Making Torque Arm
Old Jan 23, 2005 | 07:54 PM
rjmcgee's Avatar
Making Torque Arm
Decided that after my SFC turned out pretty good that I would tackle a new torque arm. I have a picture of Spohns so it kind of resembles his.
Have to look through the mess on the table to see it here.
rjmcgee's Avatar
Another in the car
Old Jan 23, 2005 | 07:58 PM
rjmcgee's Avatar
last one
Old Jan 23, 2005 | 10:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Looks good for a home made fabrication but it doesn't look adjustable. Hows the pinion angle?
Old Feb 3, 2005 | 05:09 PM
oil pan 4's Avatar
Car: 89 Firebird
No shet that's home made, that real good.
Old Feb 3, 2005 | 05:41 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
isn't that spherical rod end for adjustable pinion angle?
I don't know I don't know much about torque arms and pinion angle just an observation
Attached Thumbnails Making Torque Arm-c-documents-settings-adam
Old Feb 5, 2005 | 08:25 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
that rod end on the front won't really do much for angle adjustments. you need two on the back to really have much adjustment.
Old Feb 5, 2005 | 11:03 AM
rjmcgee's Avatar
There are two in the back.
My bushing isn't working good and I have alot of vibrations transmitting into the car but I think I have a plan to fix that.
Those rod ends have too much slack in them and I can feel the torque arm move when I shift hard. I'm going to get rid of the front one rod end first and see if that helps and then make it solid in the back if I have to.
Old Feb 5, 2005 | 11:17 AM
Car: 91 Camaro
i kind of thought that you might have a couple in the back but i couldn't really tell for sure. how are you going to remount the front? gonna use a stock type setup or what?
Old Feb 5, 2005 | 12:27 PM
rjmcgee's Avatar
I got a set of panhard bar bushings from Energy that I am going to use. I need to turn a couple of sleeves on the lathe and make a mount for the top one on the torque arm. Probably next weekend when I pull it apart to put in the new Centerforce clutch I'll change the torque arm.
Old Feb 8, 2005 | 10:14 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
[Hemi dude voice] Sweeeeeeeeeet! [/Hemi dude voice]
Old Feb 9, 2005 | 10:34 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
for those who haven't seen this thread
https://www.thirdgen.org/techbb2/sho...hreadid=259561
Old Feb 10, 2005 | 06:52 AM
oil pan 4's Avatar
Car: 89 Firebird
Good thred .
Old Feb 22, 2006 | 05:53 PM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Transmission: t-5
RjMcgee, do you by any chance have the measurements of your new transmission mount? Im looking to do the same for my advanced metals and processing class and unfortunatly do not have access to my car (400 miles south of my college). I brought up my spare TQ arm but that only gives me certain measurements. I basicly need the measurements for the cross member itself at the moment. Thankyou very much you have inspired me to make my own instead of droping tons of cash.
Old Feb 22, 2006 | 10:01 PM
rjmcgee's Avatar
I'm sorry but I don't have any thing that will help. I just drilled the angle iron and bolted them to the car and then made the square tubing to fit. Once it fit well I tacked it in a few places and pulled it out and welded it up.
With the goofy angles involved you almost have to build it on the car or be alot smarter than I am.
Old Oct 30, 2006 | 10:02 PM
fatman's Avatar
Car: 93 firebird,89 camaro,tuneport 91 chevy pickup
Engine: 350,350,350
Transmission: 350,700R4,700R4
TA to mount question.
How did this finally turn out? I understand what I want to do connecting to the rear end but wonder how the torque arm finally connected to the crossmember. I would like to do this upgrade to our camaro this winter. A picture or short explaination would sure help me out! Thanks for the information that you have already posted!!!
Old Oct 31, 2006 | 12:24 PM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
hot69z if you have a 700r4 tranny i can get you measurements when mine arrives i just bought a used one should be here by the end of the week.
Old Oct 31, 2006 | 08:06 PM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Transmission: t-5
Thanks swim500in5 but i got all the measurements now, I finished it up in May and im hoping ot install and adjust it this winter. once i got it all installed ill post up some pics of it.
Old Nov 1, 2006 | 08:00 PM
fatman's Avatar
Engine: 350,350,350
question for hot69z
Would you please let me know how you worked out the front mount? Did you tie back to the trans or go somewhere else? What did you use for the front mount. I wonder if you would could post a picture for us now before you install it? Thanks for any help! I need to build one this winter and I am looking for ideas and vendors for the ends.
Old Nov 1, 2006 | 09:59 PM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Transmission: t-5
Im not gonna have any time this week, but as soon as i get a chance Ill post up pictures, measurments and order of operation. I will say it now tho, if your car is newer than 83 the measurements will be different, only slightly tho.
-For a tranny mount I used a 1984 5spd transmission mount for my measurments.
-For the crossmember i made to L brackets using 1/4" plate steel and drilled out the mounting holes for the crossmember to the framerails.
-With the L brackets bolted up, I raised the transmission to the correct height and degree using an angle finder from Sears, bolted up the transmission mount and took measurments and made cardboard cut outs of the cross bars and a mounting brackets. The cross bars are made out of
1/8" wall 1" diameter mild steel tubing and the mounting bracket is made up of 1/4" plate steel.
As for the tourque arm, I measured out and made one out of the same tubing and instead of attaching back to the transmission case I made a bracket out of boxed off plate steel and attached it to the Crossmember.
This is just a breif outline of what i did... when I post the pictures ill elaborate a bit more
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
