thirdgen sidepipes
Old Apr 1, 2005 | 09:33 AM
91sleeperRS's Avatar
Car: Sold my Thirdgens, want another one
Engine: L98/TPI
Transmission: 5-speed
Axle/Gears: 3.45
thirdgen sidepipes
is it possible to run sidepipes on a 91 RS? if so, does anyone have any pics?
Old Apr 2, 2005 | 02:02 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sure you can do it, but why would you want to?
One problem would be the heat from the exhaust melting the side ground effects.
Old Apr 2, 2005 | 10:26 AM
klumb15's Avatar
it doesn't fit the car's body style at all either....it would look n&*ger rigged if ya ask me...
Old Apr 2, 2005 | 11:29 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
At a car show years ago I saw a earlier Z (82-84 with the high GFX) with sidepipes. The license plate said "lgbrner" or something like that.
Old Apr 2, 2005 | 02:15 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
i think pipes running al the way along the side would be too big of a ground clearence issue, 3rd gens are just so low. i think its cool when just the exhaust tips point out right in front of the rear wheels though. even then, ground clearence would be an issue but not as much, becasue if something were to hit the pipe right in front of the wheel, then the wheel is going to be hitting one hell of a bump, so you probably wouldnt be driving over it to begin with, if that makes sence.
Old Apr 2, 2005 | 02:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've seen them on ones w/o GFX and they look so ghetto and trashy.
Old Apr 2, 2005 | 04:19 PM
klumb15's Avatar
now what would be cool, is if you somehow made the gfx attach to the pipes, then like cut out a big long slit so you could see some of the pipe, then have like a section of the gfx where the tip points out...that would look sweet but very unpractically because the exhaust would have to run right tight against the gfx making it melt.....so really, there isn't a good way of doing it...
Old Apr 5, 2005 | 04:45 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
This is not my car. I saved this picture from sethirdgen.org awhile back.
IMO, sidepipes on 3rd gens look awful. However if you like them then go for it.
Attached Thumbnails thirdgen sidepipes-c-my-documents-my
Old Apr 5, 2005 | 06:46 AM
9D1Formula350's Avatar
Car: camaro...????
Engine: 305ci of mouse power
Transmission: 5 speeds of fury
that would have been a nice clean car if the exhaust and hood didnt ruin it
Old Apr 5, 2005 | 07:04 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
side pipes......mmmmm
Old Apr 5, 2005 | 11:37 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I would bet the exhaust in that picture is either not functional or was as expensive as hell.
Old Apr 5, 2005 | 06:48 PM
Jade Grey's Avatar
Engine: 305TPI
It's functional, follow the link to the original SEThirdgen.org thread.
Rusty's Z28 w/sidepipes
Old Apr 7, 2005 | 10:47 PM
sp63
Guest
Posts: n/a
i think that car looks VERY "musclecarish" i like it a lot.
Old Apr 8, 2005 | 05:31 AM
Night rider327's Avatar
Car: 1988 Camaro
Tibo.... Those aint the true "tuned" side pipes where each header tube goes down to the side pipes, but it is true working side pipes.
1 and only 1 pipe is real, hooks up with a bend, then bolts to header coll. The other pipes are pipe just to make it look like tuned side pipes.
You can buy that style from www.jcw.com
Old May 22, 2005 | 02:04 AM
DanTheMan_smlk's Avatar
i dont think the side pipes look all that bad on that white camaro. It doesnt look that bad if u stare at it for a while. Just get rid of the cowl and wheels
Old May 22, 2005 | 08:44 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the guy that owns that car lives around me (as in, within a few hours) and from what i am to understand, that thing will straight MOVE OUT!
Old Jun 23, 2005 | 12:11 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
How do you guys think it will look with side the exhaust coming out the side and no side pipes like this kit..http://www.jegs.com/cgi-bin/ncommerc...90&prmenbr=361
Old Aug 8, 2005 | 11:31 PM
tad1214's Avatar
Car: 1983 T/A
Engine: OUT (350 Block)
Transmission: 700-R4 sometimes
Axle/Gears: 3.23, moser 12 bolt >=3.73 someday
DONT GET THE DYNO MAX KIT!!!!!! It doesnt come out like they say it does, it looks REALLY BAD. Both exit out the driver side rear straight out the bumper like the stock, but only on 1 side. Together. Im getting rid of mine and doing something like the purple hornies. If you really want it ill sell you mine. I hate it. Plus it fits horrible. I have a big dent in one pipe because it sits about 2" off the ground on a hard brake it rubs. BAD BAD BAD stuff
Old Aug 8, 2005 | 11:43 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Yeah I have decided to do something just like the purple hornys but just put some dynomax Bullet mufflers on it. By the way does anyone know how the Dynomax Bullet mufflers sound like and what the Moroso Spiral Flow mufflers sound like?
Old Aug 9, 2005 | 07:23 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I have sound clips of the Moroso Spiral Flows on mine, but no way to host them. I'll email them to someone if they want to host them.
Old Aug 10, 2005 | 01:41 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
I dont know how to do that hosting stuff so maby if you could tell me I might be able to do it.
Old Aug 11, 2005 | 05:53 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
purple hornys = glasspack aka the fart can of american muscle, they sound like trash.... this dude at my school has a 3rd gen with a 350 bored .060 over etc etc and i think either bullets or spiralmax and it sounds awsome real throaty but my flows are deeper sounding
Old Aug 11, 2005 | 07:32 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
on my '89 V6, I had removed the cat and replaced it with a flowmaster 3" muffler, put a 90 on the other end and finished it with a tip. only about 4" of the tip was visible and the edge of the tip lined up with the body of the car and exited right after the pass door jamb.
Old Aug 22, 2005 | 07:51 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Car is lowered 2" all the way around. It is 3" with single chambers and its ovalized where it needs to be. I have to avoid speed bumps but if the car was stock height it wouldn't be too bad. Its extremely loud.
Old Aug 22, 2005 | 07:52 PM
REALPOWER's Avatar
Transmission: Th350
Old Aug 23, 2005 | 11:45 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
that looks sooooooooooooooo low. How long have u had it like that????
I am doiung true duals, all oval, staight back, and dumping.
Well I am going to once i get my motor in the mail.
Old Aug 24, 2005 | 06:34 PM
crazycrocket's Avatar
Car: 1985 camaro
Burn the paint off maybe, but to my knowledge fiberglass won't melt, at least not at that temperature.
Sidepipes can look ok... I'm lookin at doing not the true side pipes, but side exit exhuast from a zoomie style tip.... I just don't think the round tube coming out the side really suits the square straight edgeness of the 3rd gens.
Just my 2 cents though.
Old Aug 24, 2005 | 06:59 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Corvettes do just fine with side pipes... GM even installed it themselves for about 10 years.
Side note - I didnt know gfx were fibreglass??
Old Aug 24, 2005 | 07:47 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
they aren't they are urethane..... note how they bend.....FG dont do that....if our GFX were FG mine would prolly have ripped off by now
Old Aug 25, 2005 | 06:31 AM
Engine: LS3
i really wanna do side exits. Maybe we can get pics in here of people that have done that. Side pipes are the best lookin thing on old vettes but a bit dated on our cars i think.
Lets see what kind of ideas anyone is tossing around or done for side pipes....
I am gonna go 2210's then go into 3.5 oval pipe, find my way to each side, hopefully think of a way for a crossover, then 2 oval spintechs and angle tips before the massivetires i am runnin'
Old Aug 25, 2005 | 06:12 PM
REALPOWER's Avatar
Transmission: Th350
The point is to make the shortest exhaust thats legal. That is the idea of side pipes.
Old Aug 26, 2005 | 12:43 AM
Engine: LS3
Yeah, so what if that is the point of side pipes? I never said it wasn't. I said it looks dated......
Might wanna think over what you post, to make sure you are quoting the right phrase.
Old Aug 26, 2005 | 09:02 AM
REALPOWER's Avatar
Transmission: Th350
I'm just saying that sidepipes are generally used on cars that are more for function than style. Looks don't matter. My whole exhaust together can't weigh more than 25 or 30 pounds. If I went with a rear exit instead, it would have added 10 or 20 more pounds and more restriction.
Old Aug 26, 2005 | 09:05 AM
REALPOWER's Avatar
Transmission: Th350
Hold up, are you talking about the sidepipes that stay under the car like mine, or are you talking about the sidepipes that sit under the gfx?
Old Aug 26, 2005 | 10:46 AM
Engine: LS3
I am pretty sure the thread is about the ones that are by the GFX. Like the pic above. (whitew camaro)
I am going with a ovel side exiting set up you can't see.
Old Aug 29, 2005 | 04:30 PM
jrmaatta's Avatar
Car: 2011 Ranger
Engine: 2.3L
Transmission: Stick - Shift like a man!
Good lord man!! How do you drive anywhere?? I tried that on my 87 Firebird (not lowered) and I couldn't get off my damn driveway! I had to go and put a cherry bomb in place of the oval muffler and then it dumped from there. Took two weeks to get a ticket too, heh. Stupid moron driver in his Ram 2500 barreling down at my backside while I was stopped next to a cop - thus making me stomp on the gas to not be rear-ended
Side exit = ub3r-sw33r But I'd use some sorta rectangular tips instead of circular.
Old Aug 29, 2005 | 06:39 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
lol all i gotta say is that if you run glasspacks or sidepipes you might as well change ur name to Joe.... Joe Dirt... lmao no offense but both of those types of exhaust are ugly looking and ugly sounding to me
Old Aug 30, 2005 | 06:58 AM
Engine: LS3
pipes
I bet there is a good tastful way to make side pipes on our cars, its just that no one had found it yet
I am still tossing around ideas. Do people have any sketches or ideas as to how to make side pipes work. Maybe not even total side pipes, like some kind of new ideas.
Old Aug 30, 2005 | 11:27 AM
REALPOWER's Avatar
Transmission: Th350
I am confident enough to say that if you heared my car, you would love it.
I think you should sell your system and build a motor, cause an exhaust only sounds as good as the motor making the noise.
Old Aug 30, 2005 | 01:59 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
tru but..... ponder this.... my weak 305 has been mistaken more than a few times for a 350 by 350 powered Thirdgens on sound alone.. performance is another story( a sad one )... as for the build a motor....
i am building one... a sick 350 that should be shredding the gears in my trans as of this weekend if all goes well.....
Alum heads, big nasty cam, alum intake, all matched..... *wipes drool* i been waiting a lil more than a year for this.... i cant wait.
BTW the flowmasters will stay... and when i do redo my exhasut im getting some 2.5" super 40s... although ive heard either the bullits or the spiral mufflers( cant remeber) on a worked 350 thirdgen at school.... sounded really cool but not as deep as mine
edit: as of yet i havent heard a glasspack system that i like.... most of the time its on these * Cough Red-KNeCK Cough* trucks which the exhaust pipes sit at my window level.... i really hate them but besides that fact, i dont like the "Thwappy" sound they make
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
