Failed the California Smog Test
Car: 1990 Pontiac Formula WS6
Engine: LB9 5.0 TPI
Transmission: T-5 Manual
So I went had got the initial registration smog check and it failed the 15 mph NOx but passed the 25 mph. Here's the breakdown:
Test HC(ppm) CO(%) NO(PPM) Results
15 mph max meas max meas max meas
108 87 0.71 0.15 767 839 Fail
25 mph
83 72 0.58 0.23 706 633 Pass
If anyone has any insight into this, please let me know. The car is a 1990 5.0 tpi so it's the speed density intake not the MAF.
25 mph
Engine: LB9 5.0 TPI
Thanks RBob, now I just need to find out how to adjust the timing.
Relatively new to this whole 3rd gen TPI thing, It's nothing like My LT-1.
So if anyone has a step by step on how to adjust the timing and what I need or if anyone that lives in San Diego could give me a hand, It would be greatly appreciated!
So if anyone has a step by step on how to adjust the timing and what I need or if anyone that lives in San Diego could give me a hand, It would be greatly appreciated! Supreme Member
Car: '86 Berlinetta
Get a timing gun. Attach the clip thing to the #1 spark plug wire, aim timing gun at balancer and find out what your timing is at. Then loosen your dizzy (there's a bolt or two, i cant remember, around the base of the dizzy) then turn the dizzy accordingly until you get the right timing.
Engine: LB9 5.0 TPI
Okay just for giggles I went and tried to pull any trouble codes from the ECM and I got code 32. Which I believe has something to do with the EGR......
I was reading up a little bit in my chilton and It says that the EGR valve keeps NOx levels down by injecting exhaust gases into the combustion chamber. Could this be why I failed the 15 mph? But still why wouldn't it fail the 25 mph as well.
I was reading up a little bit in my chilton and It says that the EGR valve keeps NOx levels down by injecting exhaust gases into the combustion chamber. Could this be why I failed the 15 mph? But still why wouldn't it fail the 25 mph as well. Joined: Mar 2000
Transmission: 4L80E/4L80E
Depends upon the conditions in the combustion chamber at each speed. If you've got "hot spots", they may be more of a factor at the lower RPM. Or, the PROM timing table may produce higher combustion temps at the lower RPMs - backing off the base timing may improve that situation.
Car: '91 Camaro Z-28
Transmission: auto
With the timing, if your timing isn't set within a degree or two of factory spec they would have failed you for that as well. The print-out they gave you will should tell you where the timing is at. If it matches the sticker under the hood then you can't adjust it or they will fail you for that too. If it doesn't match the sticker then you need to adjust it until it does.
You might want to post this on the SoCal regional board as well. Being a major concern in SoCal many of the members there fully understand what the numbers mean and what you might need to do to fix them. Good luck.
P.S. Don't go back and try to smog again w/o making a significant change. The state keeps track of how many times you fail and you don't want to be classified as a gross polluter.
Car: check
Engine: check
Transmission: check
Slow91, I didn't realize CA checked the timing for emissions. They are tough out there.
Formula_racer, when you check the timing need to disconnect the EST connector. This will put the distributor in bypass mode which is when the timing can be properly adjusted.
If there are EGR problems, such as shown by the code, this will make both the NOx and HC levels high. With a double wammy at that. As Chiltons stated the EGR keeps the combustion temperature down which reduces NOx.
The double wammy happens when the EGR system isn't allowing as much EGR into the engine as the ECM thinks it is. When EGR is active the ECM adds timing and pulls fuel. Without the proper amount of EGR this action produces more NOx and HC then if the EGR system didn't even exist.
On vehicles with as many miles as the typical 3rd-gen the EGR passages can be clogged with carbon.
RBob.
RBob.
Engine: LB9 5.0 TPI
Well the print out say the timing is set at 6 BTDC unfortunately the emissions sticker under the hood is gone so I don't know what it should be set at for a 90 5.0 TPI w/5spd. Oh and where is the EST connector???
Transmission: auto
Having said that, I believe that I read somewhere (I think on the results page of my last test) that if your timing is with in 1 or 2 degrees you can pay the "test only" tech a state set fee of $15 or $20 to set it correctly for you so you can pass. If it's off by more than 2 degrees you automatically fail (the tech isn't technically allowed to fix it) or if it's within 2 degrees but you don't pay to have set properly you fail. Lucky us, huh?
California's not all bad though, a couple weeks ago I went snowboarding on a Monday and Kayaking in the ocean on Saturday, you just take the good with the bad.
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
"TEST ONLY CENTERS" as stated are NOT allowed to adjust or repair per BAR laws. Even an unplug vacuum hose cannot be replug by the technician. That's right, he would be in violation. The only thing they can do is replace the gas cap if it fails the pressure/vacuum test.
As for the timing:
1.)If the vehicle underhood label says 6*BTDC @ 750RPM, it is allowed +/-3* and +/-50rpm. In other words, it can be between 3*-9*BTDC and in between 700-800rpm.
2.)If underhod label says 4-6*BTDC @ 750 then it has to be what it says.
3.)If underhood label say no timing adjustment, factory preset then you don't even check timing. It could be idling at 1750rpm that would still pass. However if it's idling that fast, chances are there is a vacuum leak and may possibly have the MIL on.
Formula_racer,
It is not that simple to diagnose your car just by looking at those numbers. What I mean is that to diagnose the vehicle and fix it with flying colors, not just barely passing. But at least it give me some ideas. What is the CO2 and O2 numbers? Those are an indicators if it's in fuel control. You car did not fail that bad. How old is the O2 sensor? Also, how many miles on the clock? Most likely it has carbon build-up in the combustion chamber especially if you use high octane gas. Carbon build-up in the combustion chamber is like raising the compression and raising compression raises NOx. Hope that helps. Feel free to call if you need help.
As for the timing:
Formula_racer,
Engine: LB9 5.0 TPI
Well the %CO2 was 12.8 @ 15mph and 12.6 at 25mph and the %O2 was 2.8 @15mph and 3.1 @ 25mph. Maybe you can tell me something more by these numbers. The car has about 97k on the odometer, engine was replaced about 6k miles ago as well as most of the sensors. O2 sensor, knock, temp, IAC, TPS.... all the goodies. Don't know if the EGR was replaced, doesn't appear so though as it's pretty rusty.
I went out and looked at the vacuum lines from the EGR and soleniod have started to crack and split so I'm going to replace those this weekend and then check to see if the EGR is operating properly.
If someone can take a picture of the emissions sticker from a 90 5.0 TPI so I know what everything should be set at or if anyone knows where I can buy a new sticker????
Travis
Travis
Car: 1987 TA
Engine: 350 stock/twecked
when we use to have that BS out here in MN we could apply for an emision exempt permit for the car about 300 dollars then it did not matter. the only thing they checked was that the block in the car was the same one on the aplication
maybe CA has something like this===
PS
i miss socal
later and
GB
rick
Originally posted by Formula_racer
how much does that usually cost to get done?
As Slow... mentioned, you don't want to be a gross polluter.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
OK, directly out of the Smog inspection manual (rev. 6, Sec 1.2.0)
Technically, we can replace Fuel caps and even do oil changes if we chose to do so, but most Test-onlys don't because of the whole inventory thing. If you dont sell tangible stuff, you don't have to worry about inventory on it.
BTW, as long as you don't have tampers on the vehicle, you qualify for the state giving you $500 in emissions related repairs.
NO repairs or diagnosis can be performed on vehicles at a test only staion, except for those minor repairs listed below. There shall be no charge to the customer for these minor repairs.
Minor repairs to components damaged by station personnel during the inspection;
Minor repiars necessary for the safe operation of the vehicle while at the station;
Minor repairs, such as reconnection of hoses or vacuum lines.
Since I've got a carb (1985 LG4) I get sent to a test only station every two years. But, and this is a big but, before I go to that test-only station, I go get a pre-test from somebody that can do repairs. Then I go to the test only station.
Engine: LB9 5.0 TPI
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Tampers are anything that physically and/or functionally change an emission control system.
If you have any vacuum hoses routed wrong, any hoses/wires to sensors/emissions equipment missing or changed, then you have a tamper. Basically, as long as you have the stock setup, or have an E.O. number for ANY kind of modifications, then you are OK.
Does it say temperd anywhere on the inspection Report that the station gave you?
Engine: LB9 5.0 TPI
No it doesn't say tamper anywhere on the inspection report they gave me, everything says PASS or N/A. The only part I failed was the NOx at 15 mph, Max is 767 and it registered an 839. HC's were also pretty high, 87 out of 109 max.
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Originally posted by Parrydise7
A technician can probably tell you what needs replacement/repair by looking at those numbers. Dyno Don, if you are out there, what do you think?
Yes, an experienced tech can make a damn good guess, but an experienced tech will also know better.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
(Quote)
Looks like he identified most of the problem himself
Car: 92 RS
Originally posted by pasky
Damn California sucks to own some muscle.
http://www.superchevy-web.com/tech/0501sc_smog/
Smog Legal Stroker.
