92 camaro wiring
Old Mar 20, 2005 | 08:59 PM
ssean92's Avatar
Car: sold
92 camaro wiring
does anyone have the wiring for under the hood for a 92 camaro. looking for the engine light and and some other wires that are by the brake booster. also does anyone know were the vats control module is on a 92 camaro?
Old Mar 21, 2005 | 10:06 AM
ssean92's Avatar
Car: sold
oh yeah also does anyone know were the fuel pump relay is on a thirdgen car? I need to conect the wire from the new harness to it. and also the vats module i was told by the 350lt1.com guy that i can use the factory vats i just have to hook up the blue vats wire to the factory vats box. can anyone help?
Old Mar 21, 2005 | 06:40 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Here ya go bro.
Attached Thumbnails 92 camaro wiring-c-documents-settings-matt
Old Mar 21, 2005 | 08:07 PM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
And the fuel pump relay is in the very corner next to the brake booster on the driver side. It is held on upside down by 2 or 3 bolts.
Old Mar 22, 2005 | 01:55 PM
ssean92's Avatar
Car: sold
that is too cool thanks alot. does anyone have the same kind of wiring diagram for the 95 camaro? i like this diagram. thanks sean
and also the tranny wiring for the 95 camaro?
Old Mar 22, 2005 | 02:14 PM
ssean92's Avatar
Car: sold
looking through the diagrams anw wirung graghs does anyone know what color the 4th gear clutch switch wire is. im looking and cant find it?
Old Mar 22, 2005 | 05:00 PM
Transmission: th350
Engine controls for the '95
http://www.e-toolbox.com/ads/wiring/va098095.pdf
http://www.e-toolbox.com/ads/wiring/va098097.pdf
http://www.e-toolbox.com/ads/wiring/va098098.pdf
The transmission wiring is included in the third link.
Old Mar 23, 2005 | 01:50 PM
ssean92's Avatar
Car: sold
thanks for the reply this will help me out alot now i can get the few wires that i have left hooked up
Old Mar 26, 2005 | 09:10 PM
ssean92's Avatar
Car: sold
ok guys i need to find out how to hook up the engine light. i cant seem to find the wire that goes to the light so i can hook it up to the lt1 harness
Old Apr 4, 2005 | 06:43 PM
ssean92's Avatar
Car: sold
got it all done except the alt not charging thanks guys
rocn7roc
Sep 21, 2021 02:16 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
