$32B vs $6E
Old Apr 2, 2005 | 08:44 AM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
$32B vs $6E
I posted this on the TPI board and realized I probably should have posted it here instead:
I am getting my new (old) tpi setup on Saturday. It's off of an '87 IROC 305 and has the cold start injector. I'm considering converting it to the 1989 bin and deleting the cold start injector (and VATS). But before I go through the trouble, are there really any advantages in the '89 bin over the '87 bin? And are they referred to as aryp.bin and arap.bin?
Old Apr 2, 2005 | 11:42 AM
3.8TransAM's Avatar
Engine: all 225+ RWHP
Transmission: all OD
Cold start injector is problematic. Eliminating it is one more thing less to break. The 89 code is the most advanced form the factory so it should theoretically be the best code in regards to driveability and performance.
I do believe most people here who work on the 86-89 maf cars do indeed use the $6E code as do I for my friends cars.
I dont have the specific broadcast codes for a 305 MAF car handy, but I'm sure a quick search here should net you the answers you seek.
later
Jeremy
Old Apr 2, 2005 | 03:07 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
So...are you saying that I can take my $32 code off my '86 MAF system and just load it up with a $6E bin? Can I do that? I thought the ECM's are also different.
I'd much rather use the $6E code, more options.
If possible, then in theory I could just load up a $6E bin, throw it in, and it'll run with it, right?
-HD
Old Apr 2, 2005 | 04:11 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
Well I hunted around and found out the bins I had quoted "aryp.bin and arap.bin" are corvette bins (included with TunerPRO). The bin on my ecm is ABUN. So I went to Craig Moates site and DIY-EFI, but neither has an ABUN file. Any other source to get a copy of it?
Old Apr 2, 2005 | 06:12 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
The computers are the same "165"....
Old Apr 2, 2005 | 08:16 PM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
I guess I don't really need a copy of ABUN. I just thought it would be nice for comparison. I wonder if there's a way to find out what the last $6E bin file name was...
Old Apr 3, 2005 | 11:43 AM
Vader's Avatar
If you're asking about stock BINs, the later programs have better MAF tables, better spark tables, more appropriate TCC points, and the commonly available ECU files offer more control options. The same options are there for $32 and $32B, but evidently few people have bothered to hunt up the addresses in those masks and devise a more complete ECU file to open those options.
FWIW, I'm using $6E and an ARAP based custom bin on my '86 with no problems. I disabled the cold start, toyed with the cold fuel adders, and reconnected the cold start. It actually starts best with a little of both. Go figure.
Old Apr 4, 2005 | 10:56 AM
11sORbust's Avatar
.....if you are looking for bins try www.diy-efi.org
I prefer 6E, it has worked better for me...
Old Apr 4, 2005 | 11:49 AM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
last spring I used $6E on my 86 and it runs much better. I think I used ARAP bin so I had to change the injectors to 19# and I copied my spark tables from my stock bin. I also modified the Crank Fuel PW Multiplier vs Ref Pulse to get rid of the long crank. I just pulled the fuse for my 9th injector, for now, will do a 9th delete someday. I still have a strange clunky shift when slowing down to a stop sign or turn but overall I'm very happy.
Old Apr 6, 2005 | 08:50 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Well, why won't my engine start if I load up ARAP.bin into my prom? It should at least start if I just throw the ARAP bin into my '165 comp that originally had $32 code in it right?
What am I doing wrong?
-HD
Old Apr 6, 2005 | 09:10 PM
InTech's Avatar
vats
Old Apr 7, 2005 | 12:14 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Don't forget to switch the fan N/O in the bin if using ARAP/APYP.
The other (biggest, IMO) advantage to using $6E is the 8192 baud (vs. the painfully slow 160 baud).
Should be as simple as this for loading $6E:
1) Select your bin (ARAP/APYP/ANZA [5spd LB9])
2) Reverse the Fan N/O switch in the switches list if necessary (ARAP/APYP)
3) Disable your cold start injector
4) Disable the VATS switch in the switches list if your car doesn't have it
5) Burn
6) Run
Old Apr 7, 2005 | 07:46 AM
86LG4T56's Avatar
Car: 1986 Firebird
Engine: LG4 305
What's FAN N/O?
Old Apr 7, 2005 | 09:01 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Ok, I'll un-check VATS, check FANN/O, but I can't find a switch to disable the 9th injector. By disable 9th injector did you mean to unplug it, or disable it with a switch? If with a switch, what is the switch called in tunerpro?
Thanks,
-HD
Old Apr 7, 2005 | 12:38 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Just unplug it. The cold start injector operates off of a thermal switch, so the ECM doesn't have independent control of it.
tmellott89
DIY PROM
Oct 14, 2015 02:06 PM
tmellott89
DIY PROM
Aug 16, 2015 02:58 PM
MikeT 88IROC350
DIY PROM
Jun 23, 2003 08:39 PM
doc
DIY PROM
Dec 17, 2002 01:31 PM
TRAXION
DIY PROM
Nov 6, 2000 05:17 PM
