compressions in the mid 7’s… and I guess the turbo porsches (some got down into the 6.5:1 range) never actually saw boost but somehow won races anway.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't think he's gonna be running enough intercooled boost to justify 7:1 compression ratio. 8.50 should be just peachy with just about any turbo he finds.
-- Joe
Guest
Posts: n/a
just from experience and my Typhoon being stock:
Stock Typhoon is 8:35:1 pushing 14.7 lbs max boost. using a 2 Bar.
i have sense gone to a 3 bar and running 17lbs of boost.
in stock form, the turbo doesnt have much lag, course the lag is dependant on the size of the turbo itself and converter you use.
but i think 8:35:1 is probably the lowest you want to go.
i honestly dont know why more people dont build the 4.3 V6 for the turbo. i see everyone using the 3.8 and i wonder why. the 4.3 has a 4.00 inch bore which is bigger than the 3.8. its basically a 350 with 2 cylinders hacked off.
anyways im getting side tracked. sorry
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Its like the "whydont people put SBC's in hondas?" well, if most honda's didnt beat thirdgens, I supose they would.
-- Joe
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
The GN's and TTA's used 8:1 compression stock. I forget what the GN's ran as far as boost but the TTA's were set to 16.5 stock.
I have just under stock compression in my motor(something like 7.8-7.9:1)and run 19-20psi intercooled boost on 93 octane with no detonation and the car is very streetable.
HTH,
Steve
HTH,
Steve
Huh… compression in the 7’s and only 66% the cubes… I bet your car is totally unstreetable, huh? No low/midrange, right?
Car: 1992 B4C 1LE
A turbo porche is like 11:1 but it has a totally different combustion chamber and quench.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm intercooled, and about 10-12psi with a vortech S-Trim.
I figure, if you can run 6-8psi on a non intercooled, 10.5:1 LT1, then I can run 10-12psi on an intercooled alum headed 9ish:1 SBC.
-- Joe
Car: I
Engine: Taunt
Transmission: Mustangs
Originally posted by anesthes
Cuz the 3.8s are faster.
-- Joe
-- Joe
Man this turned into quite the rant. Sorry, I guess I just get annoyed when people take an econo-car and try to make it into a race-car and in the end they end up with neither.
Oh, and there is no optimal compression ratio for a SBC's. Way to many variables and differnt applications for there to be one magic number. In the area of 8.5:1 certainly is a popular choice though.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by Dustin Mustangs
That's funny, I really hope you were joking. All else being equal, the 4.3 will be faster. I realize that more people are laying down fast times with the 3.8, but that's becuase more cars came with them and a turbo from the factory so that's what the majority of people run.
No, I was not kidding. I don't like the 4.3..
I'm also wondering what hondas you are talking about. The fastest one I've seen at the strip was modded to hell (turbo kit along with other things) and running a 14.9. He claimed it was supposed to be good for a 14.1;
woo-hoo, here's a cookie. I also know of numerous hondas in the 16's and 17's. If you've moded your sbc thirdgen to a 14.9 then you need to sell it and go buy a honda with some altezas aand neon. I can think of a half a dozen real reasons why folks don't run SBC's in honda's, none of them being how fast they are in comparison to a thirdgen.
-- Joe
Car: I
Engine: Taunt
Something wrong there. Buddy of mine owns a race shop. All he does is honda. I race with a lot of his customers.. 11 and 10 second cars all day long. Few "lightly" modified cars in the 12s.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Boy would I be interested to see something like this backed up with real numbers and specifics on the build(s). Certainly the lightly modded 12s hondas. You must mean 1/8 mile, right?
Yet kids (90% of tgo) with heavy lead sleds and a modded TPI think they're the bomb.
-- Joe
Car: I
Engine: Taunt
What's the fastest honda run stock?? Mid to low 15's (sorry, I'm not even considering the s2000) when they're driven right, which most 'tunners' will struggle to pull off. I don't care what car or how light it is, you're not taking 2.5++ seconds off an ET with 'minor mods' unless your dropping the thing off a cliff. By the way, this:
is not what I ment by backing up your claim with real numbers. Somehow I am not suprised.
Also, I'm not naive enough to think third gens are the king of the streets. Maybe that means I don't fall under your 90% of tgo ASSumption. I do think that they are a much better starting point for something that can hold it's own at the track when compared to a 30mpg 4-banger fwd soccer mom compact. That's just my opinion, and I don't think I am alone as far as this board goes. I would imagine you are, which is fine, but if I where you I'd sell my 'turd gen' and buy my little sisters 1.6L civic so I could sleep at night.
Lighter car, more efficient engine, 300 hp = mid 12s.
Guest
Posts: n/a
the only reason they are faster is because, look at the car they come in.
GM used the 4.3 because it needed more power to push the trucks/SUV's because of weight.. the Ty weighs 4800lbs. i guarentee if you put the typhoon motor into a TTA or GN it will be faster.
GM completely underated the 4.3 in power and torque. if you go over to the www.syty.net board you can see what im talking about. there are guys there that have dyno'd the truck that was all stock and made 335hp and almost 400lb/tq (GM rates them 280hp and 345lb/tq)
push a 4800lb truck to 14.1 stock is pretty quick.. the engine responds to mods like a madman.. 12's are easily done with just tuning, a fuel pump, and a mild chip, filter, ect. no major engine mods at all.
on that board check out "recipee for 12's" its all you need.
BUT i will say that the 4.3 upper and lower intake manifold are extremely rare to find, no one makes aftermarket replacements. the throttle body is just an L98 48mm.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Guest
Posts: n/a
you just said it yourself.. Chinese.. which i may add not just because they are chinese, but are horribly built, usually warped.
i dont personal experience, but heard and seen from posts, people that have.
ive never seen one on ebay though, i'll start looking around, the design on the syty intake was pretty good, the faster trucks have switched to a single plane like you have. im keeping my close to stock, these trucks are way too tempramental to screw around with.
anyways im off the topic, sorry.
a little off topic but want to clear up a cpouple of things;
I own a Typhoon and a Syclone so I know a little.
Typhoons weigh 4100 (my 93)
Syclones weigh 3750
There is no aftermarket 23* manifold made that will bolt onto a SYTY. The reason I made one for mine is I am using vortec style heads.
They did not use the buick engine in them as there was not enough room to clear the turbo placement, besides it was put together at PAS (privately held company)so it had to be a bolt in.
I have never seen a "slightly modified" honda go any faster than a 14. We have a local guy who has a totaly gutted civic with a v-tec engine and a fogger and he only musters 12, 0hs with slicks.
Now back to our regularly scheduled topic.
Automatic trans, Street, pump gas, intercooled 8.5
Automatic trans, Drag Race, race gas, Trans brake, A/w intercooler 9.5.
Manual trans, drag race, alky, A/W intercooler 7:1
Yes lower compression and more boost will make more power but with a automatic it will never make enough power to spool up the turbo to launch.
JMO
Syclones weigh 3750
JMO
There are quite a few newer turbo cars running much higher compression then that, but most clearly were not designed as an all out performance setup and the turbo is more of a little bit extra at the top end rather then how the thing actually makes power across the power band. Some of the newer Porsche turbos had as high as 8’s compression but it dropped quickly as you looked at performance specific models (like the “s” models).
Car: 1992 B4C 1LE
Im trying to think of which model. We were using the book to set the cam timing, I read it right out of the porsche book. Its hard to remember because it was 10 years ago. It was a model with the engine in the rear (VW style). I remember how it listed the turbo compression as 11:1 (which I thought was riduculous) and some snooty remark about that it was that high due to the superior combstion chamber design, but other that that I don't remember much.
Damon
Sep 26, 2015 04:29 PM
