Check out this hack job
Old May 17, 2005 | 09:28 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Can anyone tell me what this harness was for? Also there is a black plug but nothing connected to it. I have no idea what was there. This is under the passenger side dash panel.
Old May 17, 2005 | 09:29 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Also, anyone know what this is. It also looks like something plugged into it. It's just above the hacked up wiring harness.
Old May 17, 2005 | 10:25 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
First pic is your C207 connector, if you're referring to the harness with all of the wires cut. I'd like to tell you what it does, but I'm currently trying to piece that together for myself.
Old May 18, 2005 | 10:33 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The black box in the second pic reminds me of the cruise control module. I could be wrong but I have a feeling that that's what it is.
Hope this helps.
Lou
Old May 18, 2005 | 11:12 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
Was your car hooked up with an ecm? Because if it was then I believe that the harness that is hacked up was for the computer. On my car there is another harness similiar to it on the right side. Not sure what the other harness is.
Old May 18, 2005 | 04:01 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
I don't think it's a cruise control modual. The cruise was just vacuum activated with the cruise transducer. The only signal the ecm got was for VSS and TCC control. I've checked the manual and from what I understand there was no other components for it. I tried to take off the kick panel to see if the ECM was still there. I was told the car had "limited computer control" whatever that means. I wanted to see if in fact the ECM was still there. I had some difficulty getting the kick panel off, so I decided to stop before I broke it. I'm starting to think the ECM was cut out, also I don't have the ALDL connector. I pulled the panel out from the dash and there isn't even any visible wiring for where it would go. The only thing I saw under there was another fuse panel for the buzzer relay, and some other stuff I can't remember right now.
Old May 18, 2005 | 04:08 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
I believe the cut wires went to an ecm at one time and the black plug to a cruise control module thats how my gta is if i remember correctly,
Old May 18, 2005 | 06:19 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
as far as I know the '82-'84 firebird didn't have a cruise modual since it wasn't really electronic. All the cruise button did was send a signal to the cruise transducer which would create a vaccum to hold the speed. The ECM would send a signal to the TCC to lock up. If the brake or clutch was applied it would disengage.
Old May 19, 2005 | 10:45 AM
dyeager535's Avatar
Car: Which one?
Transmission: 465
So it's a two piece speedometer cable setup then with the transducer (cable in/out) mounted on the fender?
I'm not familiar with your vintage, but with VSS, no real reason to use a transducer instead of a cruise module.
Your car was "CCC", which is the electronic (primary side) Quadrajet.
Old May 19, 2005 | 05:07 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Yes, that is correct.
All the VSS did was to engage or disengage the TCC. It's not like on the newer 3rd gens where it controlled the speedometer, as far as I know.
I've seen CCC in the manual, but I don't know what it means and it doesn't really say.
Old May 19, 2005 | 09:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Info: CCC stands for Computer Controlled Carburator.
Old May 19, 2005 | 09:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The 2nd pic looks like the headlamp/key ing/sealtbelt warning buzzer.Goes in the Dr side underdash by the center console with the horn relay.The black connector in the 1st pic looks like its for the heater/A.C selector switch?The other as said appears to be for the computer.
Old May 20, 2005 | 05:27 AM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
I don't think that is what it is. I know where the warning buzzer is. It's under the drivers side lower dash panel. The pics are of the passenger side.
The heater works because I have tried it. As for A/C that has been disconnected and the compressor removed. I have the compressor, but I probably wont hook it back up any time soon.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Strick1
Sep 4, 2015 07:11 AM
tnrednneck
Aug 13, 2015 08:57 AM
