DIY White-Face Gauges
Old Dec 4, 2004 | 10:52 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I'm looking for a couple template files to make white faced gauges. Before you tell me to search- I did, for the last hour. All the posts have dead links and any attached images were of the wrong gauges (110mph, etc.) There are two tech articles on this site relating to this subject. One is a dead link, the other is linked to a canadian site which is no longer supported. There are some gauge templates on the site, but they are all metric, and none are for the 140 speedo.
Here is what I'm looking for: I need the file to do
(1) an 86 Iroc cluster w/145 speedo and 7K tach and
(2) an 89 Trans Am cluster w/140 speedo and 8K tach
Any help or links would be appreciated.
Old Dec 5, 2004 | 01:19 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
I want a 110 cluster for a 92 rs as well.... but i want it black face w/ white numbers. It seems no one makes these. Maybe we can just get a whole listing of the files people use to create their own gauges...
Old Dec 7, 2004 | 03:28 PM
GarageToys's Avatar
Nobody? C'mon you're killing me. This post looking for 90-92 gauge scans got a lot of response:
https://www.thirdgen.org/techbb2/sho...hreadid=204303
I can't be the only one looking for these. Someone out there has the 145 Camaro speedo and 140 Firebird speedo cluster files. Hook a brother up.
Old Dec 7, 2004 | 09:28 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I may still have my files from my IROC on a CD around here... I used to have them uploaded, but then fbody.com decided to charge for hosting so its all gone. I'll check tomorrow and let ya know.
Old Dec 9, 2004 | 01:52 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Good news- I found the files. Luckily that was on the ZIP disk I put some of my stuff on before my old computer crashed. I uploaded them here. Some of the files need PhotoShop to be opened. Also, the speedometer does not have a spot on it for the tripometer because mine doesn't work so I covered it up. Feel free to play with them and edit them as you wish.
Old Dec 9, 2004 | 01:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
just take yours apart and scan them... so you KNOW they'll be right.
its not like you're driving the car right now anyway......
Old Dec 12, 2004 | 03:41 PM
GarageToys's Avatar
MetalliCamaro: Thanks, I appreciate it.
Trabbis: I can scan the tach, oil press and water temps, but I don't want to remove the trip odometer rod so the speedo will sit flat on the scanner.
Anyone got the 140mph Firebird cluster scans???
Old Jul 7, 2012 | 12:21 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: DIY White-Face Gauges
Link no longer works... I'm looking for a scan of a 145mph Camaro gauge cluster
Old Jul 7, 2012 | 11:33 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Thread dates dude, your doing it again.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
